DF51A-12DP-2DS(50)
DF51A-12DP-2DS(50)
    HRS(广濑)
    插件
    针座连接器 通孔,直角 12 位置 0.079"(2.00mm)
DF51A-12DP-2DS(50) 数据手册
Applicable standard Operating Temperature Range Rating -55 to +105C (Note1) Operating Humidity Range 20% to 80% (Note2) Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. Voltage 250 V AC/DC Current AWG 22 to 24 : 2.0A AWG 26 : 1.5A AWG 28 : 1.0A AWG 30 : 0.5A Storage Temperature Range -10 C to +60C (Note3) Storage Humidity Range UL・C-UL Voltage Rating Current 40% to 70% (Note3) 30 V AC/DC 2.0A Applicable Connector Applicable Contact DF51-12DS-2C DF11-****SC(F)A(##) Specifications Item Test method Requirements QT AT X X X X 30 m MAX. X - 1000 M MIN. X - No flashover or breakdown. X - 1.Contact resistance: 30 mΩ MAX. 2.No damage, crack or looseness of parts. 1.Insertion Force :40.1 N MAX. 2.Extraction Force :3.0 N MIN. X - X - 1.No electrical discontinuity of 1μs. 2.No damage, crack or looseness of parts. X - X - 1.Contact resistance: 30 mΩ MAX. 2.Insulation resistance: 500 M MIN. 3.No damage, crack or looseness of parts. 1.Contact resistance: 30 mΩ MAX. 2.Insulation resistance: 1000 M MIN. 3.No damage, crack or looseness of parts. X - X - 1.Contact resistance: 30 mΩ MAX. 2.Insulation resistance: 1000 M MIN. 3.No damage, crack or looseness of parts. 1.Contact resistance: 30 mΩ MAX. 2.Insulation resistance: 1000 M MIN. 3.No damage, crack or looseness of parts. X - X - Construction General Examination Visually and by measuring instrument. Marking According to drawing. Confirmed visually. Electric Characteristics Contact Resistance Millivolt Level Method 20mV MAX, 1mA (DC or 1000Hz). Insulation Resistance 500 V DC. Voltage Proof 650 V AC for 1 min. Mechanical Characteristics Mechanical Operation 50 times insertion and extraction. Mating and unmating force It takes out and inserts with a conformity connector. Vibration Frequency 10 to 55 Hz, single amplitude 0.75 mm, at 10 cycles for 3 direction. Shock Acceleration 490 m/s duration of pulse 11 ms at 3 times for 3 directions. 2 Environmental Characteristics Damp Heat (Steady State) Exposed at 40 ± 2C , humidity 90 to 95 %, 96 h. (After leaving the room temperature for 1 to 2h.) Rapid Change Of Temperature Dry Heat Temperature -55C→ +105C Time 30min→ 30min Under 5 Cycles. (The transferring time of the tank is 2 to 3 MIN) (After leaving the room temperature for 1 to 2h.) Exposed at 105±2C, 96h Cold Exposed at -55±3C, 96h Remarks Note 1:Include the temperature rising by current. Note 2:No condensing Note 3:Apply to the condition of long term storage for unused products before mount on pcb, After mounted on pcb, operating temperature and humidity range is applied for interim storage during transportation. 2 △ COUNT DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE 2 DIS-H-00005270 TS.MIYAKI SZ.ONO 20190912 Unless otherwise specified, refer to IEC 60512. Note QT:Qualification Test AT:Assurance Test FORM HD0011-2-1 X:Applicable Test APPROVED HS.OKAWA 20180529 CHECKED ST.WADA 20180529 DESIGNED TH.SATO 20180528 DRAWN TH.SATO 20180528 DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. ELC-363559-50-00 DF51A-12DP-2DS(50) CL543-5061-0-50 2 1/2 △ Specifications Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. Item Resistance To Soldering Heat Solderability Test method 1)Solder bath method 2 Soldered at solder temperature, 260c for in immersion, duration, 5 s. 2)Manual soldering Soldering iron temperature :270℃, Soldering time :3s. No strength on contact. Soldering temperature : 245C Duration of immersion :soldering, for 5 sec. Note QT:Qualification Test AT:Assurance Test FORM HD0011-2-2 X:Applicable Test Requirements Such as impaired function ,no deformation of case of excessive looseness of the terminals. 2 New uniform coating of solder shall cover minimum of 95  of the surface Being immersed. DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO QT X AT - X - ELC-363559-50-00 DF51A-12DP-2DS(50) CL543-5061-0-50 2 △ 2/2
DF51A-12DP-2DS(50) 价格&库存
很抱歉,暂时无法提供与“DF51A-12DP-2DS(50)”相匹配的价格&库存,您可以联系我们找货
