TECHNICAL DATA SHEET
1/3
R223.425.000
STRAIGHT JACK RECEPTACLE FOR PCB
Series : MMBX
SOLDER LEGS
All dimensions are in mm.
pn
ao
COMPONENTS
BODY
CENTER CONTACT
OUTER CONTACT
INSULATOR
GASKET
OTHERS PARTS
PLATING (µm)
MATERIALS
BRASS
BRASS
NPGR
NPGR
LIQUID CRYSTAL POLYMER
Issue : 0735 B
In the effort to improve our products, we reserve the right to make changes judged to be
necessary.
2/3
R223.425.000
Series : MMBX
SOLDER LEGS
PACKAGING
Standard
100
Unit
‘W’ option
SPECIFICATION
Other
Contact us
ELECTRICAL CHARACTERISTICS
ENVIRONMENTAL
Impedance
Operating temperature -55/+155 ° C
50 Ω
Frequency
Hermetic seal
0-12.4 GHz
NA Atm.cm3/s
VSWR
Panel leakage
1.065 + 0,0000 x F(GHz) Maxi
NA
Insertion loss
0.12 √F(GHz) dB Maxi
RF leakage
100 - F(GHz)) dB Maxi
Voltage rating
330 Veff Maxi
Dielectric withstanding voltage
1000 Veff mini
Insulation resistance
1000 MΩ mini
OTHER CHARACTERISTICS
Assembly instruction
NA
Others :
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating end
Axial force – Opposite end
Torque
10 N mini
10 N mini
NA N.cm mini
Recommended torque
Mating
Panel nut
NA N.cm
NA N.cm
Mating life
Weight
to 6 GHz
Interface MMBX only up to 2.5GHz
PCB to PCB -45dB up to 2.5 GHz
Mated pair height 6.7mm
100 Cycles mini
0,3840 g
Issue : 0735 B
necessary.
3/3
R223.425.000
Series : MMBX
SOLDER LEGS
PCB
Issue : 0735 B
necessary.
很抱歉,暂时无法提供与“R223425000”相匹配的价格&库存,您可以联系我们找货
