MPI2512V2-R47-R
MPI2512V2-R47-R
    EATON(伊顿)
    1008(2520公制)
    FIXED IND 470NH 4.9A 23MOHM SMD
MPI2512V2-R47-R 数据手册
Technical Data 10649 Effective July 2018 MPI25-V2 High current, low profile, miniature power inductors Applications • Mobile/smart phones • Handheld/mobile equipment • Tablets/e-readers • Digital cameras • Wearable devices • Notebook/netbook/laptop regulators • Portable media players Environmental data Product features • High current carrying capacity in a compact standard 1008 (2520 metric) footprint • Magnetically shielded, Low EMI • Rugged construction • Self resonant frequency (SRF) greater than 25 MHz • Inductance range from 0.33 μH to 4.7 μH • Current range from 1.2 A to 7.5 A • 2.7 mm x 2.2 mm footprint surface mount package in 1.05 mm, 1.25 mm heights • Moisture Sensitivity Level (MSL): 1 • Storage temperature range (Component): -40 °C to +125 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant • Halogen free, lead free, RoHS compliant HALOGEN Pb HF FREE MPI25-V2 High current, low profile, miniature power inductors  Technical Data 10649 Effective July 2018 Product specifications OCL1 (μH) ±20% Irms2 (A) Isat3 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C SRF (MHz) typical K-factor4 MPI2510V2-R33-R 0.33 4.8 6.6 15 20 120 6336 MPI2510V2-R47-R 0.47 4.4 6.0 19 25 100 5039 MPI2510V2-R68-R 0.68 3.1 4.3 37 44 80 5733 MPI2510V2-1R0-R 1.00 3.1 4.3 41 52 55 3372 MPI2510V2-1R5-R 1.50 2.5 2.5 65 85 45 4695 MPI2510V2-2R2-R 2.20 2.1 2.8 88 110 45 2873 MPI2510V2-3R3-R 3.30 1.6 2.1 140 170 35 1893 MPI2510V2-4R7-R 4.70 1.22 1.8 220 262 25 1616 MPI2512V2-R33-R 0.33 5.1 7.5 14 19 130 6560 MPI2512V2-R47-R 0.47 4.9 6.7 17 23 100 3628 MPI2512V2-R68-R 0.68 3.4 6.0 29 35 70 3633 MPI2512V2-1R0-R 1.00 3.3 4.4 36 44 70 3083 MPI2512V2-1R5-R 1.50 2.3 3.2 64 77 45 4850 MPI2512V2-2R2-R 2.20 2.2 3.5 73 87 30 2924 MPI2512V2-3R3-R 3.30 1.8 2.8 110 135 35 1965 MPI2512V2-4R7-R 4.70 1.4 1.9 196 235 25 1580 Part Number5 1.0 mm height 1.2 mm height 1. Open Circuit Inductance (OCL) Test Parameters: 1.0 MHz, 0.1 Vrms, 0.0 Adc, +25 °C. 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 3. Isat : Peak current for approximately 30% rolloff @ +25 °C. Dimensions (mm) Dimension A MPI2510V2 1.05 maximum MPI2512V2 1.25 maximum, No marking All soldering surfaces to be coplanar within 0.10 millimeters Tolerances are ±0.2 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics 4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p :(Gauss), K: (K-factor from table), L: (Inductance in uH), ΔI (Peak to peak ripple current in Amps). 5. Part Number Definition: MPI25xxV2-xxx-R MPI25 = Product code xx= Height indicator V2=Version indicator xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant MPI25-V2 High current, low profile, miniature power inductors Technical Data 10649 Effective July 2018  Packaging information (mm) Supplied in tape and reel packaging, 3000 parts per 7” diameter reel Core loss vs. Bp-p (+25 °C) MPI2510V2-R47-R MPI2510V2-R33-R 10.000 3 MHz 10.000 3 MHz 2 MHz 2 MHz 300 kHz 0.100 100 kHz 1.000 Core Loss (mW) 500 kHz Core Loss (mW) 1 MHz 1 MHz 1.000 500 kHz 300 kHz 0.100 100 kHz 0.010 0.010 0.001 0.001 100 1000 Bp-p (Gauss) 100 1000 Bp-p (Gauss) www.eaton.com/electronics 3 MPI25-V2 High current, low profile, miniature power inductors  Technical Data 10649 Effective July 2018 Core loss vs. Bp-p (+25 °C) MPI2510V2-R68-R MPI2510V2-1R0-R 10.000 10.000 3 MHz 3 MHz 2 MHz 2 MHz 500 kHz 300 kHz 0.100 100 kHz 1 MHz 1.000 1 MHz 500 kHz Core Loss (mW) Core Loss (mW) 1.000 0.010 300 kHz 0.100 100 kHz 0.010 0.001 0.001 100 1000 100 Bp-p (Gauss) 1000 Bp-p (Gauss) MPI2510V2-1R5-R MPI2510V2-2R2-R 10.000 10.000 3 MHz 3 MHz 2 MHz 2 MHz 1.000 1 MHz 1.000 500 kHz 0.100 300 kHz 100 kHz 0.010 Core Loss (mW) Core Loss (mW) 1 MHz 500 kHz 300 kHz 0.100 100 kHz 0.010 0.001 100 1000 0.001 100 Bp-p (Gauss) MPI2510V2-3R3-R MPI2510V2-4R7-R 3 MHz 10.000 2 MHz 1 MHz 1.000 0.100 100 kHz 0.010 500 kHz Core Loss (mW) 300 kHz 1 MHz 1.000 500 kHz Core Loss (mW) 3 MHz 10.000 2 MHz 300 kHz 0.100 100 kHz 0.010 0.001 100 1000 Bp-p (Gauss) 4 1000 Bp-p (Gauss) www.eaton.com/electronics 0.001 1000 100 Bp-p (Gauss) MPI25-V2 High current, low profile, miniature power inductors Technical Data 10649 Effective July 2018  Core loss vs. Bp-p (+25 °C) MPI2512V2-R47-R MPI2512V2-R33-R 10.000 3 MHz 10.000 3 MHz 2 MHz 1 MHz 1 MHz Core Loss (mW) 500 kHz 300 kHz 0.100 500 kHz 1.000 100 kHz 300 kHz Core Loss (mW) 1.000 100 kHz 0.100 0.010 0.010 0.001 0.001 100 100 1000 MPI2512V2-1R0-R MPI2512V2-R68-R 3 MHz 10.000 1000 Bp-p (Gauss) Bp-p (Gauss) 3 MHz 10.000 2 MHz 1.000 0.100 100 kHz Core Loss (mW) 500 kHz 300 kHz 2 MHz 1 MHz 1 MHz 1.000 Core Loss (mW) 2 MHz 500 kHz 300 kHz 100 kHz 0.100 0.010 0.010 0.001 0.001 100 100 1000 1000 Bp-p (Gauss) Bp-p (Gauss) MPI2512V2-1R5-R MPI2512V2-2R2-R 10.000 10.000 3 MHz 3 MHz 2 MHz 2 MHz 500 kHz 300 kHz 0.100 100 kHz 0.010 1 MHz 1.000 1 MHz Core Loss (mW) Core Loss (mW) 1.000 500 kHz 300 kHz 0.100 100 kHz 0.010 0.001 100 1000 Bp-p (Gauss) 0.001 100 1000 Bp-p (Gauss) www.eaton.com/electronics 5 MPI25-V2 High current, low profile, miniature power inductors  Technical Data 10649 Effective July 2018 Core loss vs. Bp-p (+25 °C) MPI2512V2-3R3-R MPI2512V2-4R7-R 3 MHz 10.000 3 MHz 10.000 2 MHz 2 MHz 1 MHz 1 MHz 1.000 1.000 300 kHz 0.100 100 kHz Core Loss (mW) Core Loss (mW) 500 kHz 0.010 500 kHz 300 kHz 0.100 100 kHz 0.010 0.001 100 0.001 1000 100 1000 Bp-p (Gauss) Bp-p (Gauss) Inductance and Q vs. Frequency MPI2510V2-R33-R MPI2510V2-R47-R 0.40 30 0.20 0.15 Q value 40 0.25 20 0.10 0.00 1.0 10.0 100.0 35 30 0.4 25 0.3 20 15 10 0.1 0 1,000.0 5 0 0.1 1 Frequency (MHz) 70 2.0 60 1.8 60 1 50 40 0.6 30 0.4 20 Q value 0.8 Inductance (uH) 1.6 50 1.4 40 1.2 30 1.0 0.8 20 0.6 0.4 0.2 10 0 0.1 1 10 Frequency (MHz) www.eaton.com/electronics 0 1000 MPI2510V2-1R0-R 1.2 Inductance (uH) 100 Frequency (MHz) MPI2510V2-R68-R 6 10 100 0 1000 10 0.2 0.0 0.1 1.0 10.0 Frequency (MHz) 100.0 0 1000.0 Q value 0.1 40 0.2 10 0.05 45 0.5 Inductance (uH) 0.30 50 0.6 50 0.35 Inductance (uH) 0.7 60 Q value 0.45 MPI25-V2 High current, low profile, miniature power inductors Technical Data 10649 Effective July 2018  Inductance and Q vs. Frequency MPI2510V2-1R5-R MPI2510V2-2R2-R 1.0 10 0.5 2.5 10.0 100.0 15 1.5 10 1.0 5 0.5 0 1000.0 0.0 0.1 1.0 Frequency (MHz) 8 40 30 5 25 4 20 3 15 2 10 2.0 1 5 1.0 0 1000 0.0 Inductance (uH) 35 6 100 35 8.0 7 0 40 9.0 Q value Inductance (uH) 10.0 45 10 30 7.0 25 6.0 5.0 20 4.0 15 3.0 10 5 0.1 1.0 0.40 90 0.35 80 0.8 0.30 60 0.25 50 0.20 40 0.15 30 0.10 20 0.05 10 0.00 100 0 1000 90 80 0.6 70 Frequency (MHz) 0 1000.0 100 0.7 Inductance (uH) 100 Q value Inductance (uH) 0.45 10 100.0 MPI2512V2-R47-R MPI2512V2-R33-R 1 10.0 Frequency (MHz) Frequency (MHz) 0.1 0 1000.0 MPI2510V2-4R7-R 9 1 100.0 Frequency (MHz) MPI2510V2-3R3-R 0.1 10.0 Q value 1.0 20 2.0 70 0.5 60 0.4 50 40 0.3 Q value 0.1 25 3.0 5 0.0 30 3.5 Inductance (uH) 15 Q value 20 1.5 35 4.0 25 2.0 40 4.5 30 2.5 Inductance (uH) 5.0 35 Q value 3.0 30 0.2 20 0.1 10 0 0.1 1 10 100 0 1000 Frequency (MHz) www.eaton.com/electronics 7 MPI25-V2 High current, low profile, miniature power inductors  Technical Data 10649 Effective July 2018 Inductance and Q vs. Frequency MPI2512V2-R68-R 50 1.6 60 1.4 50 0.6 40 30 0.4 Inductance (uH) 0.8 Q value Inductance (uH) 60 1.8 70 1.0 MPI2512V2-1R0-R 2.0 80 40 1.2 1.0 30 0.8 20 0.6 20 0.2 0.4 10 0.0 0.1 1 10 100 Q value 1.2 10 0.2 0.0 0 1000 0.1 1 Frequency 10 (MHz) 100 0 1000 Frequency (MHz) 45 45 4 40 40 3.5 35 3 30 2.5 25 2 20 1.5 15 1 10 35 1.5 30 25 20 1 Q value 15 10 0.5 0 0.1 1 10 100 5 0.5 0 1000 0 5 0.1 1 MPI2512V2-3R3-R 8 10 35 9 20 4 15 3 10 5 1 0 Frequency (MHz) www.eaton.com/electronics 100 0 1000 Inductance (uH) 25 5 35 30 8 30 6 2 8 40 Q value Inductance (uH) 7 10 0 1000 MPI2512V2-4R7-R 9 1 100 Frequency (MHz) Frequency (MHz) 0.1 10 25 7 6 20 5 15 4 3 10 2 5 1 0 0.1 1 10 Frequency (MHz) 100 0 1000 Q value Inductance (uH) 2 50 Inductance (uH) 2.5 4.5 Q value MPI2512V2-2R2-R MPI2512V2-1R5-R MPI25-V2 High current, low profile, miniature power inductors Technical Data 10649 Effective July 2018  Inductance and temperature rise vs. Current MPI2510V2-R33-R MPI2510V2-R47-R 0.5 60 0.20 50 0.15 40 30 0.10 Inductance (uH) 70 0.25 Temperature rise (°C) 80 0.30 20 0.05 100 90 90 0.35 80 70 0.4 60 0.3 50 40 0.2 30 20 0.1 10 10 0.00 0.0 0 1 2 3 4 5 6 7 0 0 8 1 2 3 0.8 100 0.7 90 90 0.4 50 0.3 40 30 0.2 20 0.1 10 0.0 0 4 5 Inductance (uH) 60 100 1.0 Temperature rise (°C) Inductance (uH) 70 0.5 3 80 70 0.8 60 0.6 50 40 0.4 30 20 0.2 10 0.0 0 0 6 1 2 MPI2510V2-1R5-R 100 1.4 90 1.0 60 0.8 50 0.6 40 30 0.4 20 0.2 10 0.0 0 3 4 5 2.0 Inductance (uH) 70 100 90 Temperature rise (°C) Inductance (uH) 1.2 Idc (A) 5 2.5 80 2 4 MPI2510V2-2R2-R 1.6 1 3 Idc (A) Idc (A) 0 8 1.2 80 0.6 2 7 MPI2510V2-1R0-R MPI2510V2-R68-R 1 6 Idc (A) Idc (A) 0 5 4 Temperature rise (°C) 0 80 70 1.5 60 50 1.0 40 30 Temperature rise (°C) Inductance (uH) 0.6 100 Temperature rise (°C) 0.40 20 0.5 10 0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 Idc (A) www.eaton.com/electronics 9 MPI25-V2 High current, low profile, miniature power inductors  Technical Data 10649 Effective July 2018 Inductance and temperature rise vs. Current 2.5 5.0 100 90 4.5 90 80 4.0 80 3.5 70 3.0 60 2.5 50 2.0 40 1.5 30 20 1.0 20 10 0.5 10 0 0.0 70 60 2.0 50 1.5 40 30 1.0 0.5 0.0 1 1.5 2 2.5 3 0 0 0.5 Idc (A) 90 0.25 70 60 0.20 50 0.15 40 30 0.10 20 0.05 10 0.00 0 3 4 5 6 7 Inductance (uH) 80 Temperature rise (°C) Inductance (uH) 0.30 2 0.50 100 0.45 90 0.40 80 0.35 70 0.30 60 0.25 50 0.20 40 0.15 30 0.10 20 0.05 10 0.00 8 0 0 Idc (A) 1 2 3 80 Inductance (uH) 0.6 70 0.5 60 0.4 50 0.3 40 30 0.2 20 0.1 10 0.0 0 4 Idc (A) 10 www.eaton.com/electronics 7 8 5 6 7 100 90 1.0 Inductance (uH) 0.7 90 3 6 1.2 Temperature rise (°C) 100 2 5 MPI2512V2-1R0-R MPI2512V2-R68-R 1 4 Idc (A) 0.8 0 2.5 MPI2512V2-R47-R 100 0.35 1 2 Idc (A) MPI2512V2-R33-R 0 1.5 1 Temperature rise (°C) 0.5 80 70 0.8 60 0.6 50 40 0.4 30 20 0.2 10 0.0 0 0 1 2 3 Idc (A) 4 5 6 Temperature rise (°C) 0 Inductance (uH) Inductance (uH) 3.0 100 Temperature rise (°C) 3.5 Temperature rise (°C) MPI2510V2-4R7-R MPI2510V2-3R3-R MPI25-V2 High current, low profile, miniature power inductors Technical Data 10649 Effective July 2018  Inductance and temperature rise vs. Current MPI2512V2-1R5-R MPI2512V2-2R2-R 100 90 90 1.4 2.0 60 0.8 50 40 0.6 30 0.4 20 0.2 80 70 Inductance (uH) 70 1.0 Temperature rise (°C) 80 1.2 1.5 60 50 1.0 40 30 0.5 20 10 0.0 10 0 0 1 2 3 4 0.0 5 0 0 0.5 1 1.5 2 Idc (A) 3 3.5 4 Idc (A) MPI2512V2-3R3-R 3.5 MPI2512V2-4R7-R 100 6.0 100 90 3.0 90 5.0 2.5 70 60 2.0 50 1.5 40 30 1.0 20 0.5 10 0.0 0 0 0.5 1 1.5 2 Idc (A) 2.5 3 3.5 4 Inductance (uH) 80 Temperature rise (°C) Inductance (uH) 2.5 80 70 4.0 60 3.0 50 40 2.0 30 Temperature rise (°C) Inductance (uH) 2.5 100 Temperature rise (°C) 1.6 20 1.0 10 0.0 0 0 0.5 1 1.5 2 2.5 Idc (A) www.eaton.com/electronics 11 MPI25-V2 High current, low profile, miniature power inductors  Technical Data 10650 Effective July 2018 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package Thickness Volume mm3
MPI2512V2-R47-R 价格&库存
很抱歉,暂时无法提供与“MPI2512V2-R47-R”相匹配的价格&库存,您可以联系我们找货
MPI2512V2-R47-R
  • 3000+5.955673000+0.71167
  • 6000+5.617956000+0.67131
库存:8319
MPI2512V2-R47-R
  • 1+14.424821+1.72368
  • 10+11.2240510+1.34121
  • 25+10.1469825+1.21250
  • 50+9.4001050+1.12326
  • 100+8.70711100+1.04045
  • 250+7.86561250+0.93989
  • 500+7.28176500+0.87013
  • 1000+6.738871000+0.80526
库存:8319
