TPD2E009DBZR
TPD2E009DBZR
    ELECSUPER(静芯微)
    SOT-23
    ESD抑制器/TVS二极管 单向 5V 4A 60W SOT-23
TPD2E009DBZR 数据手册
TPD2E009DBZR-ES Rev-1.3 www.elecsuper.com SuperESD - TPD2E009DBZR-ES 1. Description The TPD2E009DBZR-ES is an ultra-low capacitance TVS (Transient Voltage Suppressor) array designed to protect high speed data interfaces. It has been specifically designed to protect sensitive electronic components which are connected to data and transmission lines from over-stress caused by ESD (Electrostatic Discharge). 2. Features  IEC 61000-4-2 Level 4 ESD Protection  Working voltage: 5V - ±10kV Contact Discharge  RoHS compliant - ±15kV Air Discharge  Protecting two unidirectional lines  Low clamping voltage  60W Peak pulse Power (8/20us)  Low leakage current 3. Applications  Portable electronics  DVI  USB 2.0 and USB 3.0  IEEE 1394  HDMI 1.3 and HDMI 1.4  PCI Express  SATA and eSATA  Notebooks 4. Ordering Information Part Number TPD2E009DBZR-ES Package Marking Material Packing Quantity per reel Flammability Rating Reel Size SOT-23 Halogen free Tape & Reel 3,000 UL 94V-0 7 R22 PCS Table-1 Copyright© ElecSuper Incorporated inches Ordering information Contact Us 1 / 6 TPD2E009DBZR-ES Rev-1.3 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description Outline 1 IO Connect to IO 2 IO Connect to IO 3 GND Connect to GND Circuit Diagram 2 3 R22 1 3 2 1 Table-2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 60 W Peak pulse current (tp=8/20us)@25℃ IPP 4 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±15 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±10 kV TJ - 150 ℃ Operating temperature TOP -40 125 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 6 TPD2E009DBZR-ES Rev-1.3 www.elecsuper.com 6.2. Electrical Characteristics At TA = 25℃ unless otherwise noted Parameter Symbol Reverse Stand-off Voltage Reverse Breakdown Voltage Conditions Min. Typ. VRWM Units 5.0 V 9.0 V 1.0 uA VBR IT=1mA Reverse Leakage Current IR VRWM=5V Clamping Voltage VC IPP=1A; tp=8/20us 8.0 10.0 V Clamping Voltage VC IPP=4A; tp=8/20us 11.0 13.0 V Junction Capacitance CJ VR=0V; f=1MHz 0.6 0.8 pF Table-4 Symbol VRWM IR VBR 6.0 Max. Electrical Characteristics Parameters Peak Reverse Working Voltage Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP IF Forward Current VF Forward Voltage @ IF Copyright© ElecSuper Incorporated Contact Us 3 / 6 TPD2E009DBZR-ES Rev-1.3 www.elecsuper.com 7. Typical Characteristic 8/20μs waveform per IEC61000-4-5 Contact discharge current waveform per IEC61000-4-2 1.0 0.8 IO-GND CJ (pF) 0.6 0.4 IO-IO 0.2 0.0 0 1 2 3 VR (V) Power derating vs. Ambient temperature Copyright© ElecSuper Incorporated Capacitance vs. Reverse voltage Contact Us 4 / 6 VC - Clamping voltage (V) TPD2E009DBZR-ES Rev-1.3 www.elecsuper.com 18 15 12 9 6 3 0 0 1 2 3 4 5 IPP - Peak pulse current (A) Clamping voltage vs. Peak pulse current 8. Dimension (SOT-23) A D M θ 3 E B 1 K N 2 C G COMMON DIMENSIONS CUNITS MEASURE=MILLIMETER SYMBOL MIN MAX SYMBOL MIN MAX A 2.85 3.04 G 1.80 2.00 B 1.20 1.40 K 0 0.10 C 0.90 1.10 M 0.20 - D 0.40 0.50 N 0.50 0.70 E 2.25 2.55 θ 5° 9° Copyright© ElecSuper Incorporated Contact Us 5 / 6 TPD2E009DBZR-ES Rev-1.3 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 6 / 6
TPD2E009DBZR 价格&库存
很抱歉,暂时无法提供与“TPD2E009DBZR”相匹配的价格&库存,您可以联系我们找货
TPD2E009DBZR
  • 1+0.33000
  • 100+0.24500
  • 300+0.20500
  • 3000+0.17550
库存:922
