ES3A-ES3M
Fast Recovery Rectifier Diode
»Features
Low reverse leakage
High forward surge capability
High current capability
High reliability
High surge current capability
Epitaxial construction
SMB(DO-214AA)
»General Description
Case: SMB molded plastic
Polarity: Color band denotes cathode
Epoxy: UL 94V-0 rate flame retardant
Lead: Pure tin plated, lead free
High temperature soldering guaranteed:260℃/10seconds
» Maximum Ratings and Characteristics @ TA = 25℃unless otherwise noted
SYMBOLS
ES3A
ES3B
ES3D
ES3G
ES3J
ES3K
ES3M
UNIT
Maximum Repetitive Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I(AV)
Non-repetitive peak forward surge
current 8.3 ms singlehalf sine-wave
IFSM
Parameter
Maximum forward voltage @ IF=3.0A
Maximum reverse current @VDC
TA=25℃
TA=125℃
Maximum Reverse Recovery Time
@ IF=0.5A, IR=1.0A, IRR=0.25A
A
3.0
80
VF
0.95
1.25
1.7
60
A
3.2
V
5.0
IR
µA
100
trr
35
nS
CJ
60
pF
RθJA
85
℃/W
Operating Junction Temperature Range
TJ
-55 to +150
Storage Tempetature Rang
Tstg
-55 to +150
Type junction capacitance
@VR=4.0V,f=1MHz
Typical Thermal Resistance (Note 1)
Note: (1)Thermal resistance from junction to ambient, PCB mounted.
Revision 2018
www.born-tw.com
1/3
ES3A-ES3M
»Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted))
TYPICAL FORWARD CHARACTERISTIC
FORWARD CURRENT DERATING CURVE
3.5
10
3
2.5
IF(AV) (A)
IF(A)
1
2
1.5
0.1
1
0.5
0.5
0.9
1.3
1.7
2.1
2.5
2.9
25
50
75
100
125
150
175
Ta(°C)
VF(V)
MAXIMUM NON REPETITIVE
TYPICAL REVERSE CHARACTERISTICS
PEAK FORWARD SURGE CURRENT
90
10
80
70
1
IR(uA)
IFSM(A)
60
50
40
30
0.1
Tj=25℃
1
10
100
0%
40%
60%
80%
100%
Percent Of Rated Peak Reverse voltage %
Number of Cycles at 60 Hz.
Revision 2018
20%
www.born-tw.com
2/3
ES3A-ES3M
»Package Information - SMB
B
D
C
A
F
H
L
G
Z
X
Y
SMB
Dimension
Inches
Millimeters
MIN
NOM
MAX
MIN
NOM
MAX
A
0.134
0.144
0.155
3.4
3.67
3.94
B
0.201
0.213
0.224
5.1
5.4
5.7
C
0.067
0.079
0.091
1.7
2
2.3
D
0.169
0.185
4.3
4.7
F
0.006
0.012
0.152
0.305
G
H
L
X
Y
Z
0.085
0.03
0.008
0.096
0.06
2.15
0.76
0.091
0.11
0.079
0.079
0.203
2.45
1.52
2.3
2.8
2
2
»Ordering information
Part Number
ES3A
ES3B
ES3D
ES3G
ES3J
ES3K
ES3M
Marking
ES3A
ES3B
ES3D
ES3G
ES3J
ES3K
ES3M
Base qty
3K
3K
3K
3K
3K
3K
3K
Revision 2018
www.born-tw.com
3/3
很抱歉,暂时无法提供与“ES3J”相匹配的价格&库存,您可以联系我们找货
