2CL71MT
5.0mA 8.0kV 80nS
SMD High Voltage Silicon Rectifier Diode
----------------------------------------------------------------------------------------------------------------------------- ------INTRODUCE:
SHAPE DISPLAY:
HVGT high voltage silicon rectifier diodes is made
of high quality silicon wafer chip and high
reliability epoxy resin sealing structure, and
through professional testing equipment inspection
qualified after
to
customers.
FEATURES:
1. Fast recovery.
2. High reliability design.
3. SMD encapsulation.
4. Conform to RoHS and SGS.
5. Epoxy resin molded in vacuumHave
HVGT
NAME:
SMA
anticorrosion in the surface.
APPLICATIONS:
1. Air purification, negative ions.
2. Electrostatic voltage doubling circuit .
3. Other high voltage rectifier circuits.
4. Copier and X-ray.
MECHANICAL DATA:
1. Case: epoxy resin molding.
2. Terminal: Radial vane.
3. Net weight: 0.06 grams (approx).
MAXIMUM RATINGS AND CHARACTERISTICS:
Items
(Absolute Maximum Ratings)
Symbols
Condition
Data Value
Units
Repetitive Peak Renerse Voltage
VRRM
TA=25°C
8.0
kV
Non-Repetitive Peak Renerse Voltage
VRSM
TA=25°C
8.8
kV
Average Forward Current Maximum
IFAVM
TA=25°C
5.0
mA
TOIL=55°C
mA
Non-Repetitive Forward Surge Current
IFSM
TA=25°C; 60Hz Half-Sine Wave; 8.3mS
0.5
A
Junction Temperature
TJ
125
°C
Allowable Operation Case Temperature
Tc
-40~+125
°C
TSTG
-40~+150
°C
Storage Temperature
ELECTRICAL CHARACTERISTICS:
Items
Maximum Forward Voltage Drop
Maximum Reverse Current
Maximum Reverse Recovery Time
Junction Capacitance
TA=25°C
(Unless Otherwise Specified)
Symbols
Condition
Data value
Units
VFM
at 25°C; at IFAVM
V
IR1
at 25°C; at VRRM
2.0
uA
IR2
at 100°C; at VRRM
50
uA
TRR
at 25°C; IF=0.5IR; IR =IFAVM; IRR =0.25IR
80
nS
CJ
at 25°C; VR=0V; f=1MHz
1.0
pF
GETE ELECTRONIC CO.,LTD Http://www.getedz.com Http://www.hvgtsemi.com E-mai: sales@getedz.com
GETAI ELECTRONIC DEVICE CO.,LTD TEL:0086-20-8184 9628 FAX:0086-20-8184 9638 2020-08 1 / 2
2CL71MT
5.0mA 8.0kV 80nS
----------------------------------------------------------------------------------------------------------------------------- ------Forward Current Derating Curve
Reverse Recovery Measurement Waveform
Average Forward Current-%
125
TRR
100
IF
75
IRR
25
50
75
100
125
Temperature(℃)
150
175
IR
Typical data capture points: IF =0.5IR , IR,IRR =0.25IR
IR is typically the rated average forward current maximum
(IFAVM) of the D.U.T
Non-Repetitive Surge Current
100
75
Peak
Forward
Surge
Current
50
25
10
Cycles (60Hz)
Type
Marking
2CL71MT
NOTES:
1. Minimum packing quantity:2,000PCS
2. Specifications based on diode P.C.B. mounted on 5.0 mm x 5.0 mm
100
Code
Cathode Mark
MT08
HVGT
copper solder pads.
GETAI ELECTRONIC DEVICE CO.,LTD TEL:0086-20-8184 9628 FAX:0086-20-8184 9638 2020-08 2 / 2
很抱歉,暂时无法提供与“2CL71MT”相匹配的价格&库存,您可以联系我们找货
