SD24C-01FTG
SD24C-01FTG
    ELECSUPER(静芯微)
    SOD-323
    ESD抑制器/TVS二极管 双向 24V 8A 350W SOD-323
SD24C-01FTG 数据手册
SD24C-01FTG Rev-1.3 www.elecsuper.com SuperESD - SD24C-01FTG 1. Description The SD24C-01FTG is a Transient Voltage Suppressor Arrays that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the IEC61000-4-2 air discharge method. 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Working voltage: 24V - ±30kV Contact Discharge  Low leakage current - ±30kV Air Discharge  RoHS compliant  Protecting one bidirectional  350W Peak pulse Power (8/20us)  Low clamping voltage 3. Applications  Portable electronics  CAN bus protection  Control & monitoring systems  Automotive application  Servers, notebooks, and desktop PCs  Cellular handsets and accessories 4. Ordering Information Part Number Package Marking Material Packing SD24C-01FTG SOD-323 2H Halogen free Tape & Reel Table-1 Quantity per reel 3,000 PCS Flammability Rating UL 94V-0 Reel Size 7 inches Ordering information 5. Pin Configuration and Functions Pin Name Description 1 IO Connect to IO 2 IO Connect to IO Outline 1 Table-2 Copyright© ElecSuper Incorporated 2H Circuit Diagram 2 1 2 Pin configuration Contact Us 1 / 7 SD24C-01FTG Rev-1.3 www.elecsuper.com 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 350 W Peak pulse current (tp=8/20us)@25℃ IPP 8 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±30 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±30 kV TJ - 150 ℃ Operating temperature TOP -40 125 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SD24C-01FTG Rev-1.3 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Reverse Stand-off Voltage Reverse Breakdown Voltage Conditions Min. Typ. VRWM VBR IT=1mA 26.0 Max. Units 24.0 V 28.0 V Reverse Leakage Current IR VRWM=24V Clamping Voltage VC IPP=1A; tp=8/20us 31.0 V Clamping Voltage VC IPP=8A; tp=8/20us 42.0 V Junction Capacitance CJ VR=0V; f=1MHz 18 pF Table-4 Symbol VRWM IR VBR 100 nA Electrical Characteristics Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP Copyright© ElecSuper Incorporated Contact Us 3 / 7 SD24C-01FTG Rev-1.3 www.elecsuper.com 7. Typical Characteristic Measurement Wave According to IEC Standard 8/20 μs pulse waveform according to ESD pulse waveform according to IEC 61000-4-5 IEC 61000-4-2 8. Typical Application Copyright© ElecSuper Incorporated Contact Us 4 / 7 SD24C-01FTG Rev-1.3 www.elecsuper.com Typical Interface Application of CAN Bus Protection 9. Dimension (SOD-323) Copyright© ElecSuper Incorporated Contact Us 5 / 7 SD24C-01FTG Rev-1.3 www.elecsuper.com E A b D A1 E1 A2 C L Symbol A A1 A2 b C D E E1 L L1 θ L1 θ Dimensions in Millimeters Min. Max. 1.000 0.000 0.100 0.800 0.900 0.250 0.350 0.080 0.150 1.200 1.400 1.600 1.800 2.550 2.750 0.475REF 0.250 0.400 0° 8° Copyright© ElecSuper Incorporated Contact Us Dimensions in Inches Min. Max. 0.039 0.000 0.004 0.031 0.035 0.010 0.014 0.003 0.006 0.047 0.055 0.063 0.071 0.100 0.108 0.019REF 0.010 0.016 0° 8° 6 / 7 SD24C-01FTG Rev-1.3 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
SD24C-01FTG 价格&库存
很抱歉,暂时无法提供与“SD24C-01FTG”相匹配的价格&库存,您可以联系我们找货
