Antennas
Product Datasheet
2JE28
CELLULAR / LTE Surface Mount
Key Features
CELLULAR / LTE
- 698-960 MHz
- 1710-2170 MHz
- 2500-2700 MHz
Surface Mount
Left Feed
High Performance
Fiberglass Material
Ground Plane Dependent
Dimensions 40 × 8 × 3 mm
www.2j-antennas.com
Page: 1/15
Antennas
1. Antenna and electrical specifications
CELLULAR / LTE Antenna
Parameters
2G,3G and 4G
Standards
Band (MHz)
Frequency (MHz)
700/850/900
1700/1800/1900/2100
2600
698-960
1710-2170
2500-2700
Return Loss (dB)
~-7.6
~-11.2
~-14.9
VSWR
~2.6:1
~1.8:1
~1.5:1
Efficiency (%)
~58
~70
~65
Peak Gain (dBi)
~2.5
~3.1
~3.5
Average Gain (dB)
~-2.6
~-1.7
~-2.1
Impendance (Ohm)
Polarisation
Radiation Pattern
Max. Input Power (W)
50
Linear
Omni-Directional
25
Antenna Measurement Conditions:
Mounted on ground plane of 110 x 40 mm
Measured in Certified CTIA 3D Anechoic Chamber
2. Mechanical and environmental specifications
Specifications
2JE28
Mounting Type
Surface Mount
Dimensions (mm)
40 × 8 × 3
Material
Fiberglass
Operating Temperature (C)
-40 to +105
Storage Temperature (C)
-40 to +85
Storage Relative Humidity (%)
Substance Compliance
Typical Shear Force Test
www.2j-antennas.com
Up to 93 at 30 C
RoHS
50 kgf according to IEC62137-1-2:2007
Page: 2/15
Antennas
3. Antenna parameters
Return Loss (dB)
-10
-15
600 700 800 900 1000 1100 1200 1300 1400 1500 1600 1700 1800 1900 2000 2100 2200 2300 2400 2500 2600 2700 2800
Frequency (MHz)
6
5
VSWR
4
3
2
1
Frequency (MHz)
www.2j-antennas.com
Page: 3/15
Antennas
90
80
Efficiency (%)
70
60
50
40
30
Frequency (MHz)
5
Peak Gain (dBi)
4
3
2
1
Frequency (MHz)
www.2j-antennas.com
Page: 4/15
Antennas
Average Gain (dB)
-1
-2
-3
-4
Frequency (MHz)
Z
X
Y
Radiation pattern reference
www.2j-antennas.com
Page: 5/15
Antennas
740 and 840 MHz Radiation pattern
940 and 1750 MHz Radiation pattern
www.2j-antennas.com
Page: 6/15
Antennas
1850 and 1950 MHz Radiation pattern
2100 and 2600 MHz Radiation pattern
www.2j-antennas.com
Page: 7/15
Antennas
4. PCB Layout
40.0
15.0
Minimum area required for antenna integration (40mm × 15mm)
40.0±0.1
11.5
2.5
2.5
1.5
2.5
8.0±0.1
11.5
8.6
1.5
1.5
1.5
12.0
2.6
2.5
Layout dimensions for
antenna integration (mm)
2.5
1.5
9.6
2.5
1.5
12.0
2.6
2.5
2.5
1.5
1.5
5.6
7.0
0.5
5.9
0.4
2.8
7.2
1.1
Layout dimensions for antenna integration (mm)
www.2j-antennas.com
Page: 8/15
Antennas
5. Matching Network
Matching network drawing
3D View of matching components and recommended values
www.2j-antennas.com
Page: 9/15
Antennas
6. Evaluation Board
125mm x 40.4mm
125mm x 40.4mm
125mm x 40.4mm
Front View without Antenna
Front View with Antenna
Back View
www.2j-antennas.com
125mm x 40.4mm
(PCB: 1.0mm, Antenna: 3mm,
Connector: 9.5mm)
Side View
Page: 10/15
Antennas
7. Packaging
PACKAGING SPECIFICATION
Antenna
2JE28
REEL
Max Quantity per Reel
1000
REEL CARTON
Reels per Carton
Max Quantity per Carton
Reel Carton Dimensions (cm)
Reel Carton Weight (Kg)
2
2000
36.5 x 36.5 x 16
5,6
PALLET
Max Cartons per Pallet
42
Cartons per Layer
6
Number of Layers
7
Max Quantities per Pallet
Total Cartons Dimensions (cm)
Total Cartons Weight (Kg)
84,000
109.5 x 73 x 112
235,2
Pallet size and weight not included above
Typical Pallet Size (cm)
Typical Pallet Weight (Kg)
120 x 100 x 14.4
5-25
8. Tape and Reel Information
Tape and Reel Specifications
www.2j-antennas.com
Page: 11/15
Antennas
REFLOW TEMPERATURE PROFILE
Minimum Recommended Reflow Profile
Controlled hot air convection
Method of heat transfer
1
Average temperature gradient in preheating
2
Soak time
3
Max temperature gradient in reflow
4
Time above 217 °C
5
Peak temperature in reflow
6
Temperature gradient in cooling
2.5 °C/s
2-3 minutes
3 °C/s
Max 30 sec
230 °C for 10 seconds
Max -5 °C/s
Not to scale. For reference only.
5
3
200
4
Temperature / oC
6
2
100
100
150
200
250
300
Time / s
www.2j-antennas.com
Page: 12/15
Antennas
Maximum Recommended Reflow Profile
2.5 °C/s
1
2
Soak time
3
4
Time above 217 °C
Max 60 sec
5
Time above 230 °C
Max 50 sec
6
Time above 250 °C
Max 10 sec
7
8
2-3 minutes
3 °C/s
260 °C for 5 seconds
Max -5 °C/s
300
7
250
3
4-6
Temperature / oC
200
8
2
150
1
100
50
100
150
200
250
300
Time / s
www.2j-antennas.com
Page: 13/15
Antennas
8 ±0,20
3x
1,
50
9. Antenna drawings
R0
,7
5
Top View
9
40 ±0,20
3 ±0,20
Front View
soldering pads
Bottom View
soldering pads
3 ±0,20
Back View
Dimensions for fiberglass antenna 40 × 8 × 3 mm +/-0.2mm
www.2j-antennas.com
Page: 14/15
Antennas
10. Antenna Images
www.2j-antennas.com
Page: 15/15
很抱歉,暂时无法提供与“2JE28”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.72064
- 10+11.95404
- 11+9.92976
- 30+9.40273
- 50+9.39075
- 200+9.19910
