CXT5551
CXT5551
    SLKOR(萨科微)
    SOT89-3
CXT5551 数据手册
CXT5551 Plastic-Encapsulate Transistors Features C • Switching and amplification in high voltage Applications such as telephony • Low current(max. 600mA) • High voltage(max.180V) B C E Schematic diagram SOT-89-3L top view Application C • High voltage amplifier application 1G6 B E C Marking and pin assignment Maximum Ratings(Ta=25℃ unless otherwise noted) Symbol VCBO Parameter VCEO Collector-Base Voltage Collector-Emitter Voltage VEBO Emitter-Base Voltage Value Unit 180 160 V V 6 V IC Collector Current 600 mA PC Collector Power Dissipation 500 mW -55~+150 °C TJ,Tstg www.slkormicro.com Operation Junction and Storage Temperature Range 1 CXT5551 Electrical Characteristics (TJ=25℃ unless otherwise noted) Symbol Parameter V(BR)CBO Collector-base breakdown voltage Condition IC=100μA, IE=0 V(BR)CEO Collector-emitter breakdown voltage IC=1mA, IB=0 Min Typ Max Unit 180 -- -- V 160 -- -- V V(BR)EBO Emitter-base breakdown voltage IE=10μA, IC=0 6 -- -- V ICBO Collector cut-off current VCB=120V , IE=0 -- -- 50 nA IEBO Emitter cut-off current VCB= 4V , IC=0 -- -- 50 nA VCE=5V, IC= 1mA 80 -- -- VCE=5V, IC= 10mA 100 -- 300 VCE=5V, IC= 50mA 30 -- -- IC=10 mA, IB= 1mA -- -- 0.15 V IC=50 mA, IB= 5mA -- -- 0.2 V IC=10 mA, IB= 1mA -- -- 1 V IC=50 mA, IB= 5mA -- -- 1 V 100 -- -- MHz -- -- 35 pF -- -- 35 dB hFE VCE(sat) VBE(sat) DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage fT Transition frequency Cob Collector output capacitance NF Noise figure VCE=10V, IC= 10mA f=100MHz VCB=10V,IE=0,f=1MHz VCE=5V,Ic=0.2mA, f=10Hzto15.7KHZ,Rs=10Ω Typical Operating Characteristics www.slkormicro.com 2 CXT5551 www.slkormicro.com 3 CXT5551 SOT-89-3L Package information Symbol A b b1 c D D1 E E1 e e1 L www.slkormicro.com Dimensions in Millimeters(mm) Min Max 1.400 1.600 0.320 0.520 0.400 0.580 0.350 0.440 4.400 4.600 1.550 REF 2.300 2.600 3.940 4.250 1.500 TYP 3.000 TYP 0.900 1.200 4 Dimensions in Inches Min Max 0.055 0.063 0.013 0.020 0.016 0.023 0.014 0.017 0.173 0.181 0.061 REF 0.091 0.102 0.155 0.167 0.060 TYP 0.118 TYP 0.035 0.047
CXT5551 价格&库存
很抱歉,暂时无法提供与“CXT5551”相匹配的价格&库存,您可以联系我们找货
