ZD24C128A-SSGMB
ZD24C128A-SSGMB
    ZETTA(澜智)
    SOP-8
    EEPROM存储器 1.7V~5.5V 128Kbit SOP-8
ZD24C128A-SSGMB 数据手册
Zetta        ZD24C128A ZD24C128A   I2C-Compatible (2-wire) Serial EEPROM  128-Kbit (16,384 x 8)  DATASHEET  Features    Low Voltage Operation   ̶ VCC = 1.7V to 5.5V     Internally Organized as 16,384 x 8 (128K)  Additional Write lockable page  I2C-compatible (2-wire) Serial Interface  ̶ 100kHz Standard Mode, 1.7V to 5.5V  ̶ 400kHz Fast Mode, 1.7V to 5.5V  ̶ 1MHz Fast Mode Plus (FM+), 2.5V to 5.5V       Schmitt Trigger Filtered Inputs for Noise Suppression  Bidirectional Data Transfer Protocol  Write Protect Pin for Full Array Hardware Data Protection  Ultra Low Active Current (300μA max) and Standby Current (0.5μA Max)  64-byte Page Write Mode   ̶ Partial Page Writes Allowed     Random and Sequential Read Modes  Self-timed Write Cycle Within 5ms Max  High Reliability  ̶ Endurance: 1,000,000 Write Cycles  ̶ Data Retention: 100 Years   Green Package Options (Lead-free/Halide-free/RoHS Compliant)  ̶ 8-lead SOIC, 8-lead TSSOP, 8-pad UDFN, 8-lead PDIP, 5-lead SOT23   Die Sale Options: Wafer Form and Tape and Reel Available   Identification Page Options(Contact our sales for details)  Description   The ZD24C128A provides 131,072 bits of Serial Electrically Erasable and Programmable Read-Only Memory (EEPROM) organized as 16,384 words of 8 bits each. The device offers an additional page, named the Identification Page(64 bytes). The Identification Page can be used to store sensitive application parameters which can be (later) permanently locked in Read-only mode. The device’s cascadable feature allows more devices to share a common 2wire bus. This device is optimized for use in many industrial and commercial applications where low-power and low voltage operation are essential. The device is available in space-saving 8-lead SOIC, 8-lead TSSOP, 8-pad UDFN, 8-lead PDIP(1), 5-lead SOT23, and 8-ball UDFN packages. The entire family of packages operates from 1.7V to 5.5V.   Note: 1.Contact Sales for the availability of this package.    ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  1 / 28  Zetta        ZD24C128A 1. Pin Descriptions and Pinouts Table 1-1.Pin Descriptions Pin   Number  1, 2, 3  4  Pin   Symbol  A0, A1, A2  GND  Pin Name and Functional Description Device Address Input: The A2 pin is used to select the hardware device address and correspond to the fifth bit of the I2C seven bit slave address. This pin can be directly connected to VCC or GND, allowing up to two devices on the same bus. Ground: The ground reference for the power supply. GND should be connected to the system ground.  Asserted State  Pin Type —  Input  —  Power  —  Input/ Output —  Input  High  Input  —  Power  Serial Data: The SDA pin is an open-drain bidirectional input/output pin used to serially transfer data to and from the device.  5  6  SDA  SCL  The SDA pin must be pulled-high using an external pull-up resistor (not to exceed 10KΩ in value) and may be wire-ORed with any number of other open-drain or open-collector pins from other devices on the same bus.  Serial Clock: The SCL pin is used to provide a clock to the device and to control the flow of data to and from the device. Command and input data present on the SDA pin is always latched in on the rising edge of SCL, while output data on the SDA pin is clocked out on the falling edge of SCL.  The SCL pin must either be forced high when the serial bus is idle or pulledhigh using an external pull-up resistor.  7  WP  Write Protect: Connecting the WP pin to GND will ensure normal write operations. When the WP pin is connected to VCC, all write operations to the memory are inhibited.   Refer to Note 1 for behavior of the pin when not connected.  8    VCC  Device Power Supply: The VCC pin is used to supply the source voltage to the device. Operations at invalid VCC voltages may produce spurious results and should not be attempted.  Note:1. If the WP pin is not driven, it is internally pulled down to GND. In order to operate in a wide variety of application environments, the pull-down mechanism is intentionally designed to be somewhat strong. Once these pins are biased above the CMOS input buffer’s trip point (~0.5 x VCC), the pull-down mechanism disengages. Zetta recommends connecting these pins to a known state whenever possible.          ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  2 / 28  Zetta        ZD24C128A                             2. Device Block Diagram and System Configuration   Figure 2-2. System Configuration Using 2-Wire Serial EEPROMs       ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  3 / 28  Zetta        ZD24C128A 3. Device Operation and Communication   The ZD24C128A operates as a slave device and utilizes a simple I2C-compatible 2-wire digital serial interface to communicate with a host controller, commonly referred to as the bus Master. The Master initiates and controls all read and write operations to the slave devices on the serial bus, and both the Master and the slave devices can transmit and receive data on the bus.  The serial interface is comprised of just two signal lines: Serial Clock (SCL) and Serial Data (SDA). The SCL pin is used to receive the clock signal from the Master, while the bidirectional SDA pin is used to receive command and data information from the Master, as well as, to send data back to the Master. Data is always latched into the ZD24C128A on the rising edge of SCL and always output from the device on the falling edge of SCL. Both the SCL and SDA pin incorporate integrated spike suppression filters and Schmitt Triggers to minimize the effects of input spikes and bus noise.  All command and data information is transferred with the Most-Significant Bit (MSB) first. During bus communication, one data bit is transmitted every clock cycle, and after eight bits (one byte) of data have been transferred, the receiving device must respond with either an Acknowledge (ACK) or a NoAcknowledge (NACK) response bit during a ninth clock cycle (ACK/NACK clock cycle) generated by the Master. Therefore, nine clock cycles are required for every one byte of data transferred. There are no unused clock cycles during any read or write operation, so there must not be any interruptions or breaks in the data stream during each data byte transfer and ACK or NACK clock cycle.  During data transfers, data on the SDA pin must only change while SCL is low, and the data must remain stable while SCL is high. If data on the SDA pin changes while SCL is high, then either a Start or a Stop condition will occur. Start and Stop conditions are used to initiate and end all serial bus communication between the Master and the slave devices. The number of data bytes transferred between a Start and a Stop condition is not limited and is determined by the Master. In order for the serial bus to be idle, both the SCL and SDA pins must be in the logic-high state at the same time.  3.1 Clock and Data Transition Requirements The SDA pin is an open drain terminal and therefore must be pulled high with an external pull-up resistor. Data on the SDA pin may change only during SCL low time periods. Data changes during SCL high periods will indicate a Start or Stop condition as defined below.     ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  4 / 28  Zetta        ZD24C128A 3.2 Start and Stop Conditions 3.2.1 Start Condition A Start condition occurs when there is a high-to-low transition on the SDA pin while the SCL pin is at a stable Logic 1 state and will bring the device out of standby mode. The Master uses a Start condition to initiate any data transfer sequence, therefore every command must begin with a Start condition. The device will continuously monitor the SDA and SCL pins for a Start condition but will not respond unless one is detected. Please refer to Figure 3-1 for more details.   3.2.2 Stop Condition A Stop condition occurs when there is a low-to-high transition on the SDA pin while the SCL pin is stable in the Logic 1 state. The Master can use the Stop condition to end a data transfer sequence with the ZD24C128A which will subsequently return to standby mode. The Master can also utilize a repeated Start condition instead of a Stop condition to end the current data transfer if the Master will perform another operation. Please refer to Figure 3-1 for more details.   3.3 Acknowledge and No-Acknowledge After every byte of data is received, the receiving device must confirm to the Master that it has successfully received the data byte by responding with what is known as an acknowledge (ACK). An ACK is accomplished by the transmitting device first releasing the SDA line at the falling edge of the eighth clock cycle followed by the receiving device responding with a Logic 0 during the entire high period of the ninth clock cycle.   When the ZD24C128A is transmitting data to the Master, the Master can indicate that it is done receiving data and wants to end the operation by sending a Logic 1 response to the ZD24C128A instead of an ACK response during the ninth clock cycle. This is known as a no-acknowledge (NACK) and is accomplished by the Master sending a Logic 1 during the ninth clock cycle, at which point the ZD24C128A will release the SDA line so the Master can then generate a Stop condition.  The transmitting device, which can be the bus Master or the Serial EEPROM, must release the SDA line at the falling edge of the eighth clock cycle to allow the receiving device to drive the SDA line to a Logic 0 to ACK the previous 8-bit word. The receiving device must release the SDA line at the end of the ninth clock cycle to allow the transmitter to continue sending new data. A timing diagram has been provided in Figure 31 to better illustrate these requirements.   Figure 3-1.Start Condition, Data Transitions, Stop Condition and Acknowledge     SDA  SDA Allowed Allowed    ZettaDevice Electronics Technology Co.,Ltd SDA line low to ACK the previous 8-bit word.   to continue sending new data. www.zettadevice.com  5 / 28    Zetta        ZD24C128A 3.4 Standby Mode The ZD24C128A features a low-power standby mode which is enabled when any one of the following occurs:    A valid power-up sequence is performed (see Section 8.5, “Pin Capacitance”).   A Stop condition is received by the device unless it initiates an internal write cycle (see Section 5., “Write Operations”).   At the completion of an internal write cycle (see Section 5.).   An unsuccessful match of the device type identifier or hardware address in the Device Address byte occurs (see Section 4.1, “Device Addressing”).   The bus Master does not ACK the receipt of data read out from the device; instead it sends a NACK response. (see Section 6., “Read Operations”).    3.5 Software Reset After an interruption in protocol, power loss, or system reset, any 2-wire part can be protocol reset by following these steps:   1. Create a Start condition (if possible).  2. Clock nine cycles.  3. Create another Start condition followed by a Stop condition as seen in Figure 3-2.  The device should be ready for the next communication after above steps have been completed. In the event that the device is still non-responsive or remains active on the SDA bus, a power cycle must be used to reset the device (see Section 8.6.1, “Device Reset”).  Figure 3-2. Software Reset Dummy Clock Cycles SCL  1  Start  Condition  2 3 8 9  Start  Condition  Stop Condition SDA     ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  6 / 28  Zetta        ZD24C128A 4. Memory Organization The ZD24C128A is internally organized as 256 pages of 64 bytes each.   4.1 Device Addressing Accessing the device requires an 8-bit Device Address word following a Start condition to enable the device for a read or write operation. Since multiple slave devices can reside on the serial bus each slave device must have its own unique address so the Master can access each device independently.   The most significant four bits of the Device Address word is referred to as the device type identifier. The device type identifier is required in bits seven through four of the Device Address byte (Table 4-1).   Following the 4-bit device type identifier are the hardware slave address bits, A0, A1, and A2. These bits can be used to expand the address space by allowing up to eight 128-Kbit Serial EEPROM devices on the same bus.   The eighth bit (bit 0) of the Device Address byte is the read/write operation select bit. A read operation is initiated if this bit is high and a write operation is initiated if this bit is low.   Upon the successful comparison of the Device Address byte, the ZD24C128A will return an ACK. If a valid comparison is not made, the device will NACK and return to a standby state.  Table 4-1.Device Address Byte     Hardware Slave Address Bits  Device Type Identifier Bit 7  Bit 6  Bit 5  Bit 4  Bit 3  Bit 2  Bit 1  Device select code when addressing the memory array  1  0  1  0  0  0  0  Device select code when accessing the Identification Page 1 0 1 1 0 0 0 Package     ZettaDevice Electronics Technology Co.,Ltd Read/ Write  Bit 0    R/W    R/W  www.zettadevice.com  7 / 28  Zetta        ZD24C128A For all operations (except the Current Address Read), a two 8-bit Word Address byte must be transmitted to the device immediately following the Device Address byte. The Word Address bytes consist of the 14-bit memory array word address, and is used to specify which byte location in the EEPROM to start reading or writing.   The first Word Address byte contains the six most significant bits of the word address (A13 through A8) in bit positions five through zero, as seen in Table 4-2. The remainder of the first Word Address byte are don’t care bits and (in bit positions seven through six) as they all outside of the addressable 128-Kbit range. Upon completion of the first Word Address byte, the ZD24C128A will return an ACK.  Table 4-2.First Word Address Byte   Bit 7  Bit 6  Bit 5  Bit 4  Bit 3  Bit 2  Bit 1  Bit 0  X  X  A13  A12  A11  A10  A9  A8  Note: Bit 7 through Bit 6 are don’t care values as they fall outside the addressable 128-Kbit range.  Next, the second Word Address byte is sent to the device which provides the remaining eight bits of the word address (A7 though A0). Upon completion of the second Word Address byte, the ZD24C128A will return an ACK. Please consult Table 4-3 to review these bit positions.  Table 4-3.Second Word Address Byte Bit 7  Bit 6  Bit 5  Bit 4  Bit 3  Bit 2  Bit 1  Bit 0  A7  A6  A5  A4  A3  A2  A1  A0  The relationship of the AC timing parameters with respect to SCL and SDA for the ZD24C128A are shown in the timing waveform Figure 8-1 on page 15. The AC timing characteristics and specifications are outlined in Section 8.4 “AC Characteristics” on page 15.    ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  8 / 28  Zetta        ZD24C128A 5. Write Operations All write operations for the ZD24C128A begin with the Master sending a Start condition, followed by a Device Address byte with the R/W bit set to ‘0’, and then by the Word Address byte. The data value(s) to be written to the device immediately follow the Word Address byte.   5.1 Byte Write The ZD24C128A supports the writing of single 8-bit bytes. Selecting a data word in the ZD24C128A requires a 14bit word address.   Upon receipt of the proper Device Address and Word Address bytes, the EEPROM will send an Acknowledge.   The device will then be ready to receive the first 8-bit data word. Following receipt of the 8-bit data word, the EEPROM will respond with an Acknowledge. The addressing device, such as a bus Master, must then terminate the Write operation with a Stop condition. At that time the EEPROM will enter an internally selftimed write cycle, which will be completed within tWR, while the data word is being programmed into the nonvolatile EEPROM. All inputs are disabled during this write cycle, and the EEPROM will not respond until the Write is complete. Figure 5-1. Byte Write  1   2   3   4 5   6   7   8 9 1 2 3 4 5 6 7 8 9 A8 0 SCL  Device Address Byte  SDA  1   MSB     0   1   0     A   A2 1 First Word Address Byte    A0 0 X X A13 A12 A11 A10 A9 MSB Start Condition by Master   0 ACK from Slave 1   2   3   4 5 ACK from Slave 6 7 8 9 1 2 3 A7   A6     A5 A4 A3 A2 A1 A0 0 6   7   8   9   D7 D6 D5 D4 D3 D2   D1   D0   0  MSB ACK from Slave 5.2 5 Data Word  Second Word Address Byte MSB 4     Stop Condition ACK from Slave by Master     Page Write A Page Write operation allows up to 64 bytes to be written in the same write cycle, provided all bytes are in the same row of the memory array (where address bits A13 through A6 are the same). Partial Page Writes of less than 64 bytes are also allowed.   A Page Write is initiated the same way as a Byte Write, but the bus Master does not send a Stop condition after the first data word is clocked in. Instead, after the EEPROM acknowledges receipt of the first data word, the bus Master can transmit up to sixty one additional data words. The EEPROM will respond with an ACK after each data word is received. Once all data to be written has been sent to the device, the bus Master must issue a Stop condition (Figure 5-2) at which time the internally self-timed write cycle will begin.     ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  9 / 28  Zetta        ZD24C128A The lower six bits of the word address are internally incremented following the receipt of each data word. The higher order address bits are not incremented and retain the memory page row location. Page Write operations are limited to writing bytes within a single physical page, regardless of the number of bytes actually being written. When the incremented word address reaches the page boundary, the address counter will “roll over” to the beginning of the same page. Nevertheless, creating a roll over event should be avoided as previously loaded data in the page could become unintentionally altered.  Figure 5-2.Page Write 1   2   3   4 5   6   7   8 9 1 2 3 4 5 6 7 8 9 A8 0 SCL  Device Address Byte  SDA  1   MSB   0   1   0     A   A2 1 First Word Address Byte    A0   Start Condition by Master   5.3 0 0 X X A13 A12 A11 A10 A9 MSB ACK from Slave ACK from Slave   Acknowledge Polling An Acknowledge Polling routine can be implemented to optimize time sensitive applications that would prefer not to wait the fixed maximum write cycle time (tWR). This method allows the application to know immediately when the Serial EEPROM write cycle has completed, so a subsequent operation can be started.  Once the internally self-timed write cycle has started, an Acknowledge Polling routine can be initiated. This   involves repeatedly sending a Start condition followed by a valid Device Address byte with the R/W bit set at Logic 0. The device will not respond with an ACK while the write cycle is ongoing. Once the internal write cycle has completed, the EEPROM will respond with an ACK, allowing a new Read or Write operation to be immediately initiated. A flow chart has been included below in Figure 5-3 to better illustrate this technique.   Figure 5-3. Acknowledge Polling Flow Chart Send any   Write   protocol  Send   Stop   condition   to initiate the   write cycle  Send Start condition followed by a valid Device Address byte with R/W = 0 Did YES  the device   ACK?  Proceed to next Read or Write operation NO      ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  10 / 28  Zetta        ZD24C128A 5.4 Write Cycle Timing The length of the self-timed write cycle, or tWR, is defined as the amount of time from the Stop condition that begins the internal Write operation, to the Start condition of the first Device Address byte sent to the ZD24C128A that it subsequently responds to with an ACK. Figure 5-4 has been included to show this measurement. During the internally self-timed write cycle, any attempts to read from or write to the memory array will not be processed.   Figure 5-4.Write Cycle Timing   5.5 Write Protection The ZD24C128A utilizes a hardware data protection scheme that allows the user to write protect the entire memory contents when the WP pin is at VCC (or a valid VIH). No write protection will be set if the WP pin is at GND or left floating.   Table 5-1.ZD24C128A Write Protect Behavior WP Pin Voltage  Part of the Array Protected  VCC  Full Array  GND  None — Write Protection Not Enabled  The status of the WP pin is sampled at the Stop condition for every Byte Write or Page Write command prior to the start of an internally self-timed Write operation. Changing the WP pin state after the Stop condition has been sent will not alter or interrupt the execution of the write cycle. The WP pin state must be valid with respect to the associated setup (tSU.WP) and hold (tHD.WP) timing as shown in the Figure 5-5 below. The WP setup time is the amount of time that the WP state must be stable before the Stop condition is issued. The WP hold time is the amount of time after the Stop condition that the WP state must remain stable.  If an attempt is made to write to the device while the WP pin has been asserted, the device will acknowledge the Device Address, Word Address, and Data bytes but no write cycle will occur when the Stop condition is issued, and the device will immediately be ready to accept a new Read or Write command.     ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  11 / 28  Zetta        ZD24C128A Figure 5-5. Write Protect Setup and Hold Timing  SCL  1    2  7 8 9  Stop Condition by Master Data Word Input Sequence Page/Byte Write Operation SDA IN  D7   D6   D1 D0       ACK by Slave tSU.WP tHD.WP WP         ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  12 / 28  Zetta        ZD24C128A 6. Read Operations Read operations are initiated the same way as Write operations with the exception that the Read/Write Select bit in the Device Address word must be a Logic 1. There are three Read operations:   6.1  Current Address Read   Random Address Read  Sequential Read Current Address Read The internal data word address counter maintains the last address accessed during the last read or write operation, incremented by one. This address stays valid between operations as long as the VCC is maintained to the part. The address “roll over” during read is from the last byte of the last page to the first byte of the first page of the memory.  A Current Address Read operation will output data according to the location of the internal data word address counter. This is initiated with a Start condition, followed by a valid Device Address byte with the R/W bit set to Logic 1. The device will ACK this sequence and the current address data word is serially clocked out on the SDA line. All types of Read operations will be terminated if the bus Master does not respond with an ACK (it NACKs) during the ninth clock cycle, which will force the device into standby mode. After the NACK response, the Master may send a Stop condition to complete the protocol, or it can send a Start condition to begin the next sequence.   Figure 6-1.Current Address Read 1 SCL    2   3   4   5   6   7   8 9 1 2 Device Address Byte  SDA  1   MSB   0   1   0      A2   Start Condition by Master   6.2 4 5 6 7 8 9 D2 D1 D0 1 Data Word (n)    A   A1 3 0 1 0 D7 D6 D5 D4 D3 MSB ACK from Slave     Stop Condition NACK by Master from Master   Random Read A Random Read begins in the same way as a Byte Write operation does to load in a new data word address. This is known as a “dummy write” sequence; however, the Data Byte and Stop condition of the Byte Write must be omitted to prevent the part from entering an internal write cycle. Once the Device Address and Word Address bytes are clocked in and acknowledged by the EEPROM, the bus Master must generate another Start condition. The bus Master now initiates a Current Address Read by sending a Start condition, followed by a valid Device Address byte with the R/W bit set to Logic 1. The EEPROM will ACK the Device Address and serially clock out the data word on the SDA line. All types of Read operations will be terminated if the bus Master does not respond with an ACK (it NACKs) during the ninth clock cycle, which will force the device into standby mode. After the NACK response, the Master may send a Stop condition to complete the protocol, or it can send a Start condition to begin the next sequence.     ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  13 / 28  Zetta        ZD24C128A   Figure 6-2.Random Read   1 2 3 4 5 6 7 8 9 1 2 3 4 5 6 7 8 9 1 2 3 4 5 6 7 8 9 A0 0   SCL  Device Address Byte  SDA  1   MSB     0   1   0     A   A2 First Word Address Byte    A0 1 0 X X A13 A12 A11 A10 A9 A8 0 A7 MSB Start Condition by Master   0 Second Word Address Byte     A6     A5 A4   A3   A2 A1 MSB ACK from Slave ACK from Slave ACK from Slave Dummy Write 1   2 3 4 5 6 7 8   9 1 2 3 1     0   1 0 A2 A1 A0 1 6.3 5   6   7   8   9 0 D7 D6 D5 D4   D3   D2   D1   D0   1 MSB Start Condition by Master     Data Word (n)  Device Address Byte MSB 4 Stop Condition NACK from Master by Master ACK from Slave   Sequential Read Sequential Reads are initiated by either a Current Address Read or a Random Read. After the bus Master receives a data word, it responds with an acknowledge. As long as the EEPROM receives an ACK, it will continue to increment the word address and serially clock out sequential data words. When the maximum memory address is reached, the data word address will “roll over” and the sequential read will continue from the beginning of the memory array. All types of Read operations will be terminated if the bus Master does not respond with an ACK (it NACKs) during the ninth clock cycle, which will force the device into standby mode. After the NACK response, the Master may send a Stop condition to complete the protocol, or it can send a Start condition to begin the next sequence.  1   2   3   4 5   6   7   Figure 6-3.Sequential Read 8 9 1 2 3 4 5 6 7 8 9 D2 D1 D0 0 SCL  Device Address Byte  SDA  1   MSB   0   1   0     A   A2   Start Condition by Master   1 Data Word (n)    A0 1 0 D7 D6 D5 D4 D3 MSB ACK from Slave ACK from Master        ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  14 / 28  Zetta        ZD24C128A 7. Device Default Condition from Zetta Device The ZD24C128A is delivered with the EEPROM array set to Logic 1, resulting in FFh data in all locations.   8. Electrical Specifications 8.1 Absolute Maximum Ratings Temperature under Bias. . . . . . . -55°C to +125°C  Storage Temperature. . . . . . . . . -65°C to +150°C  Supply Voltage with respect to ground . . . . . . . . .. . . .. . . .. . . . .-0.5V to +5.50V  Functional operation at the “Absolute Maximum Ratings” or any other conditions beyond those indicated in Section 8.2 “DC and AC Operating Range” is not implied or guaranteed. Stresses beyond those listed under “Absolute Maximum Ratings” and/or exposure to the “Absolute Maximum Ratings” for extended periods may affect device reliability and cause permanent damage to the device.   The voltage extremes referenced in the “Absolute Maximum Voltage on any pin with respect to ground . . . . .. . . .. . . .. . . . . . .-0.6V to VCC + 0.5V  Ratings” are intended to accommodate short duration undershoot/overshoot pulses that the device may be subjected to during the course of normal operation and does not imply or DC Output Current . . . . . . . . . . . . . . . . . . . 5.0mA  guarantee functional device operation at these levels for any extended period of time.  8.2 DC and AC Operating Range Table 8-1.DC and AC Operating Range     Operating Temperature (Case)  Industrial Temperature Range  VCC Power Supply  Low Voltage Grade  ZD24C128A  -40°C to +85°C  1.7V to 5.5V       ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  15 / 28  Zetta        ZD24C128A 8.3 DC Characteristics Table 8-2.DC Characteristics Parameters are applicable over the operating range in specified Section 8.2, unless otherwise noted.  Symbol  VCC  Parameter  Test Conditions  Min  Typical(1)  Max  Units Supply Voltage    1.7    5.5  V  VCC = 1.8V(2) Supply Current, Read  VCC = 5.5V ICC1  Supply Current, Write  ICC2  VCC = 5.5V Read at 400kHz    0.08  0.3  mA  Read at 1MHz    0.15  0.5  mA  Write at 1MHz    0.20  1.0  mA    0.08  0.4  μA  VCC = 1.8V(2) ISB  Standby Current      ILI  Output Leakage Current  VIL  VIH  VOL1        Notes:         0.10  0.5 μA VIN = VCC or VSS   0.10  3.0  μA  VOUT = VCC or VSS   0.05  3.0  μA    Input Low Level(2)    –0.6    VCC x 0.3 Input High Level(2)    VCC x 0.7   VCC + 0.5 Output Low Level  VOL2  VIN = VCC or VSS   VCC = 5.5V Input Leakage Current  ILO    Output Low Level  V  VCC = 1.8V IOL = 0.15mA     0.2  V  VCC = 5.5V IOL = 2.1mA     0.4  V  1. Typical values characterized at TA = +25°C unless otherwise noted.  2. This parameter is characterized but is not 100% tested in production.     ZettaDevice Electronics Technology Co.,Ltd V  www.zettadevice.com  16 / 28  Zetta        ZD24C128A 8.4 AC Characteristics Table 8-3. AC Characteristics Parameters are applicable over operating range in Section 8.2 unless otherwise noted. Test conditions shown in Note 2.  Fast Mode  Standard Mode VCC = 1.7V to 5.5V Symbol  Min Parameter  Clock Frequency, SCL fSCL  VCC = 1.7V to 5.5V Max 100   Fast Mode Plus VCC = 2.5V to 5.5V  Max  Min 400    Min  Max 1000   Units kHz Clock Pulse Width Low  4,700   1300   500    ns Clock Pulse Width High  4,000   600   400    ns tLOW  tHIGH  tI  Input Filter Spike Suppression (SCL,SDA)(1)    100   100    100 ns tAA  Clock Low to Data Out Valid    4,500   900    450 ns Bus Free Time between Stop and Start(1) 4,700   1300   500    ns Start Condition Hold Time  4,000   600   250    ns Start Condition Set-up Time  4,700   600   250    ns 0   0   0    ns 200   100   100    ns tBUF  tHD.STA  tSU.STA  Data In Hold Time  tHD.DAT  Data In Set-up Time  tSU.DAT  t R  Inputs Rise Time(1)    1,000   300    100 ns tF  Inputs Fall Time(1)    300   300    100 ns Stop Condition Set-up Time  4,700   600   250    ns Write Protect Setup Time  4,000   600   100    ns Write Protect Hold Time  4,000   600   400    ns 100   50   50    ns tSU.STO  tSU.WP  tHD.WP  tDH  Data Out Hold Time  Write Cycle Time  tWR     ZettaDevice Electronics Technology Co.,Ltd   5   5    5 ms www.zettadevice.com  17 / 28  Zetta        ZD24C128A Notes: 1. These parameters are determined through product characterization and are not 100% tested in production.  2. AC measurement conditions:  C L : 100pF  RPUP (SDA bus line pull-up resistor to VCC): 1.3kΩ(1000kHz), 4kΩ (400kHz), 10kΩ (100kHz)  Input pulse voltages: 0.3 x VCC to 0.7 x VCC  Input rise and fall times: ≤ 50ns  Input and output timing reference voltages: 0.5 x VCC       Figure 8-1. Bus Timing     8.5 Pin Capacitance Table 8-4.Pin Capacitance(1) Applicable over recommended operating range from TA = 25°C, f = 1.0MHz, VCC = 3.0V  Symbol  Test Condition  Max Units  Conditions CI/O  Input/Output Capacitance (SDA) 8 pF  VI/O = 0V CIN  Input Capacitance (A0, A1, A2, SCL) 6 pF  VIN = 0V   Note: 8.6 Power-Up Requirements and Reset Behavior 1. This parameter is characterized but is not 100% tested in production.  During a power-up sequence, the VCC supplied to the ZD24C128A should monotonically rise from GND to the minimum VCC level as specified in Section 8.2, “DC and AC Operating Range” with a slew rate no greater than 1V/μs.  8.6.1 Device Reset To prevent inadvertent write operations or other spurious events from happening during a power-up sequence, the ZD24C128A includes a power-on-reset (POR) circuit. Upon power-up, the device will not respond to any commands until the VCC level crosses the internal voltage threshold (VPOR) that brings the device out of reset and into standby mode.   The system designer must ensure that instructions are not sent to the device until the VCC supply has reached a stable value greater than or equal to the minimum VCC level. Additionally, once the VCC is greater than or    ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  18 / 28  Zetta        ZD24C128A equal to the minimum VCC level, the bus Master must wait at least tPUP before sending the first command to the device. See Table 8-5 for the values associated with these power-up parameters.  Table 8-5.Power-up Conditions(1) Symbol  Parameter  Min  Time required after VCC is stable before the device can accept commands.  100  tPUP  VPOR  Power-On Reset Threshold Voltage Note: 1. μs 1.5 1  Minimum time at VCC = 0V between power cycles. Units     tPOFF    Max V ms   These parameters are characterized but they are not 100% tested in production.  If an event occurs in the system where the VCC level supplied to the ZD24C128A drops below the maximum VPOR level specified, it is recommended that a full power cycle sequence be performed by first driving the VCC pin to GND, waiting at least the minimum tPOFF time, and then performing a new power-up sequence in compliance with the requirements defined in this section.   8.7 EEPROM Cell Performance Characteristics Table 8-6.EEPROM Cell Performance Characteristics Operation  Test Condition Min Max  Units 1,000,000  —  Write Cycles  100 —  Years TA = 25°C, VCC(min)< VCC < VCC(max) Write Endurance(1)  Data Retention(2)    Notes: 1. Byte or Page Write Mode   TA = 55°C, VCC(min)< VCC < VCC(max) Write endurance performance is determined through characterization and the qualification process.     2. The data retention capability is determined through qualification and is checked on each device in production.     ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  19 / 28  Zetta        ZD24C128A 9. Ordering Information ZD 24C 128 A - SS G M T Zetta Designator  Product Family  24 C = Standard I  C-compatible  Serial EEPROM  2 Shipping Carrier Option  T = Tape and Reel, Standard Quantity Option B = Bulk (Tubes)  Device Density  128  = 128 Kilobit  Device Revision  Operating Voltage  M = 1.7V to 5.5V  Package Device Grade  G = Low-halogen, Lead(Pb)-free P = Lead (Pb) - free   Package Option  SS = JEDEC SOIC X = TSSOP MA = 2.0mm x 3.0mm UDFN P = PDIP ST = SOT23 C = VFBGA U = 3x3 Grid, 5-ball WLCSP U1 = 2x2 Grid, 4-ball WLCSP WU = Wafer Unsawn      ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  20 / 28  Zetta        ZD24C128A 10. Packaging Information 10.1 8-lead JEDEC SOIC      ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  21 / 28  Zetta        ZD24C128A 10.2 8-lead TSSOP      ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  22 / 28  Zetta        ZD24C128A 10.3 8-pad UDFN            ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  23 / 28  Zetta        ZD24C128A 10.4 5-lead SOT23            ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  24 / 28  Zetta        ZD24C128A 10.5 8-ball VFBGA            ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  25 / 28  Zetta        ZD24C128A 10.6 5-ball WLCSP            ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  26 / 28  Zetta        ZD24C128A 10.7 4-ball WLCSP            ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  27 / 28  Zetta        ZD24C128A 11. Revision History Doc. No.  Date    08/2015  Comments  Initial document release.       ZettaDevice Electronics Technology Co.,Ltd www.zettadevice.com  28 / 28
ZD24C128A-SSGMB 价格&库存
很抱歉,暂时无法提供与“ZD24C128A-SSGMB”相匹配的价格&库存,您可以联系我们找货
