2CL75MT
2CL75MT
    HVGT
    SMK-J
2CL75MT 数据手册
2CL75MT 10mA 15kV 80nS SMT High Voltage Silicon Rectifier Diode -----------------------------------------------------------------------------------------------------------------------------------INTRODUCE: HVGT high voltage silicon rectifier diodes is made of high quality silicon wafer chip and high reliability epoxy resin sealing structure, and through professional testing equipment inspection qualified after to customers. FEATURES: 1. Fast recovery. 2. High reliability design. 3. SMD encapsulation. 4. Conform to RoHS and SGS. 5. Epoxy resin molded in vacuumHave anticorrosion in the surface. APPLICATIONS: 1. Air purification, negative ions. 2. Electrostatic voltage doubling circuit . 3. Other high voltage rectifier circuits. 4. Copier and X-ray. MECHANICAL DATA: 1. Case: epoxy resin molding. 2. Terminal: Radial vane. 3. Net weight: 0.32 grams (approx). SHAPE DISPLAY: SIZE: (Unit:mm) HVGT NAME: SMK-J MAXIMUM RATINGS AND CHARACTERISTICS: (Absolute Maximum Ratings) Items Symbols Condition Data Value Units Repetitive Peak Renerse Voltage VRRM TA=25°C 15.0 kV Non-Repetitive Peak Renerse Voltage VRSM TA=25°C 18.0 kV Average Forward Current Maximum IFAVM TA=55°C 10 mA TOIL=55°C -- mA Non-Repetitive Forward Surge Current IFSM TA=25°C; 60Hz Half-Sine Wave; 8.3mS 2.0 A Junction Temperature TJ 125 °C Allowable Operation Case Temperature Tc -40~+125 °C TSTG -40~+150 °C Storage Temperature ELECTRICAL CHARACTERISTICS: Items TA=25°C (Unless Otherwise Specified) Symbols Condition Data value Units VFM at 25°C; at IFAVM 19.5 V IR1 at 25°C; at VRRM 1.0 uA IR2 at 100°C; at VRRM 20 uA Maximum Reverse Recovery Time TRR at 25°C; IF=0.5IR; IR=IFAVM; IRR=0.25IR 80 nS Junction Capacitance CJ at 25°C; VR=0V; f=1MHz 0.9 pF Maximum Forward Voltage Drop Maximum Reverse Current GETE ELECTRONIC CO.,LTD Http://www.getedz.com Http://www.hvgtsemi.com E-mai: sales@getedz.com GETAI ELECTRONIC DEVICE CO.,LTD TEL:0086-20-8184 9628 FAX:0086-20-8184 9638 2020-05 1 / 2 2CL75MT 10mA 15kV 80nS SMT High Voltage Silicon Rectifier Diode -----------------------------------------------------------------------------------------------------------------------------------Forward Current Derating Curve Reverse Recovery Measurement Waveform Average Forward Current-% 125 TRR 100 IF 75 0 50 IRR 25 0 0 25 50 75 100 125 Temperature(℃) 150 175 IR Typical data capture points: IF =0.5IR , IR,IRR =0.25IR IR is typically the rated average forward current maximum (IFAVM) of the D.U.T Non-Repetitive Surge Current 100 75 Peak Forward Surge Current -% 50 25 0 1 Marking 10 Cycles (60Hz) 100 Type Code 2CL75MT MT15 HVGT NOTES: 1. Minimum packing quantity:1,000PCS 2. Specifications based on diode P.C.B. mounted on 5.0 mm x 5.0 mm Cathode Mark copper solder pads. GETE ELECTRONIC CO.,LTD Http://www.getedz.com Http://www.hvgtsemi.com E-mai: sales@getedz.com GETAI ELECTRONIC DEVICE CO.,LTD TEL:0086-20-8184 9628 FAX:0086-20-8184 9638 2020-05 2 / 2
2CL75MT 价格&库存
很抱歉,暂时无法提供与“2CL75MT”相匹配的价格&库存,您可以联系我们找货
