BZT52C2V4S THRU BZT52C51S
ZENER DIODE
SOD-323
Features
1.35(0.053)
1.15(0.045)
2.75(0.108)
1.80(0.071)
2.30(0.091)
1.60(0.063)
Planar die construction
200mW power dissipation on ceramic PCB
General purpose medium current
Ideally suited for automated assembly processes
Mechanical Data
0.4(0.016)
.25(0.010)
.177(.007)
1.00(.040)
.089(.003)
0.80(.031)
Case: Molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
.08(.003)
MIN
Dimensions in millimeters and (inches)
Maximum ratings (Tamb=25C unless otherwise specified)
PARAMETER
Forward voltage
SYMBOLS
Value
UNITS
VF
0.9
V
200
mW
-65 to +150
C
Power dissipation (Note1)
Pd
Operating and storage temperature range
TSTG
1) Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm
2) Short duration test pulse used to minimize self-heating effect
3) f=1KHz
with pad areas 25mm²
1
ELECTRICAL CHARACTERISTICS (@ TA=25C unless otherwise specified)
Zener Voltage Range
Maximum Zener
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
Ω
mA
Maximum
Reverse Current
Typical
Temperature
coefficent @
IZTC=mV/℃
Min
Max
Test
Current
IZTC
Device
Marking
Nom(V)
Min(V)
Max(V)
mA
uA
V
BZT52C2V4S
WX
2.4
2.2
2.6
5
100
600
1.0
50
1.0
-3.5
BZT52C2V7S
W1
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZT52C3V0S
W2
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZT52C3V3S
W3
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZT52C3V6S
W4
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZT52C3V9S
W5
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZT52C4V3S
W6
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZT52C4V7S
W7
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
BZT52C5V1S
W8
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
BZT52C5V6S
W9
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
BZT52C6V2S
WA
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
Vz@Izt
Izt
IR
VR
mA
BZT52C6V8S
WB
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
BZT52C7V5S
WC
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
BZT52C8V2S
WD
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
BZT52C9V1S
WE
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
BZT52C10S
WF
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
BZT52C11S
WG
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
BZT52C12S
WH
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
BZT52C13S
WI
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
BZT52C15S
WJ
15
13.8
15.6
0.1
10.5
9.2
13.0
5
BZT52C16S
WK
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
BZT52C18S
WL
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
BZT52C20S
WM
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
BZT52C22S
WN
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
BZT52C24S
WO
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
BZT52C27S
WP
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
BZT52C30S
WQ
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
BZT52C33S
WR
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
BZT52C36S
WS
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
BZT52C39S
WT
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
BZT52C43S
WU
43
40.0
46.0
2
100
700
1.0
0.1
32.0
10.0
12.0
5
BZT52C47S
WV
47
44.0
50.0
2
100
750
1.0
0.1
35.0
10.0
12.0
5
BZT52C51S
WW
51
48.0
54.0
2
100
750
1.0
0.1
38.0
10.0
12.0
5
5
30
200
1.0
2
很抱歉,暂时无法提供与“BZT52C16S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3000+0.02990
- 6000+0.02912
- 国内价格
- 20+0.06750
- 100+0.05050
- 800+0.03920
- 3000+0.02840
- 15000+0.02550
