ATM2320KNSQ
20V N-Channel Enhancement Mode MOSFET
Descriptions
The ATM2320KNSQ is N-Channel logic enhancement mode power field effect
transistor which is produced using high cell density advanced trench technology
to provide excellent RDS(ON).
This high density process is especially tailored to minimize on-state resistance.
The device is particularly suited for low voltage application, and low in-lin power
loss are needed in a very small outline surface mount package.
Features
RDS(ON) = 14mΩ(typ.) @ VGS=4.5V
RDS(ON) = 18mΩ(typ.) @ VGS=2.5V
Super high design for extremely low RDS(ON)
Exceptional on-resistance and Maximum DC current capability
This is a full RoHS compliance
SOP89-3 package design
ESD Rating:2000V HBM
Applications
Power Management in Note Book
Portable Equipment
Battery Powered System
Absolute Maximum Ratings (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Maximum
Units
Drain-Source Voltage
VDS
V
Gate-Source Voltage
VGS
±8
V
ID
5
A
Drain Current-Pulsed
IDM
30
A
Power Dissipation
PD
1.5
W
Operating Junction and Storage Temperature Range
TJ,TSTG
150, -55 ~ +150
Parameter
Symbol
Drain Current-Continuous
Maximum Junction-to-Ambient
t≤10s
Steady-State
Maximum Junction-to-Lead
Steady-State
RθJA
RθJL
AGERTECH MICROELECTRONICS
Subsidiary of Sino-Talent International Holdings Ltd.
1/5
Typ
Max
Unit
64
83
℃/W
89
120
℃/W
53
70
℃/W
Dated:03/2020
Rev: 1.0
ATM2320KNSQ
Electrical Characteristics(Ta=25℃ unless otherwise specified)
Parameter
Symbol
Static Parameters
Drain-Source breakdown voltage
BVDSS
Zero Gate voltage drain current
IDSS
Gate-Body leakage current
IGSS
VGS(th)
Gate Threshold voltage
ID(ON)
On state drain current
Static Drain-source on-resistance
RDS(on)
Test Conditions
ID=250uA,VGS=0V
VDS=16V,VGS=0V
VDS=0V,VGS=±4.5V
Min
Typ
Max
Unit
V
1
uA
±1
uA
±10
uA
VDS=0V,VGS=±8V
VGS=VDS,ID=250uA
0.4
0.6
1
V
VGS=4.5V,VDS=5V
30
A
VGS=4.5V,ID=5A
14
25
mΩ
VGS=2.5V,ID=3A
18
35
mΩ
Forward Transconductance
gFS
VDS=5V,ID=5A
31
S
Diode Forward Voltage
VSD
Is=1A,VGS=0V
0.7
1.3
V
IS
2.5
A
Input Capacitance
Ciss
1120
pF
Output capacitance
Coss
195
pF
Reverse transfer capacitance
Crss
155
pF
4.0
Ω
16
nC
1.7
nC
6.8
nC
7.2
ns
11
ns
64
ns
32
ns
Maximum Body-Diode Continuous
Current
Dynamic Parameters
Gate resistance
Rg
VGS=0V,VDS=10V,f=1MHZ
VGS=0V,VDS=0V,f=1MHZ
Switching Parameters
Total Gate charge
Qg
Gate Source charge
Qgs
Gate Drain charge
Qgd
Turn-on delaytime
tD(on)
Turn-on rise time
tr
Turn-off delaytime
tD(off)
VGS=4.5V,VDS=10V,ID=5A
VGS=5V,VDD=10V,RL=1.35Ω,
RGEN=3Ω
Turn-off fall time
tf
Body Diode reverse recovery Time
trr
IF=5A,dI/dt=100A/us
32
ns
Body diode reverse recovery charge
Qrr
IF=5A,dI/dt=100A/us
12
nC
Notes:
1. Pulse test: pulse width
很抱歉,暂时无法提供与“ATM2320KNSQ”相匹配的价格&库存,您可以联系我们找货
