R124423243
R124423243
    RADIALL
    SMD
    SMA 连接器 插孔,母形插口 50 欧姆 板边缘,末端装入式 焊接
R124423243 数据手册
TECHNICAL DATA SHEET 1/5 R124.423.243 STRAIGHT JACK RECEPTACLE FOR PCB Series : SMA-COM SMT TYPE - EDGE CARD. All dimensions are in mm. . pn . ao COMPONENTS BODY CENTER CONTACT OUTER CONTACT INSULATOR GASKET OTHERS PARTS - PLATINGS (µm) MATERIALS BRASS BERYLLIUM COPPER PTFE - GOLD 0.2 OVER NICKEL 2 GOLD 0.5 OVER NICKEL 2 - - Issue : 1149 A In the effort to improve our products, we reserve the right to make changes judged to be necessary. TECHNICAL DATA SHEET 2/5 R124.423.243 STRAIGHT JACK RECEPTACLE FOR PCB Series : SMA-COM SMT TYPE - EDGE CARD. PACKAGING Standard 100 Unit ‘W’ option SPECIFICATION Other Contact us ELECTRICAL CHARACTERISTICS ENVIRONMENTAL Impedance Operating temperature -65/+165 ° C 50 Ω Frequency Hermetic seal 0-18 GHz NA Atm.cm3/s VSWR Panel leakage 1.14 + 0,0000 x F(GHz) Maxi NA Insertion loss 0.05 √F(GHz) dB Maxi RF leakage -( 100 - F(GHz)) dB Maxi Voltage rating 500 Veff Maxi Dielectric withstanding voltage 1000 Veff mini Insulation resistance 5000 MΩ mini OTHERS CHARACTERISTICS Assembly instruction Others : - MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating end Axial force – Opposite end Torque 27 N mini 27 N mini 2.8 N.cm mini Recommended torque Mating Panel nut NA N.cm NA N.cm Mating life Weight 100 Cycles mini 1,5600 g Issue : 1149 A In the effort to improve our products, we reserve the right to make changes judged to be necessary. NA TECHNICAL DATA SHEET 3/5 R124.423.243 STRAIGHT JACK RECEPTACLE FOR PCB Series : SMA-COM SMT TYPE - EDGE CARD. SOLDER PROCEDURE 1. Deposition of solder paste ‘Sn Ag4 Cu0.5’ on mounting zone by screen printing application. We recommend a low residue flux. We advise a thickness of 150 microns (5.850 microinch ). Verify that the edges of the zone are clean. 2. Placement of the receptacle on the mounting zone with an automatic machine of ‘pick and place’ type. Video camera is recommended for the positioning of the component. Adhesive agents must not be used on the receptacle. 3. Soldering by infra-red reflow. Below, please find the typical profile to use. 4. Cleaning of printed circuit boards. 5. Checking of solder joints and position of the component by visual inspection. TEMPERATURE PROFILE Parameter Temperature rising Area Max Peak Temperature Max dwell time @260°C Min dwell time @235°C Max dwell time @235°C Temperature drop in cooling Area Max dwell time above 100°C Value 1 -4 260 10 20 60 -1 to - 4 420 Issue : 1149 A In the effort to improve our products, we reserve the right to make changes judged to be necessary. Unit °C/sec °C sec sec sec °C/sec sec TECHNICAL DATA SHEET STRAIGHT JACK RECEPTACLE FOR PCB SMT TYPE - EDGE CARD. Issue : 1149 A In the effort to improve our products, we reserve the right to make changes judged to be necessary. 4/5 R124.423.243 Series : SMA-COM TECHNICAL DATA SHEET STRAIGHT JACK RECEPTACLE FOR PCB SMT TYPE - EDGE CARD. Issue : 1149 A In the effort to improve our products, we reserve the right to make changes judged to be necessary. 5/5 R124.423.243 Series : SMA-COM
R124423243 价格&库存
很抱歉,暂时无法提供与“R124423243”相匹配的价格&库存,您可以联系我们找货
