N-Ch 100V Fast
Switching
MOSFETs
60N02
60N02
4606A
S8N10
N-Ch
20V Fast
Switching MOSFETs
20N02
20N02
Product Summary
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Description
The S8N10 is the high cell density trenched
BVDSS
RDSON
ID
100V
110mΩ
6.5A
SOT89-3L Pin Configuration
N-ch MOSFETs, which provides excellent
RDSON and efficiency for most of the small
power switching and load switch applications.
The S8N10 meets the RoHS and Green
Product requirement with full function reliability
approved.
Absolute Maximum Ratings
Symbol
VDS
VGS
ID@TA=25℃
01
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current, VGS @ 10V1
Rating
100
±20
Unit
V
V
A
A
A
ID@TA=70℃
IDM
Pulsed Drain Current2
6.5
3.2
12
PD@TA=25℃
Total Power Dissipation3
2
W
TSTG
TJ
Storage Temperature Range
Operating Junction Temperature Range
-55 to 150
-55 to 150
1
N-Ch 100V Fast
Switching
MOSFETs
60N02
S8N10
60N02
4606A
N-Ch
20V Fast
Switching MOSFETs
20N02
20N02
Electrical Characteristics (TJ =25 ℃ unless otherwise specified)
Symbol
Off Characteristic
Parameter
V(BR)DSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
Gate to Body Leakage Current
IGSS
On Characteristics note3
VGS(th)
Gate Threshold Voltage
Static Drain-Source On-Resistance note2
R DS(on)
Dynamic Characteristics note4
C iss
Test condition
Min.
Typ.
Max.
100
110
V
VDS = 0V, VGS = ±20V
1
μA
±100
nA
VDS = VGS, ID = 250μA
1
1.95
115
3
140
V
mΩ
206
28.9
1.4
4.3
1.5
1.1
pF
VGS = 0V, ID = 250μA
VDS = 100V, VGS = 0V
VGS = 10V, ID = 3A
Input Capacitance
C oss
Output Capacitance
C rss
Qg
Reverse Transfer Capacitance
Total Gate Charge
Gate-Source
Charge
Qgs
Gate-Drain(“Miller”) Charge
Qgd
Switching Characteristics note4
td(on)
Turn-On Delay Time
tr
td(off)
Turn-Off Delay Time
Turn-On Rise Time
VDS = 50V, VGS = 0V, f = 1.0MHz
IS
VSD
VDS = 50V, ID = 3A, VGS = 10V
VDD = 50V, IDS=3A RG = 2Ω,
VGEN = 10V
Turn-Off Fall Time
tf
Drain-Source Diode Characteristics and Maximum Ratings
ISM
14.7
3.5
20.9
2.7
Maximum Continuous Drain to Source Diode Forward Current note2
Maximum Pulsed Drain to Source Diode Forward Current
Drain to Source Diode Forward Voltage note3 VGS = 0V, IS =3A
32.1
39.4
2.1
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Time Charge
Qrr
Peak Reverse Recovery Current
Irrm
VGS = 0V, IF = 3A, di/dt =100A/μs
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤2%.
4. Guaranteed by design, not subject to production 5. VDD=50 V, RG=50 Ω, L=0.3 mH, starting Tj=25 °C
02
Units
pF
pF
nC
nC
nC
ns
ns
ns
ns
6.5
12
1.3
A
V
A
ns
nC
A
N-Ch 100V Fast
Switching
MOSFETs
60N02
60N02
4606A
S8N10
N-Ch
20V Fast
Switching MOSFETs
20N02
20N02
Typical Electrical and Thermal Characteristics (Curves)
Figure1: Output Characteristics
Figure 3:Forward Characteristics of Reverse
Figure 5: RDS(ON) vs. ID
03
Figure 2: Typical Transfer Characteristics
Figure 4:RDS(ON) vs. VGS
Figure 6:Normalized RDS(on) vs. Temperature
N-Ch 100V Fast
Switching
MOSFETs
60N02
60N02
4606A
S8N10
N-Ch
20V Fast
Switching MOSFETs
20N02
20N02
Typical Performance Characteristics
Figure 7: Capacitance Characteristics
04
Figure 8: Gate Charge Characteristics
N-Ch 100V Fast
Switching
MOSFETs
S8N10
60N02
60N02
4606A
N-Ch
20V Fast
Switching MOSFETs
20N02
20N02
SOT-89-3L Package Information
05
很抱歉,暂时无法提供与“S8N10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36116
- 100+0.28858
- 300+0.25229
- 1000+0.22508
- 5000+0.20326
- 10000+0.19246
