SS36F
SS36F
    DIOS(迪恩思)
    SMAF(DO-214AD)
SS36F 数据手册
SS32F THRU SS320F SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Reverse Voltage - 20 to 200 Volts Forward Current - 3.0 Amperes Features SMAF The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Cathode Band Top View 0.110(2.80) 0.094(2.40) For surface mounted applications Built-in strain relief,ideal for automated placement Low reverse leakage 0.059(1.50) 0.051(1.30) High forward surge current capability 0.144(3.65) 0.128(3.25) High temperature soldering guaranteed 0.010(0.25) 0.004(0.10) 0.055(1.40) 0.043(1.10) 250 C/10 seconds at terminals Mechanical Data 0.047(1.20) 0.028(0.70) Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any 0.189(4.80) 0.173(4.40) Dimensions in inches and (millimeters) Weight : 0.0014 ounce, 0.038 grams Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS SS32F SS34F SS36F SS38F SS310F SS315F SS320F UNITS Maximum repetitive peak reverse voltage VRRM 20 40 60 80 100 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 40 60 80 100 150 200 V Maximum average forward rectified current at TL =100 C I(AV) 3.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 80.0 A Maximum instantaneous forward voltage at 3.0A VF Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C Typical thermal resistance Operating junction temperature range Storage temperature range IR 0.70 0.55 0.85 0.5 50 0.95 0.05 10 V mA RqJA 70.0 C/W TJ -55 to +150 C TSTG -55 to +150 C 1 SS32F THRU SS320F Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 140 Peak Forward Surage Current Amperes 4.0 3.5 3.0 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 2.5 2.0 1.5 1.0 0.5 0.0 0 20 40 60 80 100 120 140 120 100 80 60 f=60Hz 40 20 1Cycle 0 160 1 10 100 Lead Temperature Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 50 100 TJ=25 C 1 0.1 SS32F-SS34F SS36F SS38F-SS310F SS315F-SS320F 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, VOLTS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES SS32F-SS36F SS38F-SS320F 10.0 10 TJ=100 C 1 0.1 0.01 0.001 0 TJ=25 C 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 2
SS36F 价格&库存
很抱歉,暂时无法提供与“SS36F”相匹配的价格&库存,您可以联系我们找货
SS36F
    • 3000+0.08395
    • 6000+0.08176
    库存:6000
