2
4
3
5
6
8
7
REV. ECN NO.
9
LOCAS.
DATE
A
A
A
孔位
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
定义正脚基准脚
0.50
定义正脚基准脚
0.20
A±0.1
B±0.1
15°
D±0.2
2.00
0.2
1.0
4.50
C
0.10
3.50
D
C±0.2
0.5*(n+1)±0.05
0.7
0.5*(n-1)±0.05
0.30
0.50
1.25
0.30±0.02
.3
R0
2-
6.0
4.5
2.0
E
1.8
F
0.7
0.5
PROPER CABLE (SCALE 2:1)
0.4
A±0.1
定义正脚基准脚
PC BOARD LAYOUT
技术要求(Technical Index):
H
1.材质与表面处理(Material And Finish):
基座(Housing)and 盖子(Cover):LCP UL94V-0 Nature Or Black;
端子(Terminal):Phosphor Copper Au/Sn Plated;
焊片(Solder):Copper Alloy Au/Sn Plated;
2.工作温度(Temperature range):-45°C~+85°C.
3.额定电压(Rated voltage):50V,AC/DC.
4.额定电流:0.4A,AC/DC.
5.接触电阻(Contact resistance):≤20mΩ.
6.绝缘电阻(Insulation resistance):≥500MΩ.
7.耐电压(Withstanding Voltage):200V AC/minute.
CHECK:
JUAN
APPROVED:
XKX
TOL
DIM
X.
±0.25
X.X
±0.20
X.XX
±0.15
1
2
3
4
5
6
7
A
B
C
D
1.50
2.00
2.50
3.00
3.50
4.00
4.50
5.00
5.50
6.00
6.50
7.00
7.50
8.00
8.50
9.00
9.50
10.00
10.50
11.00
11.50
12.00
12.50
13.00
13.50
14.00
14.50
15.00
15.50
16.00
16.50
17.00
17.50
18.00
18.50
19.00
19.50
20.00
20.50
21.00
21.50
22.00
22.50
23.00
23.50
24.00
24.50
25.00
25.50
26.00
26.50
27.00
27.50
28.00
28.50
29.00
29.50
2.60
3.10
3.60
4.10
4.60
5.10
5.60
6.10
6.60
7.10
7.60
8.10
8.60
9.10
9.60
10.10
10.60
11.10
11.60
12.10
12.60
13.10
13.60
14.10
14.60
15.10
15.60
16.10
16.60
17.10
17.60
18.10
18.60
19.10
19.60
20.10
20.60
21.10
21.60
22.10
22.60
23.10
23.60
24.10
24.60
25.10
25.60
26.10
26.60
27.10
27.60
28.10
28.60
29.10
29.60
30.10
30.60
6.35
6.85
7.35
7.85
8.35
8.85
9.35
9.85
10.35
10.85
11.35
11.85
12.35
12.85
13.35
13.85
14.35
14.85
15.35
15.85
16.35
16.85
17.35
17.85
18.35
18.85
19.35
19.85
20.35
20.85
21.35
21.85
22.35
22.85
23.35
23.85
24.35
24.85
25.35
25.85
26.35
26.85
27.35
27.85
28.35
28.85
29.35
29.85
30.35
30.85
31.35
31.85
32.35
32.85
33.35
33.85
34.35
7.65
8.15
8.65
9.15
9.65
10.15
10.65
11.15
11.65
12.15
12.65
13.15
13.65
14.15
14.65
15.15
15.65
16.15
16.65
17.15
17.65
18.15
18.65
19.15
19.65
20.15
20.65
21.15
21.65
22.15
22.65
23.15
23.65
24.15
24.65
25.15
25.65
26.15
26.65
27.15
27.65
28.15
28.65
29.15
29.65
30.15
30.65
31.15
31.65
32.15
32.65
33.15
33.65
34.15
34.65
35.15
35.65
B
C
D
E
F
G
深圳市钜硕电子有限公司
MANY
DESIGN:
X.XXX
DESIGN
22.12.01
B
G
11
10
DESCRIPTION
SHENZHEN JUSHUO ELECTRONIC CO.,LTD
TITLE:
DIM
TOL
X°.
X.X°
X.XX°
X.XXX°
±3.0°
0.5mm FPC 抽拉立贴正脚+吸盖
PART NO.
AFC11-S**ICA-00
SCALE:
REV. A
8
9
N/A
UNIT:
mm
10
H
SHEET:
1/1
11
很抱歉,暂时无法提供与“AFC11-S04ICA-00”相匹配的价格&库存,您可以联系我们找货
