Applicable standard
Operating
temperature range
Operating
humidity range
Rating
-55C to + 105C(Note 1)
40% to + 80%(Note 2)
Nov.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
Voltage
250V AC/DC
Current
Storage
temperature range
Storage
humidity range
Applicable
AWG 22 to 24 :
3A
AWG 26
2A
AWG 28
1A
UL・CSA
rating
-10C to + 60C(Note 3)
40% to + 70%(Note 3)
connector
Voltage
DF3-*S-2C
30V AC/DC
AWG 24 : 3A
AWG 26 : 2A
AWG 28 : 1A
Current
(Note 4)
Specifications
Item
Test method
Requirements
QT
AT
According to drawing.
X
X
X
X
Construction
General examination
Visually and by measuring instrument.
Marking
Confirmed visually.
Electric characteristics
Contact Resistance
Millivolt Level Method
Insulation resistance
20mV MAX, 1mA (DC or 1000Hz).
30m MAX.
X
500V DC.
1000M MIN.
X
Voltage proof
650V AC for 1 min.
No flashover or breakdown.
X
①
②
①
②
①
②
Contact resistance:
30m MAX.
No damage, crack or looseness of parts.
No electrical discontinuity of 1s.
X
X
X
① Contact resistance:
30m MAX.
② Insulation resistance: 1000M MIN.
③ No damage, crack or looseness of parts.
X
30m MAX.
② Insulation resistance: 500M MIN.
No deformation of case of excessive looseness
of the terminals.
X
X
X
Mechanical characteristics
Mechanical operation
50 times insertions and extractions.
Vibration
Frequency 10 to 55 Hz, single amplitude
0.75 mm, at 2 h, for 3 directions.
Shock
490 m/s2 duration of pulse 11 ms at 3 times for 3
directions.
Environmental characteristics
Rapid change of
temperature
Damp heat
(Steady state)
Resistance to
Soldering heat
Solderability
Temperature -55C→ +85C
Time
30min→ 30min
Under 5 Cycles.
(The transferring time of the tank is 2 to 3 MIN)
(After leaving the room temperature for 1 to 2h.)
Exposed at 40 ± 2 c, 90 to 95 , 96 h.
1) Reflow soldering
Number of reflow cycles : 2 cycles MAX.
Duration above 230C, 60 sec. MAX.
Peak temperature: 250C 10 sec. MAX.
Pre-heat temperature :150 to 180C
Pre-heat time : 90 to 120 sec.
2) Manual soldering
Soldering iron temperature :300C,
Soldering time : 3sec.
No strength on contact.
Soldering temperature :230 ℃
Soldering time :3s.
A new uniform coating of solder shall cover
minimum of 95 of the surface being immersed.
Remarks
Note 1: Include the temperature rising by current.
Note 2: No condensing
Note 3: Apply to the condition of long term storage for unused products before mounted on PCB.
After mounted on PCB board, operating temperature and humidity range is applied for interim storage during transportation.
Note 4: Apply to crimping contact type.
Count
Description of revisions
Designed
Unless otherwise specified, refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
Checked
Approved
HS.OKAWA
18.04.05
Checked
TS.FUKUSHIMA
18.04.05
Designed
TS.KUMAZAWA
18.04.05
Drawn
MK.INOUE
18.04.05
Drawing no.
Specification sheet
Part no.
Hirose electric co., ltd.
Code no.
Date
ELC-369406-54-00
DF3E-*P-2H(54)
CL543
很抱歉,暂时无法提供与“DF3E-3P-2H(54)”相匹配的价格&库存,您可以联系我们找货
