D882
D882
    HXY(华轩阳)
    SOT89-3
    此款SOT-89封装的高性能NPN型三极管,具有30V高耐压VCEO及3A大电流集电极能力,放大倍数范围160至320,适用于中等电压、大电流环境下的开关与线性放大应用,是电子设备高效能电路设计的理想...
D882 数据手册
HUAXUANYANG D882 HXY ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors FEATURES z z Collector Current: IC=3A Power Dissipation of 500mw E C B SOT89-3L Package Marking and Ordering Information Pack Product ID D882 SOT89-3L Marking D882 C Qty(PCS) 1000 B E MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Parameter Symbol Limit Unit Collector-Base Voltage VCBO 40 V Collector-Emitter Voltage VCEO 30 V Emitter-Base Voltage VEBO 5 V Collector Current IC 3 A Collector Power Dissipation PC 500 mW Thermal Resistance From Junction To Ambient RΘJA 250 ℃/W Junction Temperature Tj 150 ℃ Storage Temperature Tstg Shenzhen HuaXuanYang Electronics CO.,LTD -55~+150 ℃ www.hxymos.com HUAXUANYANG D882 HXY ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC = 100μA, IE=0 40 V Collector-emitter breakdown voltage V(BR)CEO IC = 10mA, IB=0 30 V Emitter-base breakdown voltage V(BR)EBO IE= 100μA, IC=0 6 V Collector cut-off current ICBO VCB= 40V, IE=0 1 µA Collector cut-off current ICEO VCE= 30V, IB=0 10 µA Emitter cut-off current IEBO VEB= 6V, IC=0 1 µA hFE(1) VCE=2V, IC= 1A hFE(2) VCE=2V, IC= 100mA DC current gain 160 320 32 Collector-emitter saturation voltage VCE(sat) IC= 2A, IB= 0.2 A 0.5 V Base-emitter saturation voltage VBE(sat) IC= 2A, IB= 0.2 A 1.5 V Transition frequency fT VCE= 5V , Ic=0.1A f =10MHz 50 MHz Typical Characteristics Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD www.cj-elec.com Shenzhen HuaXuanYang Electronics CO.,LTD D882 NPN Plastic-Encapsulate Transistors A,Jun,2014 www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD SOT 8 9 -3L D882 NPN Plastic-Encapsulate Transistors Package Outline Dimensions Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG D882 HXY ELECTRONICS CO.,LTD NPN Plastic-Encapsulate Transistors Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
很抱歉,暂时无法提供与“D882”相匹配的价格&库存,您可以联系我们找货
