X02AQ285FD2DD42
X02AQ285FD2DD42
    XKB(中国星坤)
    弯插
    RJ11/RJ45连接器 母端 弯插
X02AQ285FD2DD42 数据手册
XKB Connecitity XKB Connecitity Electrical 电气 : 1.Turn ratio 匝数比 :1~2:J1~J2=1CT:1CT(±2%). 3~4:J3~J6=1CT:1CT(±2%) 7~8:J4~J5=1CT:1CT(±2%) 9~10:J7~J8=1CT:1CT(±2%) 2.OCL 已占搭载量 :180uH Min.at 100KHz 100mV 3.Insertion Loss 插入损耗 :-1.0 dB Max 1~125MHz. 4.Return loss 回波损耗 :-20dB Min 1~40MHz. -20+15LOG10(f/40MHz) Min 40~200MHz. 5.Cross talk 声道串扰 : -30dB Min 1~125MHz 6.CMR 共模抑制 :-30dB Min 30~200MHz; 7.Hi-Pot 耐压测试 :2250V DC 6S 1mA PRI TO SEC *21.35[0.841] 3.05[0.120] 8.89[0.350] 20mA 1.8 5-2.45V Yellow 585nm 20mA 1. 7-2.2V 1CT:1 J1 TX1+ TD1- 2 RIGHT SIDE VIEW J8 568nm TD1+ 1 4.57[0.180] 10.80[0.425] Foward(V) Green J1 J2 TX11CT:1 TD2+ 3 J3 TX2+ 1pF 50v TD2- 4 J6 TX21CT:1 TD3+ 7 J4 TX3+ TD3- 8 J5 TX31CT:1 TD4+ 9 J7 TX4+ TD4-10 11.43[0.450] CABLE SIDE YELLOW RIGHT TOP VIEW PCB SIDE TO PHY GREEN LEFT Standard LED Color LED Wavelength Foward(A) *3.05[0.120] *15.95 [0.628] LED Specification 3.20[0.126] LEFT SIDE VIEW *3.25[0.128] *13.60[0.535] 2.03 [0.080] 2.54[0.100] J8 TX4- 5 6 15.75[0.620] 2.54[0.100] GREEN -Ø 0. 13.45[0.530] 14 10 10 8 5 6 3 4 1 3 4] .1 0[0 3.2 2-Ø 13 ] 26 2 12 11 .0 2[0 1.0 4-Ø ] 40 13.45[0.530] RECOMMENDED PCB LAYOUT VIEWED FROM COMPONENT SIDE BOTTOM VIEW X X DATE DESCRIPTION REVISIONS www.helloxkb.com www.helloxkb.cn www.xk-dg.cn REVISED YELLOW 12 LEFT 11 RIGHT MATERIAL 材料: HOUSING 外壳: PBT,UL94V-0,BLACK. TERMINALS BRACKET 端子支架 : PBT,UL94V-0,BLACK. SHIELD 保护物 : C2680,T=0.20MM,NICKEL PLATING ON ALL AREA. TERMINAL 端子: PHOSPHOR BRONZE C5210,T=0.35MM, GOLD PLATING ON CONTACT AREA. X02AQ285FD2DDX2 MECHANICAL 机械: DURABILITY 耐用性 : 750 CYCLES MIN. 1:AU=1U" MATING FORCE 配合力 : 23N MAX. 3:AU=3U" OPERATING TEMPERATURE 工作温度 : -40°C~+85°C. 4:AU=6U" 5:AU=15U" STORAGE TEMPERATURE 储存温度 : -40°C~+85°C. 6:AU=30U" ALL CRITICAL DIMENSIONS WITH "*" X MARK 13 XKB Connecitity 1 2.54[0.100] 2 -Ø1.6 3[0.06 Center line 4.57[0.180] 7 2 4 5 0.635[0.025] 14 9 6 7 3.05[0.120] 12 8 9 2.03[0.080] 11 14 8.89[0.350] 4.57[0.180] 13 10 4*75Ω SHIELD 89 [0 . 11.43[0.450] 1000pF/2KV BACK VIEW 03 5] FRONT VIEW APPROVED ANGLAR L≤ 4 4
X02AQ285FD2DD42 价格&库存
很抱歉,暂时无法提供与“X02AQ285FD2DD42”相匹配的价格&库存,您可以联系我们找货
