ACM4520F Series
SMD Common Mode Line Filters
FEATURES
Chip common mode filter for large current applications
Optimal for surface mounting with low profile 2.0 mm
The product series is designed for use up to 2.0A
Operating temperature -40~+125℃ (Including self - temperature rise)
RoHS Compliant
FEATURES
USB line for personal computers and periphera
IEEE 1394 line for personal computers, DVC, STB
LVDS, panel line for liquid display panels, graph card,etc.
Explanation of Part Number
ACM 4520 F- 900 T 32
1
2
3
4
5 6
♦ 1:Product Series:Wire Wound Chip Common Mode Filters
♦ 2:Dimensions:
♦ 3: Material Code:Ferrite
♦ 4:Common Mode Impedance(Ω)
♦ 5:Packing(Tape & Reel)
♦ 6:Rated Current:32=3200mA
Shapes and Dimensions
[Dimensions in mm]
4.7±0.5
2.0 Max
1.0 Typ
1.25 Typ
0.8 Typ
4.5±0.5
Marking
2.7 Typ
www.metal-lions.com
Land Pattern: [mm]
Equivalent circuit
1.0
3.0
2.0
6.0
Electrical Characterisitics:
Part Number
Common mode
Impedance
(Ω@100MHz)
DCR
(mΩ) max.
IDC
(A)max.
Rated Volt.
(Vdc)max.
IR
( Ω) min.
Marking
ACM4520F-900T32
60 Min
90 Typ
35
3.2
50
10M
900
ACM4520F-151T31
90 Min
150 Typ
40
3.1
50
10M
151
ACM4520F-231T30
180 Min
230 Typ
45
3.0
50
10M
231
ACM4520F-301T30
200 Min
300 Typ
45
3.0
50
10M
301
ACM4520F-401T25
300 Min
420 Typ
50
2.5
50
10M
401
ACM4520F-701T22
500 Min
700 Typ
59
2.2
50
10M
701
ACM4520F-901T21
650 Min
900 Typ
68
2.1
50
10M
901
ACM4520F-102T21
800 Min 1000 Typ
68
2.1
50
10M
102
ACM4520F-122T20 1000 Min 1200 Typ
74
2.0
50
10M
122
ACM4520F-142T19 1200 Min 1400 Typ
81
1.9
50
10M
142
www.metal-lions.com
Typical Electrical Characteristics:
ACM4520F-900T32
ACM4520F-151T31
ACM4520F-231T30
ACM4520F-301T30
www.metal-lions.com
ACM4520F-401T25
ACM4520F-701T22
ACM4520F-901T21
ACM4520F-102T21
www.metal-lions.com
ACM4520F-122T20
ACM4520F-142T19
Reliability Test
Mechanical Reliability
ITEM
Solderability
Shock
Specification & Requirement
The surface of terminal/pin tested shall
Solder heat proof:
be covered with new solder by 95%
Preheating: 180 ±10℃ 90 seconds
Soldering: 255 ±5℃ for 3 ±1 sec
Inductance change within ± 5% Without
Drop down with 981m/s2 (100G) shock
mechanical damage
Attitude upon a rubber block method
shock testing machinem, 3 tests.
Vibration
Method Used
mechanical damage
Vibration frequency:
10Hz to 55Hz to 10Hz 60 seconds cycle
Vibration time: 2 hours
www.metal-lions.com
Aging Reliability
ITEM
Thermal Shock
Method Used
-25℃, (30 mins) -> room temp. (5 mins) ->
mechanical damage
100℃, (30 mins) -> room temp. (5 mins)
100 cycles
Heat Resistance
Humidity
Resistance
Low Temp. Storing
High Temp.
Storing
Apply IDC current @ 85℃ ambient
mechanical damage
mechanical damage
Duration: 1000 hrs
Apply IDC current @ 60℃ ambient
Humidity: 90~95%
Duration: 1000 hrs
Storing Temp.
mechanical damage
-25 ±2 ℃ for total 1,000 +4/-0 hours
mechanical damage
Storing Temp.
100 ±2 ℃ for total 1,000 +4/-0 hours
Packaging
Tape width
12 mm
Packing Quantity
φ178mm reel T type : 1000 pcs./reel
www.metal-lions.com
Distance
8 mm
Pull-of force
10~120g
Recommended Reflow Pattern
Reflow : until two times
10sec. Max.
255℃
217℃
Natural cooling
150sec Max..
150℃
60sec. Min.
Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip directly touch
the ferrite body outside of terminal electrode.
5 seconds max. at 260℃.
www.metal-lions.com
很抱歉,暂时无法提供与“ACM4520F-102T21”相匹配的价格&库存,您可以联系我们找货
