HUAXUANYANG
HXY
BCP51,52,53
ELECTRONICS CO.,LTD
PNP Plastic-Encapsulate Transistors
FEATURES
z
z
Collector Current: IC=-1A
Power Dissipation of 1.5w
E
C
B
SOT89-3L
Package Marking and Ordering Information
Pack
Product ID
Marking
C
Qty(PCS)
BCP51
SOT89-3L
BCP51
1000
BCP52
SOT89-3L
BCP52
1000
BCP5
BCP53
SOT89-3L
BCP53
1000
B
E
MAXIMUM
X
RATINGS (Ta=25℃ unless otherwise noted)
Parameter
Symbol
BCP52
Unit
-45
BCP51
Collector-Base Voltage
Limit
VCBO
-60
BCP53
-100
BCP51
-45
V
VCEO
-60
-80
V
VEBO
-5
V
Collector Current
IC
-1
A
Collector Power Dissipation
PC
1.5
W
Thermal Resistance From Junction To Ambient
RΘJA
94
℃/W
Junction Temperature
Tj
150
Storage Temperature
Tstg
Collector-Emitter Voltage
Emitter-Base Voltage
Shenzhen HuaXuanYang Electronics CO.,LTD
BCP52
BCP53
-55~+150
www.hxymos.com
HUAXUANYANG
HXY
BCP51,52,53
ELECTRONICS CO.,LTD
Ta =25 unless otherwise specified
Symbol
Parameter
Collector-base breakdown voltage
Min
V(BR)CBO
IC=- 0.1mA,IE=0
-60
BCP53
-100
BCP51
-45
BCP52
V(BR)CEO
IC= -10mA,IB=0
Collector cut-off current
IE = -10μA,IC 0
V(BR)EBO
Collector-emitter saturation voltage
V
-60
V
-5
VCB= -30 V, IE 0
ICBO=
hFE(1)=
VCE=-2V, IC -5mA
DC current gain
Unit
-80
BCP53
Base-emitter breakdown voltage
Max
-45
BCP51
BCP52
Collector-emitter breakdown voltage
Test conditions
-100
VCE= -2V, IC=-150m A
63
hFE(3)
VCE= -2V, IC=-500m A
25
VCE(sat) =
IC=-500mA,IB -50mA
VBE
Transition frequency
fT
VCE=-2V, IC=-500m A
= 100MHz
VCE=-10V,I
=C -50mA,f
nA
25
hFE(2)
Base-emitter voltage
V
100
250
-0.5
V
-1
V
MHz
Typical Characteristics
www.hxymos.com
HUAXUANYANG
HXY
ELECTRONICS CO.,LTD
BCP51,52,53
www.hxymos.com
HUAXUANYANG
HXY
ELECTRONICS CO.,LTD
SOT 8 9 -3L
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
BCP51,52,53
Package Outline Dimensions
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
www.hxymos.com
HUAXUANYANG
HXY
BCP51,52,53
ELECTRONICS CO.,LTD
Attention
■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle
applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications
whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG
ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein
in such applications.
■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products
specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein.
■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance,
characteristics, and functions of the described products in the independent state, and are not guarantees of the performance,
characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and
states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the
■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with some probability. It is possible that these probabilistic failures could
give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other
property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures
include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design.
■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein
are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the
export license from the authorities concerned in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including
photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production.
HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding
its use or any infringements of intellectual property rights or other rights of third parties.
■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc.
When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use.
www.hxymos.com
