BZT52C24S
BZT52C24S
    DIOS(迪恩思)
    SOD-323(SC-76)
    齐纳/稳压二极管 24V SOD-323(SC-76)
BZT52C24S 数据手册
BZT52C2V4S THRU BZT52C51S ZENER DIODE SOD-323 Features 1.35(0.053) 1.15(0.045) 2.75(0.108) 1.80(0.071) 2.30(0.091) 1.60(0.063) Planar die construction 200mW power dissipation on ceramic PCB General purpose medium current Ideally suited for automated assembly processes Mechanical Data 0.4(0.016) .25(0.010) .177(.007) 1.00(.040) .089(.003) 0.80(.031) Case: Molded plastic body Terminals: Plated leads solderable per MIL-STD-750, Method 2026 Polarity: Polarity symbols marked on case .08(.003) MIN Dimensions in millimeters and (inches) Maximum ratings (Tamb=25C unless otherwise specified) PARAMETER Forward voltage SYMBOLS Value UNITS VF 0.9 V 200 mW -65 to +150 C Power dissipation (Note1) Pd Operating and storage temperature range TSTG 1) Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm 2) Short duration test pulse used to minimize self-heating effect 3) f=1KHz with pad areas 25mm² 1 BZT52C2V4S THRU BZT52C51S ELECTRICAL CHARACTERISTICS (@ TA=25C unless otherwise specified) Zener Voltage Range Maximum Zener Impedance Zzt Zzk Izk @Izt @Izk Ω mA Maximum Reverse Current Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC Device Marking Nom(V) Min(V) Max(V) mA uA V BZT52C2V4S WX 2.4 2.2 2.6 5 100 600 1.0 50 1.0 -3.5 0 5 BZT52C2V7S W1 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 BZT52C3V0S W2 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 BZT52C3V3S W3 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 BZT52C3V6S W4 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 BZT52C3V9S W5 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V3S W6 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52C4V7S W7 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 BZT52C5V1S W8 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 BZT52C5V6S W9 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 5 BZT52C6V2S WA 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 Vz@Izt Izt IR VR mA BZT52C6V8S WB 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 BZT52C7V5S WC 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 BZT52C8V2S WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 BZT52C9V1S WE 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 BZT52C10S WF 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 BZT52C11S WG 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 BZT52C12S WH 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 BZT52C13S WI 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 BZT52C15S WJ 15 13.8 15.6 0.1 10.5 9.2 13.0 5 BZT52C16S WK 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 BZT52C18S WL 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 BZT52C20S WM 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 BZT52C22S WN 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 BZT52C24S WO 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 BZT52C27S WP 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 BZT52C30S WQ 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 BZT52C33S WR 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 BZT52C36S WS 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 BZT52C39S WT 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 BZT52C43S WU 43 40.0 46.0 2 100 700 1.0 0.1 32.0 10.0 12.0 5 BZT52C47S WV 47 44.0 50.0 2 100 750 1.0 0.1 35.0 10.0 12.0 5 BZT52C51S WW 51 48.0 54.0 2 100 750 1.0 0.1 38.0 10.0 12.0 5 5 30 200 1.0 2
BZT52C24S 价格&库存
很抱歉,暂时无法提供与“BZT52C24S”相匹配的价格&库存,您可以联系我们找货
BZT52C24S
  • 3000+0.02990
  • 6000+0.02912
库存:6000
BZT52C24S
  • 20+0.06750
  • 100+0.05050
  • 800+0.03920
  • 3000+0.02840
  • 15000+0.02550
库存:117751
