XL-1615RGBC-WS2812B-S 数据手册
Technical Data
Sheet
1615 幻彩
haracteristics
* 外观尺寸(L/W/H):1.6*1. 5*0.6 mm
outline Dimensions (L / w / h): 1.6*1. 5*0.6 mm
* 发光颜色及胶体:RGB/透明胶体
Luminous color and colloid:RGB/
transparent colloid
* 环保工艺符合 ROHS 要求
Environmental protection products Complied With ROHS Directive
* 湿气敏感性等级(MSL):5a 级
Moisture sensitivity level(MSL) : 5a levels
* EIA 规范标准包装
EIA standard packaging
* 适用于 SMT 贴片自动化生产
Suitable for SMT automatic production
* 适用于红外线回流焊制程
Suitable for infrared reflow soldering process
roduct application
* LED 全彩发光字灯串
Led full-color luminous word lamp string,
* LED 全彩模组
led full-color module
* LED 幻彩软硬灯条,LED 护栏管
Led magic color soft and hard light strip, LED guardrail tube
* LED 外观,情景照明
Led appearance, scene lighting
* LED 异性屏
Led heterosexual screen
* 各种电子产品,电器设备跑马灯
All kinds of electronic products, electrical equipment, runninglights
1
WS2812b 功能特点/ws2812b Functional characteristics:
1.灯珠内部集成高质量外控单线级联恒流 IC 和优质 RGB LED 芯片,体积小巧,外围简单。
The ball interior integrates high-quality external single-line cascade IC and high-quality RGB LED
chips, which are small in size and simple on the periphery.
2.内置 IC 恒流精度高,内部 RGB 芯片预先分光处理。发光高度一致,白光效果纯正。
BUILT-IN IC constant current high precision, internal RGB chip pre-optical processing. High Degree
of uniformity of light, white light effect pure.
3.整形转发强化技术,单线数据传输,可无限级联。
Plastic forwarding enhancement technology, single-line data transmission, can be cascaded.
4.数据传输频率 800Kbps/秒,可实现画面刷新速率 30 帧 / 秒时,不小于 1024 点。
The data transmission frequency is 800Kbps per second, and the screen refresh rate can be achieved at
30 frames per second, not less than 1024 points.
5.输出端口 PWM 控制能够实现 256 级灰度调节,端口扫描频率 1.5KHz / s。
The output port PWM control can achieve 256 levels of grayscale adjustment, and the port scan
frequency is 1.5 KHz / S.
6.采用优化预置 12mA/通道恒流模式,低压驱动级联数量最大化。高恒流精度,片内误差
XL-1615RGBC-WS2812B-S 价格&库存
很抱歉,暂时无法提供与“XL-1615RGBC-WS2812B-S”相匹配的价格&库存,您可以联系我们找货
