FCF25FP-R200E
FCF25FP-R200E
    PSA(信昌电陶)
    贴片电阻 2512 200mΩ ±1% 1W ±200ppm/℃
FCF25FP-R200E 数据手册
信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.566-1, Gaoshi Rd., Lujhu, Yangmei Dist., Taoyuan City 32668, Taiwan, R.O.C. Tel.:+886-3-4753355 Fax:+886-3-4854959 SPECIFICATION FOR APPROVAL DATE: CUSTOMER: PART NAME: General Purpose Lead Free &. Halogen Free Chip Resistors CUSTOMER'S DWG. NO.: CUSTOMER'S PART NO.: PDC PART NO.: FCF-E SERIES APPROVED DESCRIPTION.: ACTION RESULT FULL APPROVED CONDITIONAL APPROVED REJECTED OUR ACTION "V" SIGNATURE PREPARED By Jenny Tseng CHECKED By Tony Chou APPROVED By Byron Tsai CUSTOMER'S SIGNATURE NOTE CUSTOMER SIGNATURE FOR ACCEPTANCE FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors 1. Features ………………………………………..……………..…….2 2. Applications…..…..………………………………..………………. 2 3. Dimension and construction ………………………..……………..2 4. Power Derating Curve …..…………………………….…………..3 5. Rating ……………………………………………………………….4 6. Part Number ………………………………..………………………5 7. Resistance Marking / Soldering 8. Reliability Performance…………………………………………….7 9. Packing ………………………………………………….…………..8 9.1 Peel Strength of Top Cover Tape……………………………….8 9.2 Tape Packaging Dimensions……………………………………8 9.3 Reel Dimensions………………………………………………....9 ………………………………..5 10. Storage / Handling ……………………………………….…………..9 1/9 FCF(E)-REV.8.0.I50 FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors 1. Features     Low resistance and high precision (1%). Excellent reliability and suitable cost. Suitable for lead free soldering. RoHS compliant & Halogen Free. 2. Applications     Consumer electronics, M/B. Battery pack, BTC. Notebook, Tablet PC. Portable Device, Electronic Equipment. 3. Dimensions and Constructions ※ R value ≧ 40mΩ Unit:mm Type L W C D T FCF06 1.60±0.10 0.80±0.10 0.30±0.20 0.30±0.20 0.45±0.10 FCF05 2.00±0.10 1.25±0.10 0.40±0.20 0.40±0.20 0.50±0.10 FCF06 3.10±0.10 1.60±0.10 0.50±0.25 0.50±0.25 0.55±0.10 FCF12 3.10±0.10 2.60±0.10 0.50±0.25 0.50±0.25 0.55±0.10 FCF20 5.00±0.20 2.50±0.20 0.60±0.25 0.60±0.25 0.60±0.10 FCF25 6.30±0.20 3.10±0.20 0.60±0.25 0.90±0.25 0.60±0.15 2/9 FCF(E)-REV.8.0.I50 FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors ※ R value ≦ 39mΩ Unit:mm Type L W C D T FCF05 2.00±0.10 1.25±0.10 0.25±0.20 0.65±0.20 0.60±0.10 FCF06 3.10±0.15 1.60±0.10 0.25±0.20 0.90±0.25 0.55±0.10 FCF12 3.10±0.15 2.60±0.10 0.25±0.25 0.90±0.25 0.60±0.10 FCF20 5.00±0.20 2.50±0.20 0.25±0.25 1.10±0.25 0.60±0.10 FCF25 6.40±0.20 3.10±0.20 0.25±0.25 1.80±0.30 0.60±0.15 4. Power Derating Curve Operating Temperature Range: -55 to +155 deg.C 3/9 FCF(E)-REV.8.0.I50 FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors 5. Rating FCF_E series Power Rating Type FCF03 _E FCF05 _E FCF06 _E FCF12 _E FCF20 _E FCF25 _E Size 0603 0805 1206 1210 2010 2512 at 70℃ 1/8W 1/4W 1/3W 2/3W 3/4W 1W Max. Max. RCWV Overload Voltage (mV) (mV) 337 754 477 551 779 826 954 1067 1232 1742 1847 2133 Resistance Temperature Resistance Range Standard (mΩ) Tolerance Coefficient Resistance (%) (TCR; ppm/℃) ±1 ±2、±5 Min. Max. ±200 100 910 ±400 50 99 ±200 100 910 ±1 ±400 50 99 ±2、±5 ±600 22 49 ±1000 10 20 ±200 100 910 ±1 ±400 50 99 ±2、±5 ±600 22 49 ±1000 10 20 ±200 100 910 ±1 ±400 50 99 ±2、±5 ±400 22 49 ±1000 10 20 ±200 100 910 ±1 ±400 50 99 ±2、±5 ±600 22 49 ±1000 10 20 ±200 100 910 ±1 ±400 50 99 ±2、±5 ±600 22 49 ±1000 10 20 Note: 1. RCWV = (P×R)1/2 or Max. RCWV listed above, whichever is lower. RCWV:Rated Continue Working Voltage(V),P:Rated Power(W),R:Resistance Value(Ω) 2. Special resistance value request please contact factory. 4/9 FCF(E)-REV.8.0.I50 Values E-24 E-24 E-24 E-24 E-24 E-24 FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors 6. Part Number Type Size Tolerance FCF 03 :0603 F :±1% 05 :0805 G :±2% 06 :1206 J :±5% Packing Paper Tape: Power R Value Series Code (GM) Code -: XXXX 0603.0805.1206 As 4 digit 1210 Rating 12 :1210 T : 5Kpcs 20 :2010 V : 10Kpcs 25 :2512 W : 20Kpcs Plastic Tape: 2010.2512 P : 4Kpcs X : 8Kpcs Y : 16Kpcs Example: FCF06FT-R100E 1206 size, tolerance 1%, paper tape, 100mΩ. 7. Marking/Soldering Resistance value identify: 0805/1206/1210/2010/2512 Top Marking. ( 4 Digits marking to identify the resistance value. ) R068 R068=68mΩ,R120=120mΩ 0603 Top Marking. ( 3 Digits marking to identify the resistance value. ) R12 R12=120mΩ,68M=68mΩ 5/9 FCF(E)-REV.8.0.I50 E FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors Soldering Reference: R12 Recommend Solder Pad Dimensions: Type W D L FCF03 0.90 1.00 3.00 FCF05 1.30 1.15 3.50 FCF06 1.80 1.30 4.70 FCF12 3.00 1.30 4.70 FCF20 3.00 1.50 6.80 FCF25 3.70 1.60 7.60 6/9 Unit:mm FCF(E)-REV.8.0.I50 FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors 8. Reliability Performance Test Item Specification DC Resistance F:±1% Test Method G:±2% IEC 60115-1 / JIS C 5201-1 , Clause 4.5 J:±5% Measure the resistance Value. Resistance to Solder Heat ∆R≦±(1%+0.5mΩ) IEC 60115-1, Clause 4.18 F:∆R≦±(0.5%+0.5mΩ) Solder dipping @ 260℃±5℃ for 10sec.±1sec. Solder Ability Over 95% of termination IEC 60115-1, Clause 4.17 must be covered with After immersing flux, dip in the Solder. 245±2℃ molten solder bath for 3±0.5 sec. No mechanical damage Short ∆R≦±(2%+0.5mΩ) Time Overload F:∆R≦±(1%+0.5mΩ) IEC 60115-1, Clause 4.13 Temperature Coefficient of Resistance (TCR) Within the spec. IEC 60115-1, Clause 4.8 Load Life ∆R≦±(3%+0.5mΩ) IEC 60115-1, Clause 4.25 F:∆R≦±(1%+0.5mΩ) Rated voltage for 1.5 hours for followed 5 × Rated power for 5 seconds T1 T2 Test temperature: 25℃~ 155℃ TCR(ppm/℃) = (R2-R1)/R1×1 / (T2-T1)×106 by a pause 0.5 hour at 70±2℃. Cycle repeated 1000 hours. Bending strength ∆R≦ ±(1%+0.5mΩ) IEC 60115-1 / JIS C 5201-1 ,Clause 4.33 F:∆R≦ ±(0.5%+0.5mΩ) Resistance variance after bended on the 90mm No mechanical damage. PCB. Bending width:3mm for 0603 0805 2mm for 1206 2010 2512 Insulation Resistance Between termination and IEC 60115-1, Clause 4.6 coating must over 1000MΩ Test voltage:100±15V 7/9 FCF(E)-REV.8.0.I50 FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors 9. PACKAGING 9.1 Peel Strength of Top Cover Tape The peel speed shall be about 300 mm/min The peel force of top cover tape shall between 0.1 to 0.7N 9.2 Tape Packaging Dimensions unit:mm Size A B W F E P1 P2 P0 D 0603 1.10±0.20 1.90±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 0805 1.65±0.20 2.40±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 1206 2.00±0.20 3.60±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 1210 3.00±0.20 3.60±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 2010 2.80±0.20 5.50±0.20 12.00±0.30 5.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 2512 3.50±0.20 6.70±0.20 12.00±0.30 5.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50+0.10/-0 8/9 FCF(E)-REV.8.0.I50 FCF E code series. (General Purpose) Current Sensing Resistors Thick-film Chip Resistors 9.3 Reel Dimensions unit:mm Size 0603 0805 1206 1210 2010 2512 Packaging Q’ty A N C D B G T 5kpcs/Reel 178.0±2.0 60.0±0.5 13.0±0.5 20(Min.) 2.0±0.5 10.0±1.5 14.9max. 10kpcs/Reel 254.0±2.0 100.0±1.0 13.5±0.5 20(Min.) 2.0±0.5 10.0±1.5 14.9max. 20kpcs/Reel 330.0±2.0 100.0±1.0 13.5±0.5 20(Min.) 2.0±0.5 10.0±1.5 14.9max. 4kpcs/Reel 178.0±2.0 60.0±0.5 13.0±0.5 20(Min.) 2.0±0.5 13.8±1.5 16.7max. 8kpcs/Reel 254.0±2.0 100.0±0.5 13.5±0.5 20(Min.) 2.0±0.5 13.8±1.5 20.0max. 16kpcs/Reel 330.0±2.0 100.0±1.0 13.5±0.5 20(Min.) 2.0±0.5 13.8±1.5 20.0max. 10. Storage &. Handling … Products are recommended to be used up within one year as ensured shelf life. Check solder ability in case shelf life extension is needed. … To store products with following condition: Temperature:5 to 40℃;Humidity: 20 to 70% relative humidity. ※ All product specification and data are subject to change without notice. 9/9 FCF(E)-REV.8.0.I50
FCF25FP-R200E 价格&库存
很抱歉,暂时无法提供与“FCF25FP-R200E”相匹配的价格&库存,您可以联系我们找货
FCF25FP-R200E
    • 10+0.25910
    • 100+0.21136
    • 300+0.18738
    • 1000+0.16946
    库存:3500
