B772
B772
    DOESHARE(德芯)
    SOT89-3
B772 数据手册
B772 PNP Transistors General description SOT-89-3L Plastic-Encapsulate Transistors FEATURES • • • Low speed switching Power Dissipation of 500mW High Stability and High Reliability MECHANICAL DATA • • • SOT-89-3L Small Outline Plastic Package Epoxy UL: 94V-0 Mounting Position: Any Marking: B772 Maximum Ratings & Thermal Characteristics TA = 25°C unless otherwise noted Parameters Symbol Value Unit Collector-Base Voltage VCBO -40 V Collector-Emitter Voltage VCEO -30 V Emitter -Base Voltage VEBO -6 V Collector Current-Continuous IC -3 A Collector Power Dissipation PC 500 mW Junction Temperature Tj 150 ℃ Storage Temperature Tstg -55-+150 ℃ Thermal resistance From junction to ambient RθJA 250 ℃/W Electrical Characteristics TA = 25°C unless otherwise noted Parameter Symbols Collector-base breakdown voltage Collector-emitter breakdown voltage Emitter-base breakdown voltage Collector cut-off current Collector cut-off current Emitter cut-off current DC current gain Collector-emitter saturation voltage Base -emitter saturation voltage Transition frequency Test Condition Limits Min Unit Max V(BR)CBO IC=-100uA, IE=0 -40 V V(BR)CEO IC=-10mA, IB=0 -30 V V(BR)EBO IE=-100uA, IC=0 -6 V ICEO VCE=-30V, IB=0 -10 uA ICBO VCB=-40V, IE=0 -1.0 uA IEBO VEB=-6V, IC=0 -1.0 uA hFE(1) VCE=-2V, IC=-1A VCE(sat) IC=-2A, IB=-200mA VBE(sat) IC=-2A, IB=-200mA fT 60 400 -0.50 V -1.50 VCE=-5V, IC=-100mA,f=10MHz V 50 MHz CLASSIFICATION OF hFE(1) RANK R O Y GR RANGE 60-120 100-200 160-320 200-400 www.doeshare.net 1/4 B772 Typical characteristics www.doeshare.net 2/4 B772 SOT-89-3L PACKAGE OUTLINE Plastic surface mounted package Precautions: PCB Design Recommended land dimensions for SOT-89-3 diode. Electrode patterns for PCBs NOTE: 1. Controlling dimension:in millimeters. 2. General tolerance:±0.05mm. 3. The pad layout is for reference purposes only. www.doeshare.net 3/4 B772 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net 4/4
很抱歉,暂时无法提供与“B772”相匹配的价格&库存,您可以联系我们找货
