NSI1312D-DSPR
NSI1312D-DSPR
    NOVOSENSE(纳芯微)
    SOP8_150MIL
    隔离放大器 3KV SOP8_150MIL
NSI1312D-DSPR 数据手册
NSI1312 High Reliability Reinforced/Basic Isolated Amplifier Datasheet (EN) 1.3 Key Features  Up to 5000VRMS Insulation Voltage  ±1.2V Linear Input Voltage Range  Offset Drift: ±20μV/°C (Max)  Gain Error: ±0.3% (Max)  Gain Error Drift: ±40ppm/°C (Max)  Nonlinearity: ±0.05% (Max)  Nonlinearity Drift: ±1ppm/°C (Typ)  SNR: 78dB (Typ)  SOP8 narrow body (SOP8 150mil)  UL recognition:  SOW8: 5000Vrms for 1 minute per UL1577  SOP8: 3000Vrms for 1 minute per UL1577  CQC certification per GB4943.1  CSA component notice 5A  DIN EN IEC 60747-17 (VDE 0884-17) Applications  AC motor controls  Power and solar inverters  Uninterruptible Power Suppliers  Automotive onboard chargers Device Information Part Number NSI1312x-DSWVR Package SOW8(300mil) Body Size 5.85mm × 7.50mm NSI1312x-DSPR SOP8(150mil) 4.90mm × 3.90mm Functional Block Diagrams VDD1  Excellent DC Performance: Offset Error: ±2.5mV (Max) SOW8 wide body (SOP8 300mil) Safety Regulatory Approvals  Fixed Gain : 1   VDD2 VDD1 detection Reference INP Σ-Δ modulator INN  RX Retiming and 4thOrder Active Low-Pass Filter OUTP OUTN Reference Oscillator GND1 GND2 Figure 1. NSI1312D Block Diagram VDD1 VDD2 VDD1 detection Reference INP  High CMTI: 150kV/μs (Typ)  System-Level Diagnostic Features: TX Isolation Barrier NSI1312 is a cost-effective isolated amplifier with output separated from input based on the NOVOSENSE capacitive isolation technology Adaptive OOK®. The device has a linear differential input signal range of ±1.2V (±1.5V fullscale). The high input impedance of NSI1312 makes it highly suitable for connection to high-voltage resistive dividers or other voltage signal sources with high output resistance. The device has a fixed gain of 1 and provides differential analog output version (NSI1312D) and single-ended analog output version (NSI1312S) option. The low offset and gain drift ensure the accuracy over the entire temperature range. The high common-mode transient immunity ensures that the device is able to provide accurate and reliable measurements even in the presence of high-power switching such as in motor control applications. The fail-safe function (missing VDD1 detection) simplifies system-level design and diagnostics.  RoHS-Compliant Packages: Σ-Δ modulator INN TX Isolation Barrier Product Overview RX Oscillator Retiming and 4thOrder Active Low-Pass Filter OUT Reference REFIN VDD1 monitoring  Operation Temperature: -40°C~125°C Copyright © 2023, NOVOSENSE GND1 GND2 Figure 2. NSI1312S Block Diagram Page 1 NSI1312 Datasheet (EN) 1.3 INDEX 1. PIN CONFIGURATION AND FUNCTIONS............................................................................................................................. 3 2. ABSOLUTE MAXIMUM RATINGS ......................................................................................................................................... 5 3. ESD RATINGS ..................................................................................................................................................................... 5 4. RECOMMENDED OPERATING CONDITIONS ....................................................................................................................... 5 5. THERMAL INFORMATION ................................................................................................................................................... 5 6. SPECIFICATIONS ................................................................................................................................................................ 6 6.1. 6.2. 6.3. 6.4. ELECTRICAL CHARACTERISTICS....................................................................................................................................... 6 POWER RATING CHARACTERISTICS .................................................................................................................................. 7 TYPICAL PERFORMANCE CHARACTERISTICS ...................................................................................................................... 8 PARAMETER MEASUREMENT INFORMATION .................................................................................................................... 11 7. HIGH VOLTAGE FEATURE DESCRIPTION .......................................................................................................................... 11 7.1. 7.2. 7.3. INSULATION AND SAFETY RELATED SPECIFICATIONS ......................................................................................................... 11 INSULATION CHARACTERISTICS..................................................................................................................................... 12 REGULATORY INFORMATION ......................................................................................................................................... 13 8. FUNCTION DESCRIPTION ................................................................................................................................................ 14 8.1. 8.2. 8.3. OVERVIEW ................................................................................................................................................................ 14 ANALOG INPUT .......................................................................................................................................................... 15 ANALOG OUTPUT ....................................................................................................................................................... 15 9. APPLICATION NOTE ......................................................................................................................................................... 17 9.1. 9.2. 9.3. TYPICAL APPLICATION CIRCUIT .................................................................................................................................... 17 SENSE RESISTOR SELECTION ....................................................................................................................................... 17 PCB LAYOUT ............................................................................................................................................................ 18 10. PACKAGE INFORMATION ............................................................................................................................................... 18 11. ORDERING INFORMATION ............................................................................................................................................. 21 12. DOCUMENTATION SUPPORT ......................................................................................................................................... 21 13. TAPE AND REEL INFORMATION ..................................................................................................................................... 22 14. REVISION HISTORY ........................................................................................................................................................ 24 Copyright © 2023, NOVOSENSE Page 2 NSI1312 Datasheet (EN) 1.3 1. Pin Configuration and Functions VDD1 1 INP 2 INN 3 GND1 4 NSI1312D TOP VIEW 8 VDD2 7 OUTP 6 OUTN 5 GND2 Figure 1.1 NSI1312D Package (SOW8 and SOP8) Table 1.1 NSI1312D Pin Configuration and Description NSI1312D PIN NO. SYMBOL FUNCTION 1 VDD1 Power supply for isolator input side (3.0V to 5.5V) 2 INP Positive analog input 3 INN Negative analog input 4 GND1 Ground 1, the ground reference for input side 5 GND2 Ground 2, the ground reference for output side 6 OUTN Negative output 7 OUTP Positive output 8 VDD2 Power supply for isolator output side (3.0V to 5.5V) Copyright © 2023, NOVOSENSE Page 3 NSI1312 Datasheet (EN) 1.3 VDD1 1 INP 2 INN 3 GND1 4 NSI1312S TOP VIEW 8 VDD2 7 OUT 6 REFIN 5 GND2 Figure 1.2 NSI1312S Package (SOW8 and SOP8) Table 1.2 NSI1312S Pin Configuration and Description NSI1312S PIN NO. SYMBOL FUNCTION 1 VDD1 Power supply for input side (3.0V to 5.5V) 2 INP Positive analog input 3 INN Negative analog input 4 GND1 Ground 1, the ground reference for input side 5 GND2 Ground 2, the ground reference for output side 6 REFIN External Reference Input 7 OUT Output 8 VDD2 Power supply for output side (3.0V to 5.5V) Copyright © 2023, NOVOSENSE Page 4 NSI1312 Datasheet (EN) 1.3 2. Absolute Maximum Ratings Parameters Symbol Min VDD1, VDD2 -0.3 6.5 V INP, INN GND1-6 VDD1+0.5 V REFIN GND2-0.5 VDD2+0.5 V OUTP, OUTN, OUT GND2-0.5 VDD2+0.5 V Output current per Output Pin Io -10 10 mA Junction Temperature TJ -40 150 ℃ Storage Temperature TSTG -55 150 ℃ Power Supply Voltage Input Voltage Output Voltage Typ Max Unit 3. ESD Ratings Parameters Electrostatic discharge Test Condition Value Unit Human body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) ±4.0 kV Charged device model (CDM), per JEDEC specification JESD22-C101(2) ±1.0 kV (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 4. Recommended Operating Conditions Parameters Symbol Min Typ Max Unit Input side Power Supply VDD1 3.0 5.0 5.5 V Output side Power Supply VDD2 3.0 3.3 5.5 V Differential input voltage before clipping output VClipping Linear differential input full scale voltage VFSR -1.2 1.2 V Operating common-mode input voltage VCM -0.8 0.8 V Operating Ambient Temperature TA -40 125 ℃ ±1.5 V 5. Thermal Information Parameters Symbol SOW8 SOP8 Unit Junction–to-ambient thermal resistance RθJA 86 137.7 °C/W Junction-to-case (top) thermal resistance RθJC(top) 28 54.9 °C/W Junction-to-board thermal resistance RθJB 42 71.7 °C/W Junction–to-top characterization parameter ΨJT 4 12 °C/W Junction-to-board characterization parameter ΨJB 42 46 °C/W Copyright © 2023, NOVOSENSE Page 5 NSI1312 Datasheet (EN) 1.3 6. Specifications 6.1. Electrical Characteristics (AVDD = 3.0V ~ 5.5V, DVDD = 3.0V ~ 5.5V, INP = -1.2V to +1.2V, and INN = AGND = 0V, TA = -40°C to 125°C. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 3.3V, TA = 25°C.Output characteristics is based on OUTP-OUTN for NSI1312D, is based on OUT-REFIN for NSI1312S.) Parameters Symbol Min Typ Max Unit Input side supply voltage VDD1 3.0 5.0 5.5 V Output side supply voltage VDD2 3.0 3.3 5.5 V Input side supply current IDD1 7.2 9 mA Output side supply current IDD2 4.7 6.2 mA Comments Power Supply VDD1 undervoltage detection threshold voltage VDD1UV 1.8 2.3 2.7 V VOS -2.5 ±1 2.5 mV TCVOS -20 0.5 20 μV/°C VDD1 falling Analog Input Input offset voltage Input offset drift INP = INN = GND1, at TA =25°C CMRRdc -80 dB INP = INN, fIN = 0 Hz, VCM min ≤ VIN ≤ VCM max CMRRac -82 dB INP = INN, fIN = 10 kHz, VCM min ≤ VIN ≤ VCM max Single-ended input resistance RIN 1 MΩ INN = GND1 Differential input resistance RIND 1.6 MΩ Input capacitance CI 2 pF Input bias current IIB Common-mode rejection ratio Input bias current drift -0.7 TCIIB -0.6 -0.5 μA -1 nA/°C 1 V/V INP = INN = GND1, at TA =25°C, IIB = (IIBP + IIBN) / 2 Analog Output Nominal Gain Gain error Gain error thermal drift EG -0.3% ±0.1% 0.3% TCEG -40 -10 40 -0.05% ±0.01% 0.05% Nonlinearity Nonlinearity drift Total harmonic distortion THD Output noise Signal to noise ratio Copyright © 2023, NOVOSENSE SNR at TA =25°C ppm/°C at TA =25°C ±1 ppm/°C -75 dB 100 µVRMS 78 dB VIN =±1.2V, fIN = 10kHz, BW = 50kHz INP = INN = GND1, BW = 50kHz VIN =±1.2V, fIN = 10kHz, BW = 50kHz Page 6 NSI1312 Common-mode output voltage Differential fail-safe output voltage Datasheet (EN) 1.3 VCMout 1.39 VFAILSAFE Single-ended fail-safe output voltage VFAILSAFE Single-ended reference input REFIN Single-ended reference input impedance REFININ 0.5 1.44 1.49 V Only for NSI1312D -1.8 -1.7 V NSI1312D VDD1 missing 0 V NSI1312S VDD1 missing, REFIN1.8V V Only for NSI1312S. See application description for more details. VDD2/2 VDD21.5 1 GΩ 100 kHz PSRRdc -95 dB PSRR vs VDD1, at DC PSRRac -95 dB PSRR vs VDD1, 100mV and 10kHz ripple PSRRdc -90 dB PSRR vs VDD2, at DC PSRRac -80 dB PSRR vs VDD2 for NSI1312D, 100mV and 10kHz ripple PSRRac -72 dB PSRR vs VDD2 for NSI1312S, 100mV and 1kHz ripple Output resistance ROUT < 0.2 Ω Output limit current ILIM ±13 mA 150 kV/μs Output bandwidth Power supply rejection ratio Common-mode transient immunity BW CMTI 50 100 Only for NSI1312S Common-mode transient immunity Timing Rising time of OUTP, OUTN tr 3.6 μs Falling time of OUTP, OUTN tf 3.6 μs INP, INN to OUTP, OUTN signal delay (50% - 50%) tPD 3.5 Analog settling time tAS 0.5 4 μs ms VDD1 step to 5.0 V with VDD2 ≥ 3.0 V, to OUTP, OUTN valid, 0.1% settling 6.2. Power Rating Characteristics Parameters Symbol Max Unit Comments Total Power dissipation PD 83.6 mW VDD1=VDD2=5.5V Power dissipation of high side PD1 49.5 mW VDD1=5.5V Power dissipation of low side PD2 34.1 mW VDD2=5.5V Copyright © 2023, NOVOSENSE Page 7 NSI1312 Datasheet (EN) 1.3 6.3. Typical Performance Characteristics Unless otherwise noted, test at NSI1312D VDD1 = 5V, VDD2 = 3.3V, INN=GND1=0V, INP = -1.2V to 1.2V, fIN = 1kHz, BW = 10kHz. Characteristics of NSI1312S may be related to REFIN accuracy. 0.4 0.02 0.3 0.018 Sample1 0.016 Sample2 0.014 Sample3 Nonlinearity/% 0.2 Vos/mV 0.1 0 -0.1 Sample 1 -0.2 -40 -20 0 20 40 60 80 100 0.006 0.002 Sample 3 -0.4 0.01 0.008 0.004 Sample 2 -0.3 0.012 0 120 -40 140 -20 0 20 60 80 100 120 140 Figure 6.3 Nonlinearity vs Temperature Figure 6.1 Input Offset Voltage vs Temperature -0.55 0.2 0.15 Sample 1 0.1 Sample 2 0.05 Sample 3 Sample 1 -0.56 Sample 2 Sample 3 -0.57 IIB/uA Gain Error/% 40 Templerature(℃) Templerature(℃) 0 -0.05 -0.58 -0.59 -0.1 -0.6 -0.15 -0.61 -0.2 -40 -20 0 20 40 60 80 100 120 -40 140 -20 0 20 40 60 80 100 120 140 Templerature(℃) Templerature(℃) Figure 6.4 Input Bias Current vs Temperature Figure 6.2 Gain Error vs Temperature -60 1.6 -65 1.59 -75 RinD/MΩ CMRR/dB -70 -80 1.58 1.57 -85 1.56 -90 -95 -40 -20 0 20 40 60 80 100 120 140 Templerature(℃) Figure 6.5 Common-Mode Rejection Ratio vs Temperature Copyright © 2023, NOVOSENSE 1.55 -40 -20 0 20 40 60 80 100 120 140 Templerature(℃) Figure 6.6 Differential Input Resistance vs Temperature Page 8 Datasheet (EN) 1.3 -65 -65 -66 -66 -67 -67 -68 -68 -69 -69 THD/dB THD/dB NSI1312 -70 -71 -72 VDD1 VDD2 -70 -71 -72 -73 -73 -74 -74 -75 -40 -20 0 20 40 60 80 100 120 -75 140 3 Templerature(℃) 4.5 5 5.5 Figure 6.8 THD vs Supply Voltage 82 82 81 81 80 80 79 SNR/dB SNR/dB 4 Supply Voltage(V) Figure 6.7 THD vs Temperature 78 77 VDD1 VDD2 79 78 77 76 76 75 -40 -20 0 20 40 60 80 100 120 75 140 3 Templerature(℃) 3.5 4 4.5 5 5.5 Supply Voltage(V) Figure 6.9 SNR vs Temperature Figure 6.10 SNR vs Supply Voltage 0 2.5 vs VDD1 -20 2 vs VDD2 Output Voltage/V -40 PSRR/dB 3.5 -60 -80 1.5 1 0.5 -100 -120 0.1 1 10 100 1000 Frequency(kHz) Figure 6.11 Power-Supply Rejection Ratio vs Ripple Frequency (NSI1312D) Copyright © 2023, NOVOSENSE OUTP-GND OUTN-GND 0 -2 -1.5 -1 -0.5 0 0.5 1 1.5 2 Input Voltage(V) Figure 6.12 Output Voltage vs Input Voltage (NSI1312D) Page 9 NSI1312 Datasheet (EN) 1.3 -1.75 1.5 Common Mode Voltage/V Failsafe Voltage/V -1.76 -1.77 -1.78 -1.79 -1.8 -1.81 1.48 1.46 1.44 1.42 -1.82 1.4 -40 -20 0 20 40 60 80 100 120 140 -40 -20 0 20 40 Templerature(℃) Figure 6.13 Fail-Safe Output Voltage vs Temperature (NSI1312D) 3.5 100 120 140 8 7.5 3.49 3.485 Supply Current/mA Propagation Delay/us 80 Figure 6.14 Output Common-Mode Voltage vs Temperature (NSI1312D) 3.495 3.48 3.475 3.47 3.465 7 6.5 3.46 3.455 4.5 -20 0 20 40 60 80 100 120 VDD2=3.3V 5.5 5 -40 VDD1=5V 6 3.45 4 140 -1.2 -0.7 -0.2 Templerature(℃) 0.3 0.8 Input Voltage(V) Figure 6.15 Vin to Vout Delay vs Temperature Figure 6.16 Supply Current vs Input Voltage 8 7.5 7.5 7 7 6.5 VDD1=5V 6 VDD2=3.3V 5.5 5 4.5 Supply Current/mA Supply Current/mA 60 Templerature(℃) 6.5 6 VDD1 5.5 VDD2 5 4.5 4 -40 -20 0 20 40 60 80 100 120 Temperature(C) Figure 6.17 Supply Current vs Temperature Copyright © 2023, NOVOSENSE 140 4 3 3.5 4 4.5 5 5.5 Supply Voltage(V) Figure 6.18 Supply Current vs Supply Voltage Page 10 NSI1312 Datasheet (EN) 1.3 6.4. Parameter Measurement Information 3.3V VDD2 VDD1 INP OUTP INN OUTN GND1 GND2 Battery Differential Probe Oscilloscope High Voltage Probe VCM Figure 6.19 Common-Mode Transient Immunity Test Circuit 7. High Voltage Feature Description 7.1. Insulation and Safety Related Specifications Parameters Symbol Value SOP8 SOW8 Unit Comments Minimum External Clearance CLR 4 8 mm IEC 60664-1:2007 Minimum External Creepage CPG 4 8 mm IEC 60664-1:2007 Distance Through Insulation DTI 28 μm Distance through insulation Tracking Resistance (Comparative Tracking Index) CTI >600 V Material Group Description Overvoltage Category per IEC60664-1 Climatic Classification Pollution Degree per DIN VDE 0110 Copyright © 2023, NOVOSENSE I Test Condition DIN EN 60112 (VDE 0303-11); IEC 60112 IEC 60664-1 Value SOP8 SOW8 For Rated Mains Voltage ≤ 150Vrms I to IV I to IV For Rated Mains Voltage ≤ 300Vrms I to III I to IV For Rated Mains Voltage ≤ 600Vrms I to II I to IV For Rated Mains Voltage ≤ 1000Vrms I I to III 40/125/21 2 Page 11 NSI1312 Datasheet (EN) 1.3 7.2. Insulation Characteristics Description Test Condition Symbol Value Unit SOP8 SOW8 990 2121 VPEAK 700 1500 VRMS 990 2121 VDC DIN EN IEC 60747-17 (VDE 0884-17) Maximum repetitive isolation voltage Maximum working isolation voltage VIORM AC Voltage DC Voltage VIOWM Method a, after Input/output safety test subgroup 2/3, pC Vini=VIOTM, tini = 60 s , Vpd(m)=1.2*VIORM, tm=10s. Apparent Charge Method a, after environmental tests subgroup 1, Vini=VIOTM, tini=60s ,Vpd(m)=1.6*VIORM, tm=10s qpd / 1012 Ω VIO =500V, 100℃ ≤ Tamb ≤ 125°C RIO >1011 >1011 Ω VIO =500V, Tamb=Ts RIO >109 >109 Ω f = 1MHz CIO 0.8 0.8 pF VI = 5.5V, TJ = 150 °C, TA = 25 °C Ps 907 1453 mW Page 12 NSI1312 Datasheet (EN) 1.3 Description Test Condition Symbol θJA = 137.7°C /W for SOP8, VI = 5.5V, TJ = 150 °C, TA = 25°C Safety input, output, or supply current θJA = 86°C/W for SOW8, VI = 5.5V, TJ = 150 °C, TA = 25 °C Maximum safety temperature Value Unit SOP8 SOW8 165 / mA / 264 mA Ts 150 150 ℃ VISO 3000 5000 VRMS Is UL1577 VTEST = VISO, t = 60 s (qualification), Insulation voltage per UL VTEST = 1.2 × VISO, t = 1 s (100% production test) Safety Limiting Power(mW) 1600 SOP8 1400 SOW8 1200 1000 800 600 400 200 0 0 20 40 60 80 100 120 Ambient Temperature(℃) 140 160 Figure 7.1 NSI1312x Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE 0884-17 7.3. Regulatory Information The NSI1312x-DSWVR are approved or pending approval by the organizations listed in table. UL UL 1577 Component Recognition Program Single Protection, 5000Vrms Isolation voltage Approved under CSA Component Acceptance Notice 5A Single Protection, 5000Vrms Isolation voltage VDE CQC DIN EN IEC 60747-17 (VDE 0884-17) Certified according to GB4943.1 Reinforce Insulation VIORM=2121Vpeak VIOTM=8000Vpeak Reinforced insulation VIOSM=10000Vpeak E500602 Copyright © 2023, NOVOSENSE E500602 File (pending) CQC20001264940 Page 13 NSI1312 Datasheet (EN) 1.3 The NSI1312x-DSPR are approved or pending approval by the organizations listed in table. UL Approved under CSA Component Acceptance Notice 5A UL 1577 Component Recognition Program VDE CQC DIN EN IEC 60747-17 (VDE 0884-17) Certified according to GB4943.1 Basic Insulation Single Protection, 3000Vrms Isolation voltage Single Protection, 3000Vrms Isolation voltage VIORM=990Vpeak Basic insulation VIOTM=4242Vpeak VIOSM=6000Vpeak E500602 E500602 File (pending) CQC20001264940 8. Function Description 8.1. Overview The NSI1312 is a cost-effective isolated amplifier with a high input impedance that accept wide range fully-differential input. The fully-differential input is suited to AC or bus voltage monitoring in high voltage applications where isolation is required. The analog input is continuously sampled by a second-order Σ-Δ modulator in the device. With the internal voltage reference and clock generator, the modulator converts the analog input signal to a digital bitstream, as shown in the Figure 8.1. The output of the modulator is transferred by the drivers (called TX in the Functional Block Diagram) across the isolation barrier that separates the isolated input side and output side voltage. The received bitstream and clock are synchronized and processed, as shown in the Functional Block Diagram, by a fourth-order analog filter on the output side and has a differential output. NSI1312 also has singleended output version, as shown in the Figure 8.2, the received bitstream are processed and presented as a single-ended output with external voltage reference from REFIN pin. VDD1 VDD2 VDD1 detection INP Σ-Δ modulator INN TX Isolation Barrier Reference Retiming and 4thOrder Active Low-Pass Filter RX OUTN Reference Oscillator GND1 OUTP GND2 Figure 8.1 Function Block Diagram of Differential Output Version Copyright © 2023, NOVOSENSE Page 14 NSI1312 Datasheet (EN) 1.3 VDD1 VDD2 VDD1 detection Isolation Barrier Reference INP Σ-Δ modulator TX INN Oscillator GND1 RX Retiming and 4thOrder Active Low-Pass Filter OUT Reference REFIN GND2 Figure 8.2 Function Block Diagram of Single-ended Output Version 8.2. Analog Input There are two restrictions on the analog input signals (VINP and VINN).  If the input voltage exceeds the range AGND – 6 V to AVDD + 0.5 V, the input current must be limited to 10 mA because the device input electrostatic discharge (ESD) diodes turn on.  The linearity and noise performance of the device are ensured only when the analog input voltage remains within the specified linear full-scale range (FSR) and within the specified common-mode input voltage range. 8.3. Analog Output For linear input range, the analog output of NSI1312 has a fixed gain of 1. If a full-scale input signal is applied to the NSI1312 (VIN ≥ VClipping), the differential analog output (VOUTP -VOUTN for NSI1312D and VOUT -REFIN for NSI1312S) will be clipped (typically, 1.44V for positive clipping and -1.44V for negative clipping). The negative clipping differential output waveform is shown in Figure 8.3. Vout 1V/div Vneg_clip=-1.44V Figure 8.3 Typical negative clipping output For differential output version (NSI1312D), the differential output pins have a common-mode voltage of 1.44V (typ). The differential output Vout of the NSI1312D is expressed as: 𝑉𝑜𝑢𝑡 = 𝐺𝑎𝑖𝑛 ∗ (𝑉 −𝑉 ) For single-ended output version (NSI1312S), the REFIN pin with high input impedance needs external reference input. The output voltage Vout of the NSI1312S is expressed as: 𝑉𝑜𝑢𝑡 = 𝐺𝑎𝑖𝑛 ∗ (𝑉 Copyright © 2023, NOVOSENSE −𝑉 ) + 𝑅𝐸𝐹𝐼𝑁 Page 15 NSI1312 Datasheet (EN) 1.3 In addition, NSI1312 integrates some diagnostic measures and offers a fail-safe output to simplify system-level design. The failsafe output is a negative differential output voltage that does not occur under normal device operation, and it will only be activated when the undervoltage of VDD1 is detected (VDD1< VDD1UV). For NSI1312D, the typical failsafe output is -1.8V when VDD1 undervoltage, as is shown in Figure 8.4. For NSI1312S, the typical failsafe output is Vfailsafe= 0V if VREF1.8V when VDD1 undervoltage, as is shown in Figure 8.5. VDD1 5V/div Vout 1V/div Vfailsafe=-1.8V Figure 8.4 Typical Failsafe output when VDD1 undervoltage for NSI1312D VDD1 2V/div Vout 0.5V/div Vfailsafe=0V (a) VREF=1.6V (VREF1.8V) Figure 8.5 Typical failsafe output when VDD1 undervoltage for NSI1312S Copyright © 2023, NOVOSENSE Page 16 NSI1312 Datasheet (EN) 1.3 9. Application Note 9.1. Typical Application Circuit NSI1312 has an input impedance of up to 1MΩ, and has a wide bidirectional input voltage range as well. These features make NSI1312 ideally suitable for isolated AC and DC voltage sensing applications such as frequency inverters. The typical application circuit is shown in Figure 9.1. For high voltage side design, the voltage of the frequency inverter is divided by a resistance network, and the divided voltage is applied to the input of NSI1312 through a RC filter to ensure best performance. The characteristics of this filter are dictated by the input topology and sampling frequency of the ADC, customer can adjust the filter design by demand. To reduce extra offset voltage caused by input bias current flowing through Rsense, suggest to add RFLTP as below. To reduce extra gain error caused by input resistance of NSI1312, suggest customer to choose smaller resistance, such as Rsense≤10kΩ. About controller side design, for differential output version (NSI1312D), the differential output of the isolated amplifier is converted to a single-ended analog output with an operational-amplifier-based circuit. Suggest to add >1kΩ resistor on the OUTP and OUTN pin to prevent output over-current protection. For single-ended output version (NSI1312S), REFIN needs external reference input, such as accurate reference IC, LDO and resistor divider network. The single-ended output swing range is GND2+0.3V~VDD2-0.3V. To avoid OUT clamp, REFIN is recommended to be taken as VDD2/2 if need to support ±1.2V analog input range. If the reference is noisy, customer need to add RC filter and adjust the value by demand. The output can be connected to an analog-to-digital converter without signal conditioning. An analog-todigital converter usually receives the analog output and converts to digital signal for controller processing. VBU S+ R1 Rectifier VAC+ Gate Driver Gate Driver R2 R3 VACRsense≤ 10kΩ Gate Driver M Gate Driver Rsense ≤10kΩ VBU S- Gate Driver NSI1312D 3.0~5.5V 2.2uF Gate Driver 0.1uF RFLTN=(R1+R2)//Rsense+RFLTP 100pF VDD1 VDD2 GND1 GND2 INN OUTP INP OUTN RFLTP=10Ω NSI1312S 3.0~5.5V 2.2uF 0.1uF RFLTN=R3//Rsense+RFLTP 100pF RFLTP=10Ω VDD1 VDD2 GND1 GND2 INN OUT INP 0.1uF 3.0~5.5V 2.2uF 1kΩ 1kΩ 47pF 1kΩ 0.1uF To ADC 1kΩ 3.0~5.5V 2.2uF To ADC RFLT=1kΩ REFIN External Reference 4.7uF Figure 9.1 Typical application circuit in voltage sensing 9.2. Sense Resistor Selection There are two other factors should be considered when selecting the sense resistor: Copyright © 2023, NOVOSENSE Page 17 NSI1312 Datasheet (EN) 1.3  The voltage-drop on Rsense divided by nominal VBUS or VAC must not exceed the recommended linear input voltage range: VIN ≤ FSR.  The voltage-drop on Rsense divided by VBUS or VAC in maximum allowed overvoltage condition must not exceed the input voltage that causes a clipping output: VIN ≤ VClipping. 9.3. PCB Layout There are some key guidelines or considerations for optimizing performance in PCB layout:  NSI1312 requires a 0.1µF bypass capacitor between VDD1 and GND1, VDD2 and GND2. The capacitor should be placed as close as possible to the VDD pin. If better filtering is required, an additional 1~10µF capacitor may be used.  Kelvin rules is recommended for the connection between shunt resistor to NSI1312. Because of the Kelvin connection, any voltage drops across the trace and leads should have no impact on the measured voltage.  Place the shunt resistor close to the INP and INN inputs and keep the layout of both connections symmetrical and run very close to each other to the input of the NSI1312. This minimizes the loop area of the connection and reduces the possibility of stray magnetic fields from interfering with the measured signal. 10. Package Information Figure 10.1 SOW8 Package Shape and Dimension in millimeters Copyright © 2023, NOVOSENSE Page 18 NSI1312 Datasheet (EN) 1.3 Figure 10.2 SOW8 Package Board Layout Example Figure 10.3 SOP8 package shape and dimension in millimeters Copyright © 2023, NOVOSENSE Page 19 NSI1312 Datasheet (EN) 1.3 Figure 10.4 SOP8 Package Board Layout Example Copyright © 2023, NOVOSENSE Page 20 NSI1312 Datasheet (EN) 1.3 11. Ordering Information Part No. NSI1312DDSPR NSI1312SDSPR NSI1312D DSWVR NSI1312S DSWVR Isolation Rating(kV) Linear Input Range(V) Moisture Sensitivity Level Temperature Automotive 3 -1.2 ~ 1.2 Level-3 -40 to 125℃ NO 3 -1.2 ~ 1.2 Level-3 -40 to 125℃ NO 5 -1.2 ~ 1.2 Level-3 -40 to 125℃ NO 5 -1.2 ~ 1.2 Level-3 -40 to 125℃ NO Package Type SOP8 (150mil) SOP8 (150mil) SOP8 (300mil) SOP8 (300mil) Package Drawing SPQ SOP8 2500 SOP8 2500 SOW8 1000 SOW8 1000 12. Documentation Support Part Number Product Folder Datasheet Technical Documents Isolator selection guide NSI1312 Click here Click here Click here Click here Copyright © 2023, NOVOSENSE Page 21 NSI1312 Datasheet (EN) 1.3 13. Tape and Reel Information Figure 13.1 Tape Information Copyright © 2023, NOVOSENSE Page 22 NSI1312 Datasheet (EN) 1.3 Direction of Feed Pin 1 1 3 2 4 Quadrant Designations Figure 13.2 Reel Information of SOP8(300mil) Direction of Feed Pin 1 1 3 2 4 Quadrant Designations Figure 13.3 Reel Information of SOP8(150mil) Copyright © 2023, NOVOSENSE Page 23 NSI1312 Datasheet (EN) 1.3 14. Revision History Revision 1.0 1.1 1.2 1.3 Description Initial Release Update REFIN specification in 5.2 and UL certificate number in 6.3 and input filter resistance in Fig 8.1 Update VCM range in part 3, VFAILSAFE and PSRRAC specifications in 5.1, the comments of VOS, IIB, EG and Nonlinearity in 5.1, Figure 5.11~5.14 in 5.3, the standard on which VIOSM test method is based in 6.2, CQC certificate number in 6.3, description for analog output of NSI1312S in 7.3 and input filter resistance in Fig 8.1. Update typeface to Source Sans Pro.  Updated the description of isolation level in the header of first page from ‘Reinforced’ to “Reinforced/Basic’;  Updated specifications in Key features;  Updated Offset Error from ±5mV to ±2.5mV in Section. 6.1;  Updated Offset Drift from ±25μV/℃ (Typ) to ±20μV/℃ (Max) in Section. 6.1;  Updated Gain Error from ±0.4% to ±0.3% in Section. 6.1;  Updated Gain Error Drift from ±50ppm/℃(Typ) to ±40ppm/℃(Max) in Section. 6.1;  Updated THD from -70dB to -75dB in Section. 6.1;  Added a separate section of ESD ratings and changed its description;  Updated ESD the level of HBM from ±2.0kV to ±4.0kV;  Updated the lower limit of VDD1 power supply from 4.5V to 3.0V in Pin Configuration and Functions;  Updated the description of Safety Regulation Approvals;  Updated the description of Safety certification in Section.7(Section.6 in previous edition). Copyright © 2023, NOVOSENSE Date 2022/3/23 2022/6/27 2022/12/24 2023/7/20 Page 24 NSI1312 Datasheet (EN) 1.3 IMPORTANT NOTICE The information given in this document shall in no event be regarded as any warranty or authorization of, express or implied, including but not limited to accuracy, completeness, merchantability, fitness for a particular purpose or infringement of any third party’s intellectual property rights. You are solely responsible for your use of Novosense’ products and applications, and for the safety thereof. You shall comply with all laws, regulations and requirements related to Novosense’s products and applications, although information or support related to any application may still be provided by Novosense. The resources are intended only for skilled developers designing with Novosense’ products. Novosense reserves the rights to make corrections, modifications, enhancements, improvements or other changes to the products and services provided. Novosense authorizes you to use these resources exclusively for the development of relevant applications designed to integrate Novosense’s products. Using these resources for any other purpose, or any unauthorized reproduction or display of these resources is strictly prohibited. Novosense shall not be liable for any claims, damages, costs, losses or liabilities arising out of the use of these resources. For further information on applications, products and technologies, please contact Novosense (www.novosns.com ). Suzhou Novosense Microelectronics Co., Ltd Copyright © 2023, NOVOSENSE Page 25
NSI1312D-DSPR 价格&库存
很抱歉,暂时无法提供与“NSI1312D-DSPR”相匹配的价格&库存,您可以联系我们找货
