15.8±0.2
13.4
3.5
3
5
4
7
3
3.5±0.3
3
2
4.1±0.3
1
14.3±0.2
1.45
∅12.7
2-2
4
Main technical characteristics and requirements:
1. Use temperature range:
Ambient temperature:-25 ~+70℃
Relative humidity: 95%(40℃)
2. Rated load: 7.5A 20V DC
3. Contact resistance: ≤ 30mΩ
4. Insulation resistance: ≥100MΩ
5. Withstand voltage: 250V AC(50Hz)1min.
6. Plugging force: 10 ~ 50N
7. life Life: 5000 times
2.5
2
主要技术特性要求:
1.使用温度范围:
环境温度:-25~+70℃
相对湿度:95%(40℃)
2.额定负荷:7.5A 20V DC
3.接触电阻:≤30mΩ
4.绝缘电阻:≥100MΩ
5.耐
压:250V AC(50Hz)1min
6.插 拔 力:10~50N
7.寿
命:5000次
1.7±0.3
1.8
2-∅1.5
3.3±0.3
2-2
7.1±0.3
5±0.2
5.5±0.2
10.85±0.3
15.4±0.2
11.8±0.3
PCB板安装孔图
15.4
9-2.5
×0.8
5.5
1
3.5
S
5
11.8
7.1
4
1.7
3.3
3
∅1.6 +0.1
10.85
2
8
Round wrapping
1
H62
7
Iron shell
1
SPCC
D.Cu/Sn
6
Left long needle
1
H62
Y1=0.28mm
D.Cu/Sn
5
Right short needle
1
H62
Y1=0.28mm
D.Cu/Sn
4
Right long needle
1
H62
Y1=0.28mm
D.Cu/Sn
3
Left short needle
1
H62
Y1=0.28mm
D.Cu/Sn
2
back cover 1
1
Serial
Number
Base
1
name
number
D.Cu/Sn
Y=0.35mm
BLACK
PA6T
PA6T
BLACK
Material Science
handle
single piece
total
Quality
remarks
Wenzhou Mingheng Electronic Technology Co., Ltd
MPC-4-02
HX/13MPC402
Technical Characteristics Specification
Scope of application
This technical specification book is applicable to S-terminal sockets, and the product is
suitable for the output and input of audio and video signals, and is used for plugging.
Appearance size
The appearance and internal structure fit (tolerance) dimensions of this product are subject to the drawings.
material
All materials and surface treatments specified in the drawings shall prevail.
operational environment
Temperature:-25 ~ 70℃
Relative humidity: < 95%(40℃)
PH value: PH6~8
Electrical appliance performance index
serial number
item eye
technical condition
technical requirement
7.5A
20V
rated load
preparefill
250V
pressure proof
contact resistance
No abnormality, no breakdown and arcing.
At a frequency of
1000HzCurrent < 100mA
Voltage = 20 V
insulance
Mechanical performance index
serial number
item eye
insertion force
technical condition
Use a standard plug, insert it
for 3 times and then determine.
Use the standard plug, pull it out
withdrawal force
preparefill
10-50N
10-50N
for 3 times and then measure it.
Appearance: No deformation or looseness.
Contact resistance ≤30mΩ
Insulation resistance ≥ 100MΩ
Terminal strength
Add a static load of 10N for 1min,
in any direction.
250V
Withstand voltage: AC250V,1min
without breakdown and arcing.
serial number
item eye
technical condition
preparefill
Contact resistance ≤50mΩ
250V
mechanical life
serial number
item eye
Plug and unplug 5000 times under no load,
Plug-in speed: 10~20 times /min
technical condition
Using weld groove method
Temperature: 230±5℃
weldability test
Time: 3±0.5s
10-50N
The insertion force is 10-50N.
10-50N
Pull-out force 10-50N
preparefill
Welding lubrication time ≤3s.
Tin-stained area of terminal ≥95%
Temperature: 260±5℃
Welding resistance test
serial number
item eye
250V
Time: 10±1s
technical condition
10-50N
10-50N
preparefill
The temperature is about 70℃,
keep it under standard
atmospheric conditions for 96h,
and resume the test for 1h.
heat resistance
250V
10-50N
10-50N
Terminal strength: 10N,
no deformation or damage
in appearance for 1min.
250V
Vibration resistance
Frequency: 10 ~ 55hz sweep
cycleDouble amplitude: 15minOn
three mutually perpendicular axes,
each axis vibrates for 2h,
totaling 6h.
10-50N
10-50N
很抱歉,暂时无法提供与“MPC-4-02”相匹配的价格&库存,您可以联系我们找货
