R112426000
R112426000
    RADIALL
    插件
    SMC 连接器 插座,公插针 50 欧姆 通孔 焊接
R112426000 数据手册
TECHNICAL DATA SHEET 1/2 R112.426.000 STRAIGHT MALE RECEPTACLE FOR PCB Series : SMC SOLDER LEGS All dimensions are in mm. . pn . ao COMPONENTS BODY CENTER CONTACT OUTER CONTACT INSULATOR GASKET OTHERS PARTS - PLATINGS (µm) MATERIALS BRASS BRASS PTFE - GOLD 0.2 OVER NICKEL 2 GOLD 1.3 OVER NICKEL 2 - - Issue : 0723 B In the effort to improve our products, we reserve the right to make changes judged to be necessary. TECHNICAL DATA SHEET 2/2 R112.426.000 STRAIGHT MALE RECEPTACLE FOR PCB Series : SMC SOLDER LEGS PACKAGING Standard 1 Unit - SPECIFICATION Other Contact us ELECTRICAL CHARACTERISTICS ENVIRONMENTAL Impedance Operating temperature -65/+165 ° C 50 Ω Frequency Hermetic seal 0-10 GHz NA Atm.cm3/s VSWR 1.05 + 0,0300 x F(GHz) Maxi Panel leakage NA Insertion loss 0.03* √F(GHz) dB Maxi RF leakage -( 62 - F(GHz)) dB Maxi Voltage rating 335 Veff Maxi Dielectric withstanding voltage 1000 Veff mini Insulation resistance 1000 MΩ mini OTHERS CHARACTERISTICS Assembly instruction NA Others : * Coaxial Transmission Line Only MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating end Axial force – Opposite end Torque 10 N mini 10 N mini NA N.cm mini Recommended torque Mating Panel nut NA N.cm NA N.cm Mating life Weight 500 Cycles mini 0,7390 g Issue : 0723 B In the effort to improve our products, we reserve the right to make changes judged to be necessary.
R112426000 价格&库存
很抱歉,暂时无法提供与“R112426000”相匹配的价格&库存,您可以联系我们找货
R112426000
  • 1+94.37141
库存:450
R112426000
  • 1+98.786091+11.92708
  • 50+70.3234450+8.49060
  • 100+67.59438100+8.16111
  • 250+65.27651250+7.88126
  • 500+58.66415500+7.08290
库存:132
