T echnical Specification
ENERGY VERY ENDURE
ER14505
Lithium-thionyl Chloride
(Li-SOCl2) Battery
International size reference: AA
ELECTRICAL CHARACTERISTICS
(typical values for cells stored for one year or les s, at 25 C)
Nominal capacity
2.7Ah
(At 2 mA, +25 C, 2.0V cut off. The capacity restored by the cell
varies according to current drain, temperature and cut off voltage.)
Nominal voltage
3.6V
Maximum continuous current
Non-restricted for transport
50mA
(For the fresh cell* to get 50% of the nominal capacity at
+25 C 2.0V cut off.Higher currents possible, consult EVE.)
Maximum pulse capability:
Typical up to 150mA
(150mA/0.1 second pulse, drained every 2 min at 25℃ from undischarged cells with
10uA base current, yield voltage readings above 3.0V. This data is base on the fresh
battery* performance, voltage readings may vary according to the pulse characteristics,
the temperature, and the cell’s previous history.
Fitting the cell with a Lithium-ion Battery Capacitor or a capacitor may be recommended
in servere conditions, consult EVE.
Storage
(recommended)
+30 C max
(for more severe condition consult EVE)
Operating temperature range
-60 C / +85 C
(Operation at temperature different from ambient may lead
to reduced capacit y and lower voltage plateau readi ngs.)
Typical weight
19g
* Fresh cell/battery:
Defined as the cell or battery that stored at +25℃ max. Within 3 months.
WARNING:
Fire, explosion and severe burn hazard. Do not recharge, crush, disassemble, heat above 100 C,
incinerate, or expose contents to water.
Do not solder directery to the cell, use tabbed cell intead.
ER14505
1.Typical discharge profile at +25 C (Median value)
2. Voltage plateau versus Current and Temperature
(at mid-discharge)
AVAILABLE
TERMINATIONS
Suffix-/S
Suffix-/P
Suffix-/T
Suffix-/2PT
Suffix-/3PT/3TP
Standard
Axial Pins
Solder Tabs
Radial Pins
Radial Pins
View available terminations
3. Capacity versus Current and Temperature
(2.0V cut off)
4. STORAGE CHARACTERISTICS
Attention:
Information in this document is subject to change without notice. Any representations in this document concerning performance
are for informational purpose only. This document becomes contractual only after written confirmation by EVE.
EVE ENERGY CO., LTD.
Address.:EVE Industrial Park, XiKeng Industrial zone, Huihuan Town, Huizhou, Guangdong, China
Operator: (86-752)260 6966 Fax: (86-752)260 6033
http:// www.evebattery.com Email: sales@evebattery.com
Latest version can be downloaded from the EVE website
Long
Dec 2015
很抱歉,暂时无法提供与“EVE ER14505 P”相匹配的价格&库存,您可以联系我们找货
