KBPC3510
KBPC3510
    HYELECTRONIC(虹扬)
    KBPC
    桥式整流器/整流桥 1KV 35A KBPC
KBPC3510 数据手册
KBPC10/15/25/35/50A SERIES REVERSE VOLTAGE SILICON BRIDGE RECTIFIERS - 50 to 1000Volts FORWARD CURRENT - 10/15/25/35/50 Amperes KBPC FEATURES ●Surge overload -240~500 Amperes peak .442(11.23) .424(10.77) ● Low forward voltage drop ● Mounting Position : Any .921(23.4) .882(22.4) ● Electrically isolated base -2000 Volts 0.94 (2.4) diam ● Solderable 0.25" FAST ON terminals ● Materials used carries U/L recognition .035(0.9) .028(0.7) .254(6.45) .242(6.15) 1.133(28.8) 1.114(28.3) .673(17.1) .634(16.1) Hole for No.8 screw 193"(4.9)diam .673(17.1) .634(16.1) 1.133(28.8) 1.114(28.3) .732(18.6) .693(17.6) .583(14.8) .543(13.8) Dimensions in inches and (milimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ ambient temperature unless otherwise specified. Resistive or inductive load 60Hz. For capacitive load current by 20% CHARACTERISTICS SYMBOL KBPC KBPC KBPC KBPC KBPC KBPC KBPC 10005 1001 1002 1004 1006 1008 1010 15005 1501 1502 1504 1506 1508 1510 25005 2501 2502 2504 2506 2508 2510 35005 3501 3502 3504 3506 3508 3510 50005 5001 5002 5004 5006 5008 5010 UNIT Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Bridge Input Voltage VRMS 35 70 140 280 420 560 700 V Maximum Average Forward Rectified Output Current Peak Forward Surge Current @T C=55℃ 8.3ms Single Half Sine-Wave I(AV) 10 KBPC 10 IFSM 240 KBPC 15 15 300 25 KBPC 25 400 35 KBPC 35 400 KBPC 50 50 A 500 A Super Imposed on Rated Load Maximum Forward Voltage Drop Per Element at 5.0/7.5/12.5/17.5/25.0A Peak Maximum Reverse Current at Rate DC Blocking Voltage Per Element @T J=25℃ Operating Temperature Range Storage Temperature Range VF 1.1 V IR 10 μA TJ -55 to +150 ℃ TSTG -55 to +150 ℃ REV. 6, 30-Dec-2014 ~ 436 ~ RATING AND CHARACTERISTIC CURVES KBPC10/15/25/35/50A SERIES FIG.2- DERATING CURVE OUTPUT RECTIFIED CURRENT FIG.1-MAXIMUM FORWARD SURGE CURRENT 500 KBPC50 400 KBPC25/35 300 KBPC15 200 100 KBPC10 0 10 1 100 AVERAGE FORWARD OUTPUT CURRENT , AMPERES PEAK FORWARD SURGE CURRENT AMPERES 600 50 KBPC50 40 30 20 10 KBPC35 KBPC25 KBPC15 KBPC10 0 50 NUMBER OF CYCLETS AT 60Hz 150 100 CASE TEMPERATURE,°C FIG.3-TYPICAL FORWARD CHARACTERISTICS KBPC35/50 FIG.4-TYPICAL REVERSE CHARACTERISTICS KBPC15 100 KBPC25 KBPC10 INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT , AMPERES 10 10 1.0 0.1 1.0 TJ=25℃ 0.1 0.01 0 0.01 0.4 0.6 0.8 1.0 1.2 1.4 20 40 60 80 100 120 140 1.6 PERCENT OF RATED PEAK REVERSE VOLTAGE INSTANTANEOUS FORWARD VOLTAGE,VOLTS The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! REV. 6, 30-Dec-2014 ~ 437 ~
KBPC3510 价格&库存
很抱歉,暂时无法提供与“KBPC3510”相匹配的价格&库存,您可以联系我们找货
KBPC3510
  • 10+36.86763
  • 20+36.61145
  • 100+30.13101
库存:2280
KBPC3510
  • 50+35.16145
  • 250+31.64480
库存:900
