IRLML2502TR
20V N-Channel Enhancement Mode MOSFET
FEATURE
20V/2.0A, RDS(ON)=80mΩ (typ.)@V GS=1.8V
Super high design for extremely low R DS(ON)
Exceptional on-resistance and Maximum DC
to
r
20V/4.5A, RDS(ON)=25mΩ (typ.)@V GS=4.5V
20V/2.5A, RDS(ON)=55m Ω (typ.)@V GS=2.5V
Full RoHS compliance
SOT23-3L package design
uc
current capability
nd
DESCRIPTION
The 2502 is the N-Channel logic enhancement
APPLICATIONS
mode power field effect transistor is produced using
Power Management
Portable Equipment
DC/DC Converter
particularly suited for low voltage application, and
Load Switch
low in-line power loss are needed in a very small
DSC
outline surface mount package.
LCD Display inverter
This high density process is especially tailored to
Symbol
VDSS
VGSS
Se
CR
O
ABSOLUTE MAXIMUM RATINGS ( TA = 25℃
ID
Unless otherwise noted )
Parameter
Typical
Unit
Drain-Source Voltage
V
Gate-Source Voltage
±10
V
4.5
A
JS
MI
mi
minimize on-state resistance. These devices are
co
high cell density advanced trench technology..
Continuous Drain Current (TC=25℃)
Continuous Drain Current (TC=70℃)
VGS=10V
3.0
IDM
Pulsed Drain Current
A
IS
Continuous Source Current (Diode Conduction)
1.5
A
PD
Power Dissipation
TJ
Operation Junction Temperature
TSTG
Storage Temperature Range
RθJA
Thermal Resistance Junction to Ambient
TA=25℃
1.5
TA=70℃
0.9
W
150
-55~+150
90
℃/W
Note: Absolute maximum ratings are those values beyond which the device could be permanently damaged.
Absolute maximum ratings are stress rating only and functional device operation is not implied
www.jsmsemi.com
第1页,共5页
IRLML2502TR
ELECTRICAL CHARACTERISTICS(TA=25℃
Symbol
Parameter
Unless otherwise noted)
Condition
Min
Typ
Max
Unit
Static Parameters
Drain-Source Breakdown Voltage
VGS=0V, ID=250uA
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=250uA
0.5
IGSS
Gate Leakage Current
VDS=0V, VGS=±12V
VDS=20V, VGS=0
IDSS
Zero Gate Voltage Drain Current
VDS=20V, VGS=0
TJ=55℃
Drain-Source On-Resistance
Diode Forward Voltage
60
VGS=1.8V, ID=2.0A
65
90
0.78
1.2
VDS=10V
11
13
VGS=4.5V
1.45
co
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Tr
Td(off)
Tf
Se
Turn-On Time
CR
O
Td(on)
Turn-Off Time
5
40
mi
Qg
nA
VGS=2.5V, ID=2.5A
IS=1.7A, VGS=0V
Dynamic Parameters
±100
45
Source-Drain Diode
VSD
V
25
nd
RDS(ON)
1.0
1
uc
VGS=4.5V, ID=3.0A
V
to
r
V(BR)DSS
uA
mΩ
V
nC
ID=5.0A
2.3
VDS=10V
578
VGS=0V
116
f=1MHz
96
VDS=10V
14.5
25
ID=1.0A
42
62
VGEN=4.5V
46
67
RG=6Ω
34
43
pF
nS
Note: 1. Pulse test: pulse width
很抱歉,暂时无法提供与“IRLML2502TRPBF”相匹配的价格&库存,您可以联系我们找货
