HXY
BCX54,BCX55,BCX56
ELECTRONICS CO.,LTD
NPN Plastic-Encapsulate Transistors
HUAXUANYANG
FEATURES
z
z
PNP Complements to BCX51,BCX52,BCX53
Low Voltage
E
C
B
SOT89-3L
Package Marking and Ordering Information
Pack
Product ID
Qty(PCS)
BCX54
SOT89-3L
1000
BCX55
SOT89-3L
1000
BCX56
SOT89-3L
1000
63-250
63-160
C
B
100-250
E
Marking
Product ID
BCX54
BA
BC
BD
BCX55
BE
BG
BM
BCX56
BH
BK
BL
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Parameter
Symbol
BCX54
Collector-Base Voltage
BCX55
VCBO
V
45
VCEO
BCX56
Emitter-Base Voltage
60
100
BCX54
BCX55
Unit
45
BCX56
Collector-Emitter Voltage
Limit
60
V
80
VEBO
5
V
Collector Current
IC
1
A
Collector Power Dissipation
PC
500
mW
Thermal Resistance From Junction To Ambient
RΘJA
250
℃/W
Junction Temperature
Tj
150
Storage Temperature
Tstg
Shenzhen HuaXuanYang Electronics CO.,LTD
-55~+150
www.hxymos.com
HXY
BCX54,BCX55,BCX56
ELECTRONICS CO.,LTD
HUAXUANYANG
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Collector-base breakdown voltage
Collector-emitter breakdown voltage
Emitter-base breakdown voltage
Symbol
V(BR)CBO
V(BR)CEO*
T est
conditions
IC=100µA,IE=0
IC=10mA,IB=0
Min
BCX54
45
BCX55
60
BCX56
100
BCX54
45
BCX55
60
BCX56
80
Typ
Max
Unit
V
V
V(BR)EBO
IE=10µA,IC=0
Collector cut-off current
ICBO
VCB=30V,IE=0
0.1
µA
Emitter cut-off current
IEBO
VEB=5V,IC=0
0.1
µA
hFE(1)*
VCE=2V, IC=5mA
40
hFE(2)*
VCE=2V, IC=150mA
63
hFE(3)*
VCE=2V, IC=0.5A
25
VCE(sat)*
IC=0.5A,IB=50mA
0.5
V
Base -emitter voltage
VBE*
VCE=2V, IC=0.5A
1
V
Transition frequency
fT
DC current gain
Collector-emitter saturation voltage
VCE=5V,IC=10mA, f=100MHz
5
V
250
130
MHz
* Pulse Test
Typical Characteristics
www.hxymos.com
HXY
BCX54,BCX55,BCX56
ELECTRONICS CO.,LTD
HUAXUANYANG
www.hxymos.com
HXY
BCX54,BCX55,BCX56
ELECTRONICS CO.,LTD
HUAXUANYANG
SOT 8 9 -3L
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
Package Outline Dimensions
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
www.hxymos.com
HXY
BCX54,BCX55,BCX56
ELECTRONICS CO.,LTD
HUAXUANYANG
Attention
■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle
applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications
whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG
ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein
in such applications.
■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products
specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein.
■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance,
characteristics, and functions of the described products in the independent state, and are not guarantees of the performance,
characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and
states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the
■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with some probability. It is possible that these probabilistic failures could
give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other
property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures
include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design.
■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein
are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the
export license from the authorities concerned in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including
photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production.
HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding
its use or any infringements of intellectual property rights or other rights of third parties.
■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc.
When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use.
www.hxymos.com
