2SC2383(RANGE:160-320) 数据手册
2SC2383
TRANSISTOR (NPN)
SOT-89-3L
FEATURE
z
High voltage: VCEO=160V
z
Large continuous collector current capability
1. BASE
3
2
2. COLLECTOR
1
3. EMITTER
MARKING:2383
MAXIMUM RATINGS (TA=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
160
V
VCEO
Collector-Emitter Voltage
160
V
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current -Continuous
1
A
PC
Collector Power Dissipation
0.5
W
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified)
Parameter
Collector-base breakdown voltage
Test
V(BR)CBO
conditions
Min
Max
Unit
IC= 100μA , IE=0
160
V
IC= 10mA, IB=0
160
V
6
V
Collector-emitter breakdown voltage
V(BR)CEO
Emitter-base breakdown voltage
V(BR)EBO
IE= 10μA, IC=0
Collector cut-off current
ICBO
VCB=150V, IE=0
1
μA
Emitter cut-off current
IEBO
VEB=6V, IC=0
1
μA
DC current gain
hFE
VCE=5V, IC=200mA
Collector-emitter saturation voltage
Symbol
100
320
IC=500m A, IB=50mA
VCE(sat)
Base-emitter voltage
VBE
IC=5mA, VCE= 5V
Transition frequency
fT
VCE=5V, IC=200mA
Collector output capacitance
Cob
VCB=10V,IE=0,f=1MHz
0.45
1
V
0.75
V
MHz
pF
pulse test
CLASSIFICATION OF hFE
Rank
O
Y
Range
100-200
160-320
www.fuxinsemi.com
Page 1
Ver2.1
2SC2383
TRANSISTOR (NPN)
Rating and characteristic curves
Static Characteristic
300
(mA)
250
IC
0.7mA
150
0.6mA
0.5mA
100
0.4mA
IC
Ta=100℃
hFE
DC CURRENT GAIN
0.8mA
200
COMMON EMITTER
VCE= 5V
1000
1mA
0.9mA
COLLECTOR CURRENT
hFE
3000
COMMON
EMITTER
Ta=25℃
Ta=25℃
100
10
0.3mA
0.2mA
50
IB=0.1mA
2
3
4
5
COLLECTOR-EMITTER VOLTAGE
VBEsat ——
1000
6
1
0.1
7
IC
VCEsat
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
IC
100
1000
(mA)
IC
β=10
800
Ta=25℃
600
Ta=100 ℃
400
200
1
10
100
COLLECTOR CURREMT
IC
1000
IC
Ta=100 ℃
100
Ta=25℃
10
0.1
1000
1
10
100
COLLECTOR CURREMT
(mA)
VBE
fT
100
IC
1000
(mA)
IC
(MHz)
COMMON EMITTER
VCE=5V
(mA)
10
COLLECTOR CURRENT
1000
β=10
100
TRANSITION FREQUENCY
T =2
5℃
a
T =1
00℃
a
fT
80
IC
COLLECTOR CURRENT
1
VCE (V)
10
1
60
40
COMMON EMITTER
VCE=5V
Ta=25℃
0.1
400
600
800
1000
40
80
1000
Cob/Cib
VCB/VEB
100
CAPACITANCE
C
(pF)
COLLECTOR POWER DISSIPATION
PC (mW)
Ta=25 ℃
Cib
Cob
10
160
IC
200
(mA)
Ta
500
400
300
200
100
REVERSE VOLTAGE
www.fuxinsemi.com
PC
600
f=1MHz
IE=0/IC=0
1
0.1
120
COLLECTOR CURRENT
BASE-EMMITER VOLTAGE VBE (mV)
10
V
30
50
75
AMBIENT TEMPERATURE
(V)
Page 2
100
Ta
125
150
Ver2.1
2SC2383
TRANSISTOR (NPN)
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
2SC2383(RANGE:160-320) 价格&库存
很抱歉,暂时无法提供与“2SC2383(RANGE:160-320)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35634
- 100+0.28169
- 300+0.24436
- 1000+0.21637
- 5000+0.19402
- 10000+0.18274
