FDN86246
Description
Product Summary
The FDN86246is the high cell density trenched Nch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The FDN86246meet the RoHS and Green Product
requirement with full function reliability approved.
CR
MI
JS
VDS
150
V
RDS(ON),max
280
mΩ
ID
1.8
A
SOT23 Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
D
O
c
mi
Se
Absolute Maximum Ratings
G
S
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
150
V
VGS
Gate-Source Voltage
ID@TA=25℃
IDM
PD@TA=25℃
V
Continuous Drain Current, VGS @
1.8
A
10V1
1.4
A
7.2
A
1.3
W
-55 to 150
-55 to 150
Pulsed Drain
Total Power
Current2
Dissipation3
c
du
on
ID@TA=70℃
±20
10V1
TSTG
Storage Temperature Range
TJ
Operating Junction Temperature Range
r
to
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
Thermal Resistance Junction-Case1
1
www.jsmsemi.com
Typ.
Max.
Unit
100
℃/W
80
℃/W
第1/5页
FDN86246
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Min.
Typ.
Max.
Unit
100
V
VGS=10V , ID=2A
240
280
VGS=4.5V , ID=1A
250
300
VGS=0V , ID=250uA
m
VGS=VDS , ID =250uA
1.0
2
2.5
V
Drain-Source Leakage Current
VDS=150V , VGS=0V , TJ=25℃
1
uA
IDSS
VDS=150V , VGS=0V , TJ=125℃
30
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Qg
Total Gate Charge (10V)
18
4.6
Gate-Drain Charge
5.7
Turn-On Delay Time
13
Qgd
Td(on)
Tr
Td(off)
Rise Time
VDD=75V , VGS=10V , RG=6
19
Turn-Off Delay Time
ID=2A
26
ns
9
840
119
25
Min.
Typ.
Max.
Unit
1.8
A
1.2
V
O
Input Capacitance
Crss
Reverse Transfer Capacitance
Diode Characteristics
Symbol
Parameter
Continuous Source Current1,4
Diode Forward
Voltage2
VDS=75V , VGS=0V , f=1MHz
c
mi
Se
Output Capacitance
VSD
nC
Fall Time
Coss
IS
VDS=75V , VGS=10V , ID=2A
Gate-Source Charge
c
du
on
Tf
Ciss
CR
MI
JS
Gate Threshold Voltage
IDSS
Qgs
Conditions
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
pF
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
r
to
www.jsmsemi.com
第2/5页
FDN86246
Typical Characteristics
O
CR
MI
JS
c
du
on
c
mi
Se
r
to
www.jsmsemi.com
第3/5页
FDN86246
O
CR
MI
JS
c
du
on
c
mi
Se
r
to
www.jsmsemi.com
第4/5页
FDN86246
Ordering Information
Part Number
FDN86246
Package code
SOT-23
Packaging
3000/Tape&Reel
O
CR
MI
JS
c
du
on
c
mi
Se
r
to
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“FDN86246”相匹配的价格&库存,您可以联系我们找货
