TECHNICAL DATA SHEET
1/2
RIGHT ANGLE JACK RECEPTACLE FOR PCB
R113.665.000
Series : MCX
SOLDER LEGS
All dimensions are in mm.
pn
ao
COMPONENTS
BODY
CENTER CONTACT
OUTER CONTACT
INSULATOR
GASKET
OTHERS PARTS
PLATINGS (µm)
MATERIALS
BRASS
BERYLLIUM COPPER
PTFE
GOLD 0.2 OVER NICKEL 2
GOLD 1.3 OVER NICKEL 2
Issue : 0203 F
In the effort to improve our products, we reserve the right to make changes judged to be
necessary.
2/2
R113.665.000
Series : MCX
SOLDER LEGS
PACKAGING
Standard
100
Unit
‘W’ option
SPECIFICATION
Other
Contact us
ELECTRICAL CHARACTERISTICS
Impedance
Frequency
VSWR
1.05 +
Insertion loss
RF leakage
Voltage rating
Dielectric withstanding voltage
Insulation resistance
50
0-6
0.015
0.03*
NA
335
1000
1000
Ω
GHz
x F(GHz) Maxi
√F(GHz) dB Maxi
- F(GHz)) dB Maxi
Veff Maxi
Veff mini
MΩ mini
ENVIRONMENTAL
Operating temperature
Hermetic seal
Panel leakage
-55/+155 ° C
NA Atm.cm3/s
NA
OTHERS CHARACTERISTICS
Assembly instruction
NA
Others :
* Coaxial Transmission Line Only
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating end
Axial force – Opposite end
Torque
10 N mini
10 N mini
NA N.cm mini
Recommended torque
Mating
Panel nut
NA N.cm
NA N.cm
Mating life
Weight
500 Cycles mini
1.800 g
Issue : 0203 F
necessary.
很抱歉,暂时无法提供与“R113665000”相匹配的价格&库存,您可以联系我们找货
