BV05CQ
BV05CQ
    BENCENT(槟城)
    SOD-323
    ESD抑制器/TVS二极管 5V 1A SOD-323
BV05CQ 数据手册
BV05CQ Order Code: BV05CQ Version: A1 2022-04-13 Transient Voltage Suppressor Features Exterior IEC 61000-4-2(ESD)±30KV(air), ±30KV(contact) 150Watts peak pulse power (tp=8/20μs) Ultra low capacitance: 1.5pF maximum Low clamping voltage 2 1 Moisture sensitivity level: Level 1 Weight 5.0mg Small package: SOD323 AEC-Q101 qualified SOD323 Agency Approvals Application Information xDSL Icon Description Compliance with 2011/65/EU Compliance with IEC61249-2-21:2003 Mean lead free Part Number and Electrical Parameter Part Number BV05CQ VBR①@IR IDRM@VDRM V μA V MAX Vc@Ipp② mA MIN 5 5 6 V Vc@Ipp② A MAX 1 9.8 V CO③ A MAX 1 18.3 pF MAX 8 1.5 Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted). ① VBR is measured at IR=1mA ② Surge Waveform: 8/20us. ③ Off-state capacitance is measured in VDC=0V, VRMS=1V, f=1MHz. Part Numbering System Mark BV 05 C Q (1) (2) (3) (4) (1) Bencent Transient Voltage Suppressor (2) Series: 05 etc. (3) Bidirectional TVS B42LC B006U2G AC 0909 0909 AC: Part Number (4) AEC-Q101 qualified 1/4 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BV05CQ Order Code: BV05CQ Version: A1 2022-04-13 Transient Voltage Suppressor V-I Curve Parameters Definition VC Clamping voltage Ipp Surge waveform 8/20us VDRM Stand-off Voltage VBR Breakdown Voltage IDRM Reverse Leakage Current IR Test current Ppp Peak Pulse Power Dissipation IPP VC VBR VDRM IR IDRM IDRM IR V VDRM VBR VC IPP Typical Characteristics Thermal Considerations 2/4 symbol Parameter Value Unit TJ Operating Junction Temperature Range -55 to +150 ℃ TS Storage Temperature Range -55 to +150 ℃ www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BV05CQ Order Code: BV05CQ Version: A1 2022-04-13 Transient Voltage Suppressor Environmental Characteristics Technical standards Testing items Temperature: 150±3℃ Bias=80%VDRM Time: 168H Temperature: 150℃ High Temperature Life Test Time:168H Temperature: From -40℃ to125℃ High-low Temperature Cycle test Dwell time: 30min, 10~100cycles Temperature: 85℃ Humidity: 85% High Temperature &High Humidity Test Time: 168H Temperature: 121℃, 2atm. Humidity: 100% Pressure cooker Test Time: 24H Temperature: 260±5℃ Resistance of soldering heat Time of dip soldering: 10s, 3times Note: The above testing items can be specified by customer’s special request High temperature Reverse Bias Test Product Dimensions REF mm inch A 1.17(max) 0.046(max) A1 0.10(max) 0.004(max) b 0.34±0.10 0.013±0.0039 c 0.17±0.08 0.007±0.0032 D 1.66±0.14 0.065±0.0055 E 1.28±0.17 0.050±0.0067 H 2.5±0.2 0.098±0.0079 L 0.28±0.18 0.011±0.0071 Q1 0.25±0.15 0.010±0.0059 Recommended Soldering Pad A D C 3/4 B www.bencent.com.cn REF mm inch A 3.20 0.126 B 1.08 0.043 C 1.06 0.042 D 0.54 0.021 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BV05CQ Order Code: BV05CQ Version: A1 2022-04-13 Transient Voltage Suppressor Reflow Profile Reflow Condition Temperature Min. +150°C Temperature Max. +200°C Time (Min to Max) 60 – 180 secs. Average ramp up rate (Liquidus Temp (TL) to peak) TS(max) to TL - Ramp-up Rate - Temperature (TL) Reflow (Liquidus) - Temperature (TL) Peak Temp (TP) TP TP 3°C/sec. Max. 3°C/sec. Max. +217°C 60 – 150 secs. TL TS(max) Ramp-down Preheat TS(min) TS +(260+0/-5 )°C Time within 5°C of actual Peak Temp (TP) Critical Zone TL to TP Ramp-up TL Temperature Pre Heat Pb-Free Assembly TL 25 secs. 25 Ramp-down Rate 6°C/sec. Max. Time 25°C to peak Temp (TP) 8 min. Max. Do not exceed +260°C Time time to peak temperature Package Reel Information 4/4 REF mm inch A 1.46+/-0.1 0.057+/-0.004 B 3.10+/-0.3 0.122+/-0.012 d 1.50+/-0.1 0.059+/-0.004 D 178+/-1.0 7.008+/-0.039 D1 55+/-3 2.165+/-0.118 D2 13+/-0.5 0.512+/-0.020 E 1.75+/-0.1 0.069+/-0.004 F 3.5+/-0.2 0.138+/-0.008 P 4.0+/-0.2 0.157+/-0.008 P0 4.0+/-0.2 0.157+/-0.008 P1 2.0+/-0.2 0.079+/-0.008 W 8.0+/-0.2 0.315+/-0.008 W1 12.3+/-1.0 0.484+/-0.039 Outline Reel (pcs) Per Carton (pcs) Reel Diameters (mm) Taping 3,000 90,000 178 www.bencent.com.cn Carton Size(mm) L W H 390 370 220 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BV05CQ 价格&库存
很抱歉,暂时无法提供与“BV05CQ”相匹配的价格&库存,您可以联系我们找货
