2302
N-Channel 20-V(D-S) MOSFET
SOT-23 Plastic-Encapsulate MOSFETS
Features
SOT-23
※ TrenchFET Power MOSFET
1.GATE
2.SOURCE
3.DRAIN
Equivalent Circuit
Application
※ Load Switch for Portable Devices
※ DC/DC Converter
MARKING
S2
V(BR)DSS
20 V
RDS(on)MAX
45mΩ@4.5V
55mΩ@2.5V
ID
3A
Maximum ratings ( Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±12
Continuous Drain Current
ID
3
Pulsed Diode Curren
IDM
Continuous Source-Drain Current(Diode Conduction)
IS
0.8
Power Dissipation
PD
1
W
RθJA
157
℃/W
TJ
150
TSTG
-55~+150
Thermal Resistance from Junction to Ambient (t≤5s)
Operating Junction
Storage Temperature
V
A
1
2022/12/15
2302
MOSFET ELECTRICAL CHARACTERISTICS
Static Electrical Characteristics (Ta = 25 ℃ Unless Otherwise Noted)
Parameter
Symbol
Test Condition
Min
V(BR)DSS
VGS = 0V, ID =-250µA
VGS(th)
VDS =VGS, ID =-250µA
0.5
Gate-source leakage
IGSS
VDS =0V, VGS =±10V
Zero gate voltage drain current
IDSS
VDS = 20V, VGS =0V
Typ
Max
Unit
Static
Drain-source breakdown voltage
Gate-source threshold voltage
Drain-source on-state resistancea
Forward transconductancea
Diode forward voltage
V
0.7
1.1
V
±0.1
±95
nA
1
µA
VGS = 4.5V, ID = 3A
27
45
mΩ
VGS = 2.5V, ID = 2A
35
55
mΩ
gfs
VDS = 4.5V, ID =2.8A
4
VSD
IS=0.8A,VGS=0V
0.8
RDS(on)
S
1.3
V
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitanceb
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Gate resistance
VDS = 10V,VGS =0V,
f=1MHz
VDS = 10V,VGS = 4.5V,ID =2.8A
VDS = 10V,VGS = 2.5V,
ID = 3A
Rg
f=1MHz
405
pF
75
pF
55
pF
5.5
10
3.3
6
nC
0.7
nC
1.3
nC
6.0
Ω
Switchingb
Turn-on delay time
Rise time
Turn-off delay time
Fall time
td(on)
tr
td(off)
VDD= 10V
RL=10Ω, ID ≈-1A,
VGEN= 4.5V,Rg=1Ω
tf
11
ns
35
60
ns
30
50
ns
10
ns
1
A
10
A
Drain-source body diode characteristics
Continuous Source-Drain Diode Current
Pulsed Diode forward Curren
IS
Tc=25℃
ISM
Note :
1. Repetitive Rating : Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t < 5 sec.
3. Pulse Test : Pulse Width≤300µs, Duty Cycle ≤ 2%.
4. Guaranteed by desig n, not subj ect to p roduction testing .
2
2022/12/15
2302
TYPICAL ELEC TRICAL AND THERMAL CHARACTERISTICS
3
2022/12/15
很抱歉,暂时无法提供与“2302”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.07130
- 200+0.06670
- 500+0.06210
- 1000+0.05750
- 3000+0.05520
- 6000+0.05198
