FDD5614P
FDD5614P
    MSKSEMI(美森科)
    TO-252-2(DPAK)
    MOSFETs P-沟道 60V 14A TO-252-2(DPAK)
FDD5614P 数据手册
FDD5614P Product specification FDD5614P General Description BVDSS These P-Channel enhancement mode power field effect transistors are using trench DMOS technology. This advanced technology has been especially tailored to minimize on-state resistance, provide superior switching performance, and withstand high energy pulse in the avalanche and commutation mode. These devices are well suited for high efficiency fast switching applications. RDSON -60V Features ID -15A 75mΩ  -60V,-15A, RDS(ON) =75mΩ@VGS = -10V  Improved dv/dt capability  Fast switching  100% EAS Guaranteed  Green Device Available Applications  Motor Drive  Power Tools  LED Lighting Reference News PACKAGE OUTLINE P-Channel MOSFET Marking D MSKSEMI G FDD5614P S TO-252 Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter Rating Units VDS Drain-Source Voltage -60 V VGS Gate-Source Voltage ±20 V Drain Current - Continuous (TC=25℃) -15 A Drain Current - Continuous (TC=100℃) -11 A Pulsed1 -45 A 40 W 0.16 W/℃ ID Drain Current - IDM Power Dissipation (TC=25℃) PD Power Dissipation - Derate above 25℃ TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Characteristics Symbol Parameter Typ. Max. Unit RθJA Thermal Resistance Junction to ambient --- 62 ℃/W RθJC Thermal Resistance Junction to Case --- 6.1 ℃/W Copyright© Msksemi Incorporated www.msksemi.com FDD5614P Electrical Characteristics (TJ=25 Off Characteristics Symbol BVDSS ℃, unless otherwise noted) Parameter Drain-Source Breakdown Voltage △BV DSS /△T J BVDSS Temperature Coefficient IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current Conditions Min. Typ. Max. Unit VGS=0V , ID=-250uA -60 --- V Reference to 25℃ , ID=-1mA --- --- -0.05 --- V/℃ VDS=-60V , VGS=0V , TJ=25℃ --- --- -1 uA VDS=-48V , VGS=0V , TJ=125℃ --- --- -10 uA --- --- ±100 nA VGS=-10V , ID=-5A --- 75 100 mΩ VGS=-4.5V , ID=-4A --- 100 130 mΩ -1.0 -1.6 -2.5 V --- 5 --- mV/℃ --- 8.5 --- S --- 16.4 --- --- 2.8 --- VGS= ±20V , VDS=0V On Characteristics RDS(ON) VGS(th) △V GS(th) gfs Static Drain-Source On-Resistance Gate Threshold Voltage VGS(th) Temperature Coefficient Forward Transconductance VGS=VDS , ID=-250uA VDS=-10V , ID=-6A Dynamic and switching Characteristics Qg Total Gate Charge3 , 4 Qgs Gate-Source Charge3 , 4 Qgd Gate-Drain Charge3 , 4 --- 3.6 --- Td(on) Turn-On Delay Time3 , 4 --- 8.3 --- VDD=-30V , VGS=-10V , --- 29.6 --- RG=6Ω ID=-1A --- 51.7 --- --- 15.6 --- --- 870 --- --- 70 --- --- 42 --- --- 16 --- Ω Min. Typ. Max. Unit --- --- -15 A --- --- -30 A --- --- -1.2 V Tr Td(off) Tf Rise Time3 , 4 Turn-Off Delay Time3 , 4 Fall Time3 , 4 Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Rg VDS=-30V , VGS=-10V , ID=-6A Gate resistance VDS=-30V , VGS=0V , F=1MHz VGS=0V, VDS=0V, F=1MHz Drain-Source Diode Characteristics and Maximum Ratings Symbol Parameter Conditions IS Continuous Source Current ISM Pulsed Source Current VSD Diode Forward Voltage VG=VD=0V , Force Current VGS=0V , IS=-1A , TJ=25℃ nC ns pF Note : 1.Repetitive Rating : Pulsed width limited by maximum junction temperature. 2.VDD=25V,VGS=10V,L=0.1mH,IAS=11A.,RG=25Ω,Starting TJ=25℃ . 3.The data tested by pulsed , pulse width ≤ 300us , duty cycle ≤ 2%. 4.Essentially independent of operating temperature. Copyright© Msksemi Incorporated www.msksemi.com TC , Case Temperature (℃) Continuous Drain Current vs. TC Fig.5 Fig.2 Normalized RDSON vs. TJ Fig.4 Qg , Gate Charge (nC) Gate Charge Waveform -ID , Continuous Drain Current (A) TJ , Junction Temperature (℃) Normalized Vth vs. TJ Normalized Thermal Response Fig.3 TJ , Junction Temperature (℃) -VGS , Gate to Source Voltage (V) Normalized Gate Threshold Voltage Fig.1 Normalized On Resistance -ID , Continuous Drain Current (A) FDD5614P Square Wave Pulse Duration (s) Normalized Transient Impedance Copyright© Msksemi Incorporated Fig.6 -VDS , Drain to Source Voltage (V) Maximum Safe Operation Area www.msksemi.com FDD5614P VDS 90% 10% VGS Td(on) Tr Ton Fig.7 Td(off) Tf Toff Switching Time Waveform Copyright© Msksemi Incorporated www.msksemi.com FDD5614P PACKAGE MECHANICAL DATA D A D1 c V L3 h E φ L4 L A1 L2 L1 D2 b e θ Symbol A A1 b c D D1 D2 E e L L1 L2 L3 L4 Φ θ h V Dimensions In Millimeters Min. Max. 2.200 2.400 0.000 0.127 0.635 0.770 0.460 0.580 6.500 6.700 5.100 5.460 4.830 REF. 6.000 6.200 2.186 2.386 9.712 10.312 2.900 REF. 1.400 1.700 1.600 REF. 0.600 1.000 1.100 1.300 0° 8° 0.000 0.300 5.250 REF. Dimensions In Inches Min. Max. 0.087 0.094 0.000 0.005 0.025 0.030 0.018 0.023 0.256 0.264 0.201 0.215 0.190 REF. 0.236 0.244 0.086 0.094 0.382 0.406 0.114 REF. 0.055 0.067 0.063 REF. 0.024 0.039 0.043 0.051 0° 8° 0.000 0.012 0.207 REF. Suggested Pad Layout REELSPECIFICATION P/N FDD5614P Copyright© Msksemi Incorporated PKG QTY TO-252 2500 www.msksemi.com FDD5614P Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
FDD5614P 价格&库存
很抱歉,暂时无法提供与“FDD5614P”相匹配的价格&库存,您可以联系我们找货
FDD5614P
    • 5+1.64541
    • 50+1.32921
    • 150+1.19372
    • 500+0.98629
    库存:75
