W005 thru W10
SEP ELECTRONIC CORP.
1.5 A Single-Phase Silicon Bridge Rectifier
Rectifier Reverse Voltage 50 to 1000V
8.9
5.2
Features
0.5
This series is UL listed under the Recognized
Component Index, file number E142814
The plastic material used carries Underwriters Laboratory
flammability recognition 94V-0
Ideal for printed circuit board mounting
High surge current capability
High temperature soldering guaranteed 265 C/10
seconds at 5 lbs (2.3kg) tension
20.5
16.7
0.5
0.5
5.1 + 0.5
Mechanical Data
Case: Reliable low cost construction utilizing
molded plastic technique
Terminals: Plated leads solderable per MIL-STD-202,
Method 208
Mounting Position: Any
Weight: 0.05 ounce, 1.3 grams (approx)
5.1 + 0.5
Dimensions in millimeters(1mm =0.0394")
Maximum Ratings & Thermal Characteristics
Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz.
For Capacitive load derate current by 20%.
Parameter
Symbol W005
W01
W02
W04
W06
W08
W10 unit
Maximum repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS bridge input voltage
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
Maximum DC blocking voltage
Maximum average forward rectified
output current at TA=25 C
IF(AV)
1.5
A
Peak forward surge current single sine-wave
superimposed on rated load (JEDEC Method)
IFSM
50
A
I t
2
10.0
A sec
ReJA
50.0
C/W
24.0
pF
Rating for fusing ( t
很抱歉,暂时无法提供与“W04M”相匹配的价格&库存,您可以联系我们找货
