TECHNICAL DATA SHEET
1/2
R222.M00.720
STRAIGHT MALE RECEPTACLE FOR PCB
Series : SMP-MAX
SLIDE TYPE - SOLDER LEGS
All dimensions are in mm.
pn
ao
COMPONENTS
BODY
CENTER CONTACT
OUTER CONTACT
INSULATOR
GASKET
OTHERS PARTS
PLATING (µm)
MATERIALS
BRASS
BRASS
NPGR
NPGR
PTFE
Issue : 1107 B
In the effort to improve our products, we reserve the right to make changes judged to be
necessary.
2/2
R222.M00.720
Series : SMP-MAX
PACKAGING
Standard
100
Unit
‘W’ option
SPECIFICATION
Other
Contact us
ELECTRICAL CHARACTERISTICS
ENVIRONMENTAL
Impedance
Operating temperature -55/+165 ° C
50 Ω
Frequency
Hermetic seal
0-6 GHz
NA Atm.cm3/s
VSWR
Panel leakage
1.25* + 0,0000 x F(GHz) Maxi
NA
Insertion loss
0.15* √F(GHz) dB Maxi
RF leakage
NA - F(GHz)) dB Maxi
Voltage rating
335 Veff Maxi
Dielectric withstanding voltage
1000 Veff mini
Insulation resistance
5000 MΩ mini
OTHER CHARACTERISTICS
Assembly instruction
Others :
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating end
Axial force – Opposite end
Torque
7 N mini
7 N mini
NA N.cm mini
Recommended torque
Mating
Panel nut
NA N.cm
NA N.cm
Mating life
Weight
*VSWR: up to 3GHz; 3-6GHz, 1.35max
*Coaxial Transmission Line Only
*Slide type receptacle+Bullet+Snap type receptacle
Typical VSWR(Board to Board connection):
0-3GHz, 1.2max
Power handling (typical) :
>300W@2.7GHz at 25℃; >200W@2.7GHz at 85℃
Radial working angle: 3°min
Axial working range: 2mm
100 Cycles mini
1,3100 g
Issue : 1107 B
necessary.
很抱歉,暂时无法提供与“R222M00720”相匹配的价格&库存,您可以联系我们找货
