CEA6861
www.VBsemi.com
P-Channel 60-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 60
RDS(on) ()
ID
(A)a
0.058 at VGS = - 10 V
- 6.5
0.065 at VGS = - 4.5 V
- 5.5
Qg (Typ.)
30 nC
• TrenchFET® Power MOSFET
• 100 % UIS Tested
APPLICATIONS
• Load Switch
S
D
G
G
D
D
S
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Symbol
Limit
Drain-Source Voltage
Parameter
VDS
- 60
Gate-Source Voltage
VGS
± 20
TC = 25 °C
Continuous Drain Current (TJ = 150 °C)
TC = 70 °C
TA = 25 °C
Avalanche Current Pulse
Single Pulse Avalanche Energy
Continuous Source-Drain Diode Current
L = 0.1 mH
TC = 25 °C
TA = 25 °C
- 5.2
ID
- 4 .8b
IDM
- 4.1b
- 20
IAS
- 4.5
EAS
10.1
Maximum Power Dissipation
TA = 25 °C
mJ
A
3.5b
10.4a
6.6a
PD
W
2.1b
1.1 b
TA = 70 °C
TJ, Tstg
Operating Junction and Storage Temperature Range
A
6.9a
IS
TC = 25 °C
TC = 70 °C
V
- 6.5 a
TA = 70 °C
Pulsed Drain Current
Unit
- 55 to 150
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum
Steady State
Symbol
RthJA
Typical
Maximum Junction-to-Ambientb
33
40
Maximum Junction-to-Case
Steady State
RthJC
0.98
1.2
Unit
°C/W
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1" x 1" FR4 board.
服务热线:400-655-8788
1
CEA6861
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = - 250 µA
- 60
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS/TJ
VDS Temperature Coefficient
V
68
ID = - 250 µA
mV/°C
VGS(th) Temperature Coefficient
VGS(th)/TJ
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = - 250 µA
- 2.5
V
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
nA
VDS = - 60 V, VGS = 0 V
-1
VDS = - 60 V, VGS = 0 V, TJ = 55 °C
- 10
Gate-Source Leakage
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
VDS =-5 V, VGS = - 10 V
- 5.2
- 1.2
- 25
A
VGS = - 10 V, ID = - 3 A
0.058
VGS = - 4.5 V, ID = - 2 A
0.065
VDS = - 15 V, ID = - 5 A
µA
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
1500
VDS = - 25 V, VGS = 0 V, f = 1 MHz
150
VDS = - 30 V, VGS = - 10 V, ID = - 5 A
VDS = - 30 V, VGS = - 4.5 V, ID = - 5 A
tr
Rise Time
td(off)
Turn-Off Delay Time
f = 1 MHz
VDD = - 2 V, RL = 2 Ω
ID ≅ - 5 A, VGEN = - 10 V, Rg = 1 Ω
tf
Fall Time
38
56
19
30
9
nC
10
td(on)
Turn-On Delay Time
pF
200
5.2
10
15
7
15
70
110
40
60
ns
Drain-Source Body Diode Characteristics
a
IS
Pulse Diode Forward Current
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
TC = 25 °C
- 6.9
- 15
IS = - 3 A
IF = - 5 A, di/dt = 10 A/µs, TJ = 25 °C
A
-1
- 1.5
V
45
68
ns
59
120
nC
29
16
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
CEA6861
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
10
VGS = 10 thru 6 V
8
VGS = 5 V
ID - Drain Current (A)
16
12
8
VGS = 4 V
4
6
4
TC = 125 °C
2
TC = 25 °C
VGS = 3 V
TC = - 55 °C
2
3
4
VDS - Drain-to-SourceVoltage (V)
5
1
2
3
4
VGS - Gate-to-Source Voltage (V)
Output Characteristics
5
Transfer Characteristics
10
100
8
80
gfs - Transconductance (S)
TC = - 55 °C
6
4
TC = 125 °C
2
TC = 25 °C
60
TC = 125 °C
40
TC = 25 °C
TC = - 55 °C
2
3
4
24
36
12
0.09
2000
0.08
1600
0.07
VGS = 4.5 V
0.06
0.05
Ciss
1200
800
400
VGS = 10 V
Coss
0.00
Crss
60
60
Transconductance
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
48
80
On-Resistance vs. Drain Current
100
40
50
VDS - Drain-to-Source Voltage (V)
60
Capacitance
服务热线:400-655-8788
3
CEA6861
www.VBsemi.com
2.0
10
RDS(on) - On-Resistance (Normalized)
ID = 5 A
8
VDS = 20 V
6
VDS = 30 V
4
2
40
60
Qg - Total Gate Charge (nC)
1.7
VGS = 10 V
1.4
VGS = 4.5 V
1.1
0.8
0.5
- 50
ID = 2 A
80
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
Gate Charge
On-Resistance vs. Gate-to-Source Voltage
0.10
100
TJ = 150 °C
IS - Source Current (A)
ID = 2 A
TJ = 25 °C
10
0.08
0.06
0.04
TJ = 150 °C
0.02
TJ = 25 °C
1
0.0
0.00
0.3
0.6
0.9
VSD - Source-to-Drain Voltage (V)
2
4
6
8
Source-Drain Diode Forward Voltage
10
1000
75
ID = 10 mA
72
V(BR)DSS - (V)
I Dav - (A)
100
10
69
66
IAV (A) at TJ = 25 °C
1
63
IAV (A) at TJ = 150 °C
0.1
0.0001
0.001
0.01
T in - (s)
0.1
1
Single Pulse Avalanche Current Capability vs. Time
60
- 50
- 25
50
75
100
125
150
TJ - Temperature (°C)
Drain-Source Breakdown Voltage vs. Junction Temperature
服务热线:400-655-8788
4
CEA6861
www.VBsemi.com
12
0.8
10
V GS(th) Variance (V)
0.5
ID = 250 µA
ID = 1 mA
0.2
8
6
4
- 0.1
2
- 50
- 25
50
75
100
TJ - Temperature(°C)
125
25
Threshold Voltage
100
125
150
Max. Drain Current vs. Case Temperature
14
100
Limited by RDS(on)*
12
10 µs
10
I D - Drain Current (A)
10
Power (W)
75
50
TC - Case Temperature (°C)
8
6
4
100 µs
5
1 ms
10 ms
100 ms, DC
1
2
BVDSS
Limited
TC = 25 °C
Single Pulse
50
75
100
125
0.1
0.1
150
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Power Derating, Junction-to-Case
Safe Operating Area, Junction-to-Case
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10-1
1
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
CEA6861
www.VBsemi.com
Package outline - SOT89
D
A
C
D1
E
H
E1
L
B
e
B1
DIM
e1
Millimeters
Inches
Min
Max
Min
Max
A
1.40
1.60
0.550
0.630
B
0.44
0.56
0.017
B1
0.36
0.48
C
0.35
D
D1
DIM
Millimeters
Inches
Min
Max
Min
Max
E
2.29
2.60
0.090
0.102
0.022
E1
2.13
2.29
0.084
0.090
0.014
0.019
e
1.50 BSC
0.059 BSC
0.44
0.014
0.017
e1
3.00 BSC
0.118 BSC
4.40
4.60
0.173
0.181
H
3.94
4.25
0.155
0.167
1.62
1.83
0.064
0.072
L
0.89
1.20
0.035
0.047
Note: Controlling dimensions are in millimeters. Approximate dimensions are provided in inches
服务热线:400-655-8788
6
CEA6861
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
