SL0630-2R2M
SL0630-2R2M
    SEA&LAND(台湾陆海)
    SMD,7.1x6.6mm
    固定电感器 SMD,7.1x6.6mm 2.2μH ±20% 9A 7.10 x 6.60mm
SL0630-2R2M 数据手册
SEA & LAND ELECTRONIC CORP. www.sealand-pptc.com ALPHA-TOP TECHNOLOGY CORP. www.alpha-top.cn APPROVAL SHEET MODEL NO.: SL0420~1265-SERIES CUSTOMER: CUSTOMER'S APPROVAL: AUTHORIZED SIGNATURE/STAMP: DATE MANUFACTURER: HEAD OFFICE: 13F.,No.120-10,Sec.3,Zhongshan Rd.,Zhonghe Dist.,New Taipei City 23544,Taiwan Tel: 886-2-8221-2567 Fax:882-2-2225-7268 E-mail:service@chipfast.com.tw China Branch: Factory Building B)Shuangpeng,Weibu Village, Qiuchang Town, Huiyang District, Huizhou City, Guangdong Province, P.R.C.) Tel: 86-752-3562001 Fax:86-752-3558696 E-mail:service@atpptc.com Submitted by: Approved by: DATE: SEA & LAND ELECTRONIC CORP. Chen YC Lin 25-Mar-24 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 0420 Size - 0420 Dimensions A B C D E F G H 4.1 ± 0.5 4.5 ± 0.5 2.0 MAX 2.0 ± 0.5 1.0 ± 0.5 4.95 Typ 2.15 Typ 2.30 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL0420-R22M SL0420-R47M SL0420-R56M SL0420-R68M SL0420-1R0M SL0420-1R5M SL0420-2R2M SL0420-3R3M SL0420-4R7M SL0420-6R8M SL0420-100M L0 Inductance μH ±20% @0A DCR (mΩ) 0.22 6.5 12 16 18 27 45 58 89 105 150 200 0.47 0.56 0.68 1.00 1.50 2.20 3.30 4.70 6.80 10.00 [ Max ] Heat Rating Current Idc (AMP) Typical 9.5 7.5 7.0 6.5 6.0 5.0 4.5 3.5 3.0 2.5 2.0  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 17.0 13.0 10.0 8.0 7.0 6.5 5.0 4.0 3.5 3.0 2.5 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 1 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 0520 Size - 0520 Dimensions A B C D E F G H 5.2 ± 0.5 5.7 ± 0.5 2.0 MAX 2.0 ± 0.5 1.0 ± 0.5 5.20 Typ 2.00 Typ 2.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL0520-R22M SL0520-R47M SL0520-R56M SL0520-R68M SL0520-1R0M SL0520-1R5M SL0520-2R2M SL0520-3R3M SL0520-4R7M SL0520-6R8M SL0520-100M L0 Inductance μH ±20% @0A DCR (mΩ) 0.22 4.5 9 10 13 17 27 34 58 85 120 155 0.47 0.56 0.68 1.00 1.50 2.20 3.30 4.70 6.80 10.00 [ Max ] Heat Rating Current Idc (AMP) Typical 15.0 10.5 9.5 9.0 8.0 7.0 5.0 4.5 3.5 2.8 2.5  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 18.5 15.5 15.0 11.5 9.0 8.0 7.0 5.5 4.5 3.5 3.0 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 2 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 0530 Size - 0530 Dimensions A B C D E F G H 5.2 ± 0.5 5.7 ± 0.5 3.0 MAX 2.0 ± 0.5 1.0 ± 0.5 5.20 Typ 2.00 Typ 2.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL0530-R22M SL0530-R33M SL0530-R47M SL0530-R68M SL0530-1R0M SL0530-1R5M SL0530-2R2M SL0530-3R3M SL0530-4R7M SL0530-6R8M SL0530-100M SL0530-150M L0 Inductance μH ±20% @0A DCR (mΩ) 0.22 3.9 5.5 7.5 10 14 25 29 38 55 70 115 175 0.33 0.47 0.68 1.00 1.50 2.20 3.30 4.70 6.80 10.00 15.00 [ Max ] Heat Rating Current Idc (AMP) Typical 14.0 13.0 12.0 10.0 9.0 8.0 7.0 5.5 4.5 3.5 3.0 2.5  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 20.0 18.0 15.0 14.0 13.0 9.5 8.5 7.5 6.0 5.0 4.0 3.0 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 3 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 0620 Size - 0620 Dimensions A B C D E F G H 6.6 ± 0.5 7.1 ± 0.5 2.0 MAX 3.0 ± 0.5 1.5 ± 0.5 8.40 Typ 3.60 Typ 3.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL0620-R10M SL0620-R22M SL0620-R33M SL0620-R47M SL0620-R68M SL0620-1R0M SL0620-1R5M SL0620-2R2M SL0620-3R3M SL0620-4R7M SL0620-6R8M SL0620-100M L0 Inductance μH ±20% @0A DCR (mΩ) 0.10 0.22 2.5 3.5 5.5 8.4 12 16 26 35 50 60 95 120 0.33 0.47 0.68 1.00 1.50 2.20 3.30 4.70 6.80 10.00 [ Max ] Heat Rating Current Idc (AMP) Typical 25.0 16.0 12.0 11.5 9.5 8.5 8.0 7.0 4.5 4.0 3.0 2.5  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 42.0 25.0 22.0 18.0 17.0 12.5 10.5 8.5 7.0 5.5 5.0 4.0 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 4 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 0624 Size - 0624 Dimensions A B C D E F G H 6.6 ± 0.5 7.1 ± 0.5 2.4 MAX 3.0 ± 0.5 1.5 ± 0.5 8.40 Typ 3.60 Typ 3.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL0624-R10M SL0624-R22M SL0624-R33M SL0624-R47M SL0624-R68M SL0624-1R0M SL0624-1R5M SL0624-2R2M SL0624-3R3M SL0624-4R7M SL0624-6R8M SL0624-100M SL0624-150M SL0624-220M L0 Inductance μH ±20% @0A DCR (mΩ) 0.10 0.22 1.85 3.2 4.1 5.1 7 13.5 17.5 28 39 50 70 100 160 230 0.33 0.47 0.68 1.00 1.50 2.20 3.30 4.70 6.80 10.00 15.00 22.00 [ Max ] Heat Rating Current Idc (AMP) Typical 22.5 21.0 18.0 15.0 12.0 9.0 8.0 7.0 5.5 5.0 4.0 3.0 2.5 2.0  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 55.0 33.0 24.5 21.0 16.5 15.0 13.5 9.0 7.0 6.5 5.0 4.0 3.5 2.5 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 5 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 0630 Size - 0630 Dimensions A B C D E F G H 6.6 ± 0.5 7.1 ± 0.5 3.0 MAX 3.0 ± 0.5 1.5 ± 0.5 8.40 Typ 3.60 Typ 3.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL0630-R33M SL0630-R47M SL0630-R56M SL0630-R68M SL0630-R82M SL0630-1R0M SL0630-1R5M SL0630-2R2M SL0630-3R3M SL0630-4R7M SL0630-6R8M SL0630-100M SL0630-150M SL0630-220M SL0630-330M SL0630-470M L0 Inductance μH ±20% @0A DCR (mΩ) 0.33 0.47 3.5 4.5 5 5.8 6 9.2 12.1 19.5 26 38 65 99.5 115 155 250 415 0.56 0.68 0.82 1.00 1.50 2.20 3.30 4.70 6.80 10.00 15.00 22.00 33.00 47.00 [ Max ] Heat Rating Current Idc (AMP) Typical 21.0 18.0 16.5 16.0 14.0 12.0 11.0 9.0 8.5 6.5 5.5 5.0 3.5 2.5 2.0 1.5  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 25.0 20.0 18.0 17.0 16.0 15.0 13.0 10.0 9.5 8.0 6.5 5.5 4.5 3.5 2.5 2.0 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 6 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 0650 Size - 0650 Dimensions A B C D E F G H 6.6 ± 0.5 7.1 ± 0.5 5.0 MAX 3.0 ± 0.5 1.5 ± 0.5 8.40 Typ 3.60 Typ 3.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL0650-R22M SL0650-R47M SL0650-R56M SL0650-R68M SL0650-1R0M SL0650-1R5M SL0650-2R2M SL0650-3R3M SL0650-4R7M SL0650-6R8M SL0650-100M SL0650-150M SL0650-220M SL0650-330M SL0650-470M L0 Inductance μH ±20% @0A DCR (mΩ) 0.22 0.47 1.5 5 5.5 6.5 8 10.5 12.5 22.5 27.5 35 58 65 98 186 255 0.56 0.68 1.00 1.50 2.20 3.30 4.70 6.80 10.00 15.00 22.00 33.00 47.00 [ Max ] Heat Rating Current Idc (AMP) Typical 30.0 20.0 18.0 14.0 12.0 9.5 9.0 8.5 7.0 6.0 5.0 4.0 3.0 2.5 2.0  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 35.0 24.0 22.0 18.0 16.0 13.0 12.0 10.0 9.0 8.0 7.0 5.0 5.0 3.5 2.5 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 7 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 1040 Size - 1040 Dimensions A B C D E F G H 10.5 ± 0.5 11.0 ± 0.5 4.0 MAX 3.0 ± 0.5 2.0 ± 0.5 12.5 Typ 6.00 Typ 4.00 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL1040-R47M SL1040-R56M SL1040-R68M SL1040-1R0M SL1040-1R5M SL1040-2R2M SL1040-3R3M SL1040-4R7M SL1040-5R6M SL1040-6R8M SL1040-8R2M SL1040-100M SL1040-150M SL1040-220M SL1040-330M SL1040-470M L0 Inductance μH ±20% @0A DCR (mΩ) 0.47 1.7 1.9 2.4 3.5 5 7 12 16 20 25 27 32 45 66 92 145 0.56 0.68 1.00 1.50 2.20 3.30 4.70 4.70 6.80 8.20 10.00 15.00 22.00 33.00 47.00 [ Max ] Heat Rating Current Idc (AMP) Typical 30.0 25.0 23.0 19.0 16.0 12.0 11.0 9.0 8.7 8.5 8.0 7.5 6.5 5.0 4.5 3.5  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions Saturation Current Isat (AMP) Typical 40.0 33.0 30.0 28.0 24.0 18.0 16.0 14.0 13.0 12.0 9.0 8.0 7.0 6.0 5.0 4.0 all effect the part temperature. Part temperature should be verified in the end application. Page: 7 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 1050 Size - 1050 Dimensions A B C D E F G H 10.5 ± 0.5 11.0 ± 0.5 5.0 MAX 3.0 ± 0.5 2.0 ± 0.5 12.5 Typ 6.00 Typ 4.00 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL1050-R82M SL1050-1R0M SL1050-1R5M SL1050-2R2M SL1050-3R3M SL1050-4R7M SL1050-5R6M SL1050-6R8M SL1050-8R2M SL1050-100M SL1050-150M SL1050-220M SL1050-330M SL1050-470M SL1050-680M SL1050-101M L0 Inductance μH ±20% @0A DCR (mΩ) 0.82 2.6 2.8 3.8 6 7.5 15 17 19.5 28 35 48 87 95 120 170 255 1.00 1.50 2.20 3.30 4.70 4.70 6.80 8.20 10.00 15.00 22.00 33.00 47.00 68.00 100.00 [ Max ] Heat Rating Current Idc (AMP) Typical 22.0 19.5 16.0 14.0 12.0 10.0 9.5 9.0 8.5 8.0 6.5 5.5 5.0 4.0 3.5 2.5  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Saturation Current Isat (AMP) Typical 38.0 30.0 26.0 20.0 17.0 15.0 14.0 13.0 11.5 10.0 9.0 8.0 6.0 5.0 4.5 3.5 Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all effect the part temperature. Part temperature should be verified in the end application. Page: 8 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 1250 Size - 1250 Dimensions A B C D E F G H 12.8 ± 0.5 13.5 ± 0.5 5.0 MAX 3.5 ± 0.5 2.5 ± 0.5 14.5 Typ 8.00 Typ 4.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL1250-R82M SL1250-1R0M SL1250-1R5M SL1250-2R2M SL1250-3R3M SL1250-4R7M SL1250-5R6M SL1250-6R8M SL1250-8R2M SL1250-100M SL1250-150M SL1250-220M SL1250-330M L0 Inductance μH ±20% @0A DCR (mΩ) 0.82 1.7 2.5 4 5.5 7.5 9 10.5 16.5 22 26.5 33 45 68 1.00 1.50 2.20 3.30 4.70 5.60 6.80 8.20 10.00 15.00 22.00 33.00 [ Max ] Heat Rating Current Idc (AMP) Typical 30.0 26.0 23.0 15.0 14.0 13.0 12.0 11.0 9.0 8.5 8.0 7.0 5.0  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions Saturation Current Isat (AMP) Typical 40.0 35.0 33.0 26.0 24.0 20.0 18.0 15.0 12.5 12.0 11.0 8.0 6.0 all effect the part temperature. Part temperature should be verified in the end application. Page: 9 SPECIFICATION ITEM P/N PRODUCT SL0420~1265-SERIES SMD Inductor PACKING DIMENSIONS (mm) EXPLANATION OF PART NUMBERS SL Serial Codes 1265 Size - 1265 Dimensions A B C D E F G H 12.8 ± 0.5 13.5 ± 0.5 6.5 MAX 3.5 ± 0.5 2.5 ± 0.5 14.5 Typ 8.00 Typ 4.50 Typ 1R0M Inductance Code ELECTRICAL CHARACTERISTICS P/N SL1265-1R0M SL1265-1R5M SL1265-2R2M SL1265-3R3M SL1265-4R7M SL1265-5R6M SL1265-6R8M SL1265-8R2M SL1265-100M SL1265-150M SL1265-220M SL1265-330M SL1265-470M SL1265-680M SL1265-101M L0 Inductance μH ±20% @0A DCR (mΩ) 1.00 1 1.8 3.2 6.5 7.5 10.5 13.5 16 18 26 39.5 53 75 115 138 1.50 2.20 3.30 4.70 5.60 6.80 8.20 10.00 15.00 22.00 33.00 47.00 68.00 100.00 [ Max ] Heat Rating Current Idc (AMP) Typical 24.0 23.0 21.0 15.0 15.0 13.0 12.0 11.0 10.0 8.5 7.0 6.0 5.5 3.5 2.0  All test Data is referenced to 25℃ ambient  Typical Heat Rating DC Current would cause an approximately △T of 40℃  Typical Saturation DC Current would cause Lo to drop approximately 30%  Operation Temperature Range : -40℃ ~ 125℃  The Part temperature (ambient + △T) should not exceed 125℃ under worst case operating conditions.  Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions Saturation Current Isat (AMP) Typical 40.0 30.0 27.0 24.0 22.0 21.0 19.0 15.5 15.0 13.5 10.0 8.0 6.5 4.5 3.5 all effect the part temperature. Part temperature should be verified in the end application. Page: 10 CHARACTERISTICS ITEM P/N SL0420~1265-SERIES PRODUCT SMD Inductor RECOMMENDED SOLDERING TEMP. GRAPH A B C D E 260℃ 230℃ 10 Sec 150℃ 60~240 Sec MECHANICAL RELIABILITY TEST Solderability Specification & Requirement Method Used The surface of terminal/pin tested shall Solder heat proof: be covered with new solder by 95% Preheating: 180 ±10℃ 90 seconds Inductance change within ± 5% Without Drop down with 981m/s2 (100G) shock Attitude upon a rubber block method shock Soldering: 255 ±5℃ for 3 ±1 sec Shock mechanical damage testing machinem, 3 tests. Vibration Inductance change within ± 5% Without Vibration frequency: mechanical damage 10Hz to 55Hz to 10Hz 60 seconds cycle Vibration time: 2 hours ENDURANCE RELIABILITY TEST Specification & Requirement Inductance change within ± 5% Without Thermal Shock mechanical damage Heat Resistance Humidity Resistance Low Temp. Storing High Temp. Storing Inductance change within ± 5% Without Method Used -25℃, (30 mins) -> room temp. (5 mins) -> 125℃, (30 mins) -> room temp. (5 mins) 100 cycles Apply IDC current @ 85℃ ambient mechanical damage Inductance change within ± 5% Without Duration: 1000 hrs Apply IDC current @ 60℃ ambient mechanical damage Humidity: 90~95% Duration: 1000 hrs Inductance change within ± 5% Without Storing Temp. mechanical damage -25 ±2 ℃ for total 1,000 +4/-0 hours Inductance change within ± 5% Without Storing Temp. mechanical damage 125 ±2 ℃ for total 1,000 +4/-0 hours Page: 11 PACKING FOR SMD ITEM P/N SL0420~1265-SERIES PRODUCT SMD Inductor CARRIERTAPEING REEL & CARRIER MATERIALS (PAPER PLASTICS) UNIT : (mm) Typical Pulling Force: 100 grams Series 0420 0520 0530 0620 0624 0630 0650 1040 1050 1250 1265 A 3000 2000 2000 2000 1000 1000 1000 800 800 500 500 B 12 12.5 12.5 17 17 17 17 25 25 25 25 W 12 12 12 16 16 16 16 24 24 24 24 Ao 4.6Typ 5.7Typ 5.7Typ 6.9Typ 6.9Typ 6.9Typ 6.9Typ 11.0Typ 11.0Typ 13.1Typ 13.1Typ Bo 4.75 Typ 5.90 Typ 5.90 Typ 7.6 Typ 7.6 Typ 7.6 Typ 7.6 Typ 12.6 Typ 12.6 Typ 15.0 Typ 15.0 Typ Ko 2.3Typ 2.3Typ 3.6Typ 2.3Typ 2.3Typ 3.3Typ 5.4Typ 4.3Typ 5.4Typ 5.3Typ 6.8Typ Page:12
SL0630-2R2M 价格&库存
很抱歉,暂时无法提供与“SL0630-2R2M”相匹配的价格&库存,您可以联系我们找货
SL0630-2R2M
  • 10+0.44971
  • 100+0.36761
  • 300+0.32659
  • 1000+0.29579
  • 5000+0.27118
  • 10000+0.25887
库存:952
