EMI、EMC對策用元件
THIS SPECIFICATION IS APPLIED TO MULTILAYER FERRITE CHIP BEADS
BEAD0603SSJX601A20T
Product standard of spec sheet
寶仁弘電子有限公司 Prosperity Electronic Co., Limited
EML:brh@baorenhong.com Web:www.baorenhong.com
TEL:0755-29687188 FAX:0755-29688152
深圳市寶安區福永鎮立新二路天佑創客產業園
TEL:0512-36878535 FAX:0512-36878435
江蘇省昆山市花橋鎮綠地大道 1325號
BEAD0603SSJX601A20T
SAFETY REMINDERS
Note:This standard is the general industry standard, for customers' reference.
◆ Do not expose the products to magnets or magnetic fields.
◆ Use a wrist band to discharge static electricity in your body through the grounding wire.
◆ Carefully lay out the coil for the circuit board design of the non-magnetic shield type.A malfunction may occur
due to magnetic interference.
◆ Soldering corrections after mounting should be within the range of the conditions determined in the
specifications.If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
◆ When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not
given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw
tightening portions.
◆ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient
for the set thermal design.
◆ Before soldering, be sure to preheat components.The preheating temperature should be set so that the
temperature difference between the solder temperature and chip temperature does not exceed 150°C.
◆ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
◆ The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C,
Humidity: 10 to 75% RH or less).
◆ When designing your equipment even for general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/device or providing backup circuits in your equipment.
◆ Do not use for a purpose outside of the contents regulated in the delivery specifications.
◆ The products listed on this catalog are intended for use in general electronic equipment (AV equipment,
telecommunications equipment, home appliances, amusement equipment, computer equipment, personal
equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use
condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose
performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or
trouble could cause serious damage to society, person or property.
Web Site:http://www.baorenhong.com
BEAD0603SSJX601A20T
PRODUCT OVERVIEW
◎ Part Number Construction 產品描述:
BEAD 0603 S SJX601 A 20 T
BEAD--------Series name 系列名稱
0603---------Dimension 產品尺寸
S-------------Material code 材料代碼
SJX601------Impedance 阻抗值 600Ω
A-------------High current 耐大電流
20------------Current value 電流值2A
T-------------Taping 編帶盤裝
版本:A3.2
首次承認
發行編號:BE20241217A3587-AB01
繪圖:潘陽陽 小姐
審核:羅國良 先生
核準:魏庭 先生
BEAD0603SSJX601A20T
PRODUCT OVERVIEW
◎ Shape&Dimensions 形狀與尺寸:
UNIT:mm
PART NUMBER
A
B
C
D
CHIPS REEL
0402
1.00±0.10
0.50±0.10
0.50±0.10
0.25±0.10
10K
0603
1.60±0.20
0.80±0.20
0.80±0.20
0.30±0.20
4K
0805
2.00±0.20
1.20±0.20
0.90±0.20
0.50±0.30
4K
1206
3.20±0.20
1.60±0.20
1.10±0.20
0.50±0.30
3K
1210
3.20±0.20
2.50±0.20
1.30±0.20
0.50±0.30
2K
1806
4.50±0.20
1.60±0.20
1.60±0.20
0.50±0.30
2K
1812
4.50±0.20
3.20±0.20
1.50±0.20
0.50±0.30
1K
◎ Recommended Land Pattern 推薦焊盤布局:
UNIT:mm
PART NUMBER
A
B
C
0402
0.4
2.2
0.7
0603
0.5
2.5
1.1
0805
0.7
3.8
1.5
1206
1.2
4.5
1.8
1210
1.2
4.5
2.7
1806
1.8
5.8
1.8
1812
1.8
5.8
3.4
BEAD0603SSJX601A20T
ELECTRICAL CHARACTERISTICS
◎ Characteristics Specification Table 特性規格表:
ORDERING CORE
Impedance (Ω)
Test Frequency (Hz)
DC Resistance (Ω)MAX
Rated Current (mA)MAX
BEAD0603SSJX601A20T
600±25%
60mV / 100M
0.100
2000
Standard Testing Condition:
Temperature:Ordinary Temperature(15 to 35℃),In case of doubt:20±2℃
Humidity:Ordinary Humidity(25 to 85% RH),In case of doubt:60 to 70 % RH
BEAD0603SSJX601A20T
TEST DATA OF PREPRODUCTION SAMPLES
◎ Test Data Of Preproduction Samples 樣品測試數據:
MEAS.Item
Z (Ω)
RDC (Ω)
A mm
B mm
C mm
D mm
Ref value
600±25%
0.1 MAX
1.00±0.10
0.50±0.10
0.50±0.10
0.25±0.10
1
580.55
0.070
1.64
0.81
0.82
0.31
2
599.21
0.083
1.66
0.81
0.81
0.28
3
600.01
0.075
1.66
0.82
0.81
0.32
4
581.26
0.082
1.64
0.80
0.80
0.29
5
599.75
0.080
1.65
0.83
0.81
0.29
6
600.03
0.077
1.64
0.81
0.81
0.31
7
580.49
0.083
1.65
0.84
0.83
0.30
8
599.89
0.070
1.66
0.81
0.83
0.31
9
588.79
0.082
1.63
0.81
0.80
0.29
10
580.54
0.075
1.63
0.83
0.81
0.28
X
591.05
0.078
1.65
0.82
0.81
0.30
R
19.54
0.013
0.03
0.04
0.03
0.04
Test instruments:
Impedance : HP 4291B RF Impedance/Material analyzer
RDC : HIOKI 3540
at 100MHz 60mV
The test data above is only for reference,actual results may differ due to different production batches.
BEAD0603SSJX601A20T
THE TEST CURVE
◎ The Test Curve 樣品測試曲線:
RELIABILITY TEST
100% Pure matte- tin solder terminal Plating.
Pb contain of solder terminal less than 1000ppm
Rework temperature:350℃ 3-5 seconds ok.
Operating Temperature Range:-40℃ to +125℃.
Storage Temperature Range:-40℃ to +125℃.
(For products in unopened tape package 0℃ to +40℃. )
RELIABILITY TEST
Item
Performance
Test Condition
Preheat:150℃,60 seconds
1. The chip shall not be cracks .
Soldering heat
resistance
2. More than 75% of terminal electrode
shall be covered with solder.
Solder: Sn/Ag/Cu
Solder:temperature:260 ±5℃
Flux: Rosin
Dip time:5±0.5 seconds
3. Impedance: within±20% of the
initial value.
4. Inductance: within±10% of the
initial value.
Solder ability
More than 90% of the terminal
electrode shall be covered with new
solder.
The terminal eletrode and the ferrite
shall not be damaged by the forces
applied on the right conditions.
Terminal Strength
RELIABILITY TEST
Item
Performance
Test Condition
The ferrite shall not be damaged by
the forces applied on the right
conditions.
Bending strength
Appearance: Ferrite shall not be
damaged.
Temperature:100℃
Impedance : Within ±20% of the initial
Testing time: 1008 hours.
value.
Inductance : Within ±10% of the initial
Measurement: After placing for 24 hours min.
value.
High temperature Q: Within±30% of the initial value.
resistance
This test procedure was according to
JESD22-A103-A
Impedance: Within±20% of the initial
value.
Temperature:-40℃
Inductance: Within±10% of the initial
value.
Appearance: cracking, chipping or any
other defects harmful to the
Low temperature
characteristics shall not be allowed.
resistance
RELIABILITY TEST
Item
Performance
damaged.
Test Condition
Humidity:95%RH
Temperature:60℃
value.
value.
Humidity
resistance
MIL-STD-202F method 103D
Appearance: Cracking, chipping or any
Temperature:100℃
Impedance: Within ±30% of the initial
value.
Inductance: Within ±10% of the initial
value.
Thermal shock
MIL-STD-883D method 1010.7
BEAD0603SSJX601A20T
SOLDERING AND MOUNTING
● Mildly activated rosin fluxes are preferred. If hand soldering cannot be avoided, the preferred
technique is the utilization of hot air soldering tools.
1.Recommended temperature profiles for re-flow soldering
Standard Profile
Pre – heating
Limit Profile
150~180℃,90S±30S
Heating
Above 220℃, 30s-60s
Above 217℃,60s-150s
Peak temperature
245±3℃
260℃,10s
Cycle of reflow
2 times
2 times
2.Flux,Solder
Use rosin-based flux
Don’t use high acidic flux with halide content exceeding 0.2(wt)% (chlorine conversion value).
Use lead-free solder, use Sn-3.0Ag-0.5Cu solder
Standard thickness of solder paste: 0.12~0.15mm
3.Reworking with soldering iron
The following conditions must be strictly followed when using a soldering iron.
Pre – heating
150℃, 1 minute
Tip temperature
350℃ max.
Soldering iron output
30w max.
End of soldering iron
3mm max.
Soldering time
3 seconds max.
CLEANING CONDITIONS
● Products should be cleaned on the following conditions.
Cleaning temperature shall be limited to 60℃max. (40℃ max for fluoride and alcohol type
cleaner.)
Ultrasonic cleaning shall comply with the
following conditions with avoiding the
resonance phenomenon at the mounted
products and P.C.B.
Cleaner
Cleaning Conditions:
Power: 20 w / liter max.
Frequency:28 kHz ~ 40 kHz
Time:5 minutes max.
◎Alcohol cleanerIsopropyl alcohol ( IPA)
◎Aqueous agentPINE ALPHA ST – 100S
Do not clean after soldering. Some cleaning agents may
degrade bonding strength,and characteristics of products by
detaching. If cleaning,please contact us.
There shall be no residual flux and residual cleaner after cleaning, extra flux maybe affect
the electrical characteristics. In the case of using aqueous agent, products shall be dried
completely after rinse with de-ionized water in order to remove the cleaner.
ATTENTION REGARDING P.C.B BENDING
The following shall be considered when designing and laying out P.C.B.
P.C.B shall be designed so that products are not subjected to the mechanical stress due to
warping the board.
Products direction
Products shall be located in the sideways direction to the mechanical stress.
Poor example
Good example
Products location on P.C.B. separation.
Products shall be located carefully so that products are not subjected to the mechanical
stress due to warping the board. Because they may be subjected the mechanical stress in
magnitude of A > C > B D.
RESIN COATING
The electrical characteristics may be changed due to the large cure-stress of the resin to
be used for coating/molding products. Some resin contains some impurities or chloride
possible to generate chlorine by hydrolysis under some operating condition may cause
corrosion of wire of coil ,leading to open circuit. So please pay your careful attention in
selecting resin to prevent any affection on the product in case of coating/molding the
products with the resin. In prior to use,please make the reliability evaluation with the
product mounted in your application set.
CAUTION FOR USE
Limitation of Applications
Please contact us before using our products for the applications listed below which require
especially high reliability for the prevention of defects which might directly cause damage
to the third party’s life, body or property.
1.Aircraft equipment
2.Aerospace equipment
3.Undersea equipment
4.Power plant control equipment
5.Medical equipment
Requirements to the applications listed in the above.
6. Transportation equipment (vehicles, trains, ships, etc.)
7. Traffic signal equipment
8. Disaster prevention / crime prevention equipment
9. Data-processing equipment
10. Applications of similar complexity and / or reliability
There is possibility that the inductance value change due to magnetism. Don’t use a
magnet or a pair of tweezers with magnetism when chip coil are handled. (The tip of the
tweezers should de molded with resin or pottery.)
Sharp material, such as a pair of tweezers, shall not be touched to the winding portion to
prevent the breaking of wire.
Mechanical shock should not be applied to the products mounted on the board to prevent
the breaking of the core.
STORAGE AND HANDLING REQUIREMENTS
Storage period
Products should be used in 6 months from the day of PROSPERITY ELECTRONICS CO.,LTD
outgoing inspection. Solerability should be checked if this period is exceeded.
Storage conditions
Products should be storage in the warehouse on the following conditions.
Temperature : 0 ~ 40℃
Humidity : 55 ~ 70% relative humidity
No rapid change on temperature and humidity
Don’t keep products in corrosive gases such as sulfur, chlorine gas or acid, or it may cause
oxidation of electrode, resulting in poor solderability.
Products should be stored on the palette for the prevention of the influence from humidity,
dust and so on.
Products should be stored in the warehouse without heat shock, vibration, direct sunlight
etc.
Products should be stored under the airtight package condition.
Handling Condition
Care should be taken when transporting of handling product to avoid excessive vibration
or mechanical shock.
CONSTRUCTION AND COMPOSITION AND LEAD FREE DETAIL OF BEAD SERIESE
Construction and composition of BEAD
Outer Terminal Paste
Inner Circuit
Ferrite Ceramic Body
Construction
Position
Outer Terminal
Paste
Material composition
total%
Pb Limit
Silver + Glass
10wt%
