LKS2G102MS070K63B
LKS2G102MS070K63B
    LIRON(力容)
    插件,D35xL70mm
    牛角型电解电容 插件,D35xL70mm 1000μF ±20% 400V
LKS2G102MS070K63B 数据手册
深 圳 市 力 容 电 子 有 限 公 司 SHENZHEN LIRON ELECTRONICS CO., LTD. 地址:广东省深圳市龙华区观澜街道大富社区桂月路300号岭南工业园A栋 Add: Building A, No.300 Guiyue Road, Guanlan Community,Longhua District, Shenzhen City, Guang Dong, China. TEL: 0755-82525484 FAX: 0755-82544459  http://www.szliron.com 承认书编号 NO:20240712 05 制定日期 Date:2024.07.12 版本Ver: 1.0 承认书 APPROVAL SHEET 承认 APPROVED BY: 客户物料编码 厂商料号 系列 规格 尺寸 备注 Customer P/N: Liron P/N: Series Description ΦD*L Notes C2917466 LKS2G102MS070K63B LKS 400V 1000μF 35X70 二针牛角 签认后,请寄回一份,谢谢! Please return us one copy your signed specification after you approved of it, Thanks! 批 客户承认栏 厂商承认栏 APPROVED COLUMN APPROVED COLUMN 准 APPROVED BY: 审 核 CHECKED BY: 核 准 APPROVAL BY: 罗胜军 审 核 制 定 CHECKED BY: DESIGNED BY: 张永乐 韦英婷 变更记录页 Edit Log 序号 Item 版本 Version 变更日期 Edit Date 变更原因 Reason 变更内容摘要 Abstract 备注 Notes 1 1.0 2024.07.12 无 None 新制作 Newly made 无 None Aluminum Electrolytic Capacitor 1 /10 1. 产 品规格特性表 Electric Characteristics Liron Cap. Rate Surge D.F Cap Ripple Current LC Oper. Case Size ESR (TYP) LOAD LIFE (μF) W.V Volt (%) Tol. 85℃ (μA) Temp. DФ* L (mΩ) 120Hz hours (25±5℃) (VDC) (VDC) (25±5℃) (%) 120Hz (Arms) (25±5℃) (℃) 1000 400 450 15 ±20 2.60 1500 Series P/N LKS2G102M S070K63B LKS (mm) (25±5℃) 85℃ 35X70 110 2000 2. 尺寸图 Diagram of Dimensions (Unit=mm) D:表示直径,L:表示高度; 3. 备注 Remarks: 3.1 Leakage Current Test: I≦0.01CV (μA) After 5 minute whichever is greater measured with rate working voltage applied. 3.2 Operating temperature: 6.3~450VDC: -40℃ ~ + 85℃ C(-40℃/C(+25℃)≥0.7 500~600VDC: -25℃ ~ + 85℃ C(-25℃/C(+25℃)≥0.6 3.3 Cap and Dissipation factor (D.F) Test: At +25℃,120Hz 3.4 Load Life Test: At + 85℃, for 2000 Hrs. 3.5 Shelf Life Test: At + 85℃, for 1000 Hrs. 4、纹波电流系数(Multiplier for ripple current): 4.1、频率系数 Frequency Coefficents CAP (uF) \ Hz UR(V) 50(60) 120 1K 10K 100K ≦50 0.95 1.00 1.10 1.15 1.15 63~100 0.95 1.00 1.16 1.30 1.33 ≥160 0.95 1.00 1.20 1.50 1.55 Aluminum Electrolytic Capacitor 5、使用温度范围(Operating Temperature Range): 5.1 温度范围: 6.3~450VDC:-40℃ ~ + 85℃ 5.2 温度系数 2 /10 500~600VDC: -25℃ ~ + 85℃ 105℃系列温度系数 85℃系列温度系数 Temperature(℃) 40 55 70 85 Temperature(℃) 40 55 70 85 105 Coeffcient 1.7 1.5 1.3 1.0 Coeffcient 2.7 2.5 2.1 1.7 1.0 6、损耗(Dissipation Factor): (25℃,120Hz) 工作电压(WV) Rated voltage 损耗角正切值 D.F.(Tan%) Max 35 100 160 200 250 300 350 400 450 500 550 600 650 420 25 20 15 15 15 15 15 15 15 15 15 15 15 15 注:当标准容量每大于1000uF时,每增加1000uF损失角正切值相应增加2%。 7、浪涌电压(Surge Voltage): 工作电压(WV) Rated voltage 浪涌电压(V) Surge voltage 35 200 250 300 315 350 400 450 500 550 600 650 700 420 44 250 300 350 365 400 450 500 550 600 650 700 750 470 8、漏电流(DC Leakage Current) 施加额定电压5分钟后测试 (After 5 minutes application of rated working voltage) 6.3 ~ 100VDC LC≤ 0.01 CV (μA)或1500μA取小者,(at 25℃) 160 ~ 650VDC LC≤ 0.01 CV (μA)或1500μA取小者,(at 25℃) 9、套管标示(Marking) 电容器上的标示包括: Marking on capacitors include 项目内容 说明ITEM Liron 商标Trade Mark 400V 额定电压Working Voltage 1000μF 标称容量Nominal Capacitance LKS 系列Series VENT 防爆表示Vent -NEG 负极代码表示 Negative 的缩写 最高工作温度 85℃ Maximum Operating Temp (M) 产品容差范围 (行业通用代码) 负极指示线Polarity 产 品 表 面 印 刷 模 板 Liron 400V 1000μF(M) LKS VENT 85℃ -NEG Aluminum Electrolytic Capacitor 3 /10 10、构造图及材料表(Frame drawing and Material table) 10.1、构造图(Frame drawing) 10.2、 芯包分解图(Element drawing) 10.3、材料表(Material Table) No 1 2 构成部件 材质 供应商 Parts Material Supply Factory 铝壳 铝 东莞华和电子 Case Aluminum 新龙宝电子 套管 无铅 PVC 东莞市联云电子 No 6 7 Sleeve 构成部件 材质 供应商 Parts Material Supply Factory 引线条 铝 江天电子 Lead Tab Aluminum 端子 冷轧钢带镀铜镀锡 Terminal Copper and tin 深圳市天阳电子 platinge on SPCC-SD 3 封口盖板 覆胶板 End seal board (EPT) Rubber Bakelite 垫片 PP--聚丙烯 深圳市天阳电子 8 正极箔 铝 东阳光电子 Anode Foil Aluminum 立业电子 负极箔 铝 富奕达电子 Cathode Aluminum 冠业电子 电解液 有机溶剂 深圳新宙邦电子 Electrolyte Organic Solvent 东莞久制电子 众和电子 4 深圳市天阳电子 Bottom plate 9 Foil 5 绝缘纸 电解电容器纸 浙江凯恩纸业 Separator Electrolytic Capacitors 仙鹤纸业 Paper 10 Aluminum Electrolytic Capacitor 11、铝电解电容物料编码系统 4 /8 Part Number System (1)系列Series LKS LKA LKB LKC LHS LHA LCB LCC LRS LRA LRB ...... LHB LHC LLS LLA LLB LSS LSA LSB LSC LCS LCA 系列较多,无法一一列举,需求请联系我们 Series more, not a list of requirements, please contact us (2)工作电压Rated Voltage Code 电压 (WV) 代码 Code 125 25 40 50 63 80 100 160 200 250 350 400 420 450 500 550 1B 1E 1G 1H 1J 1K 2A 2C 2D 2E 2V 2G 2I 2W 2H 2Y (3) 容量Capacitance Code 代码 Code 第6位数字 The 6th digit(A) 容量 µF 第7位数字 The 7th digit(B) 容量=(第6位数字*10+第7位数字)*10 举例 For exampl n 第8位数字 The 8th digit(n) 注:公式中的 n=第8位数字 Capacity = (A * 10 + B) *10 n 第6位数是3,第7位数是9,第8位数是2,则容量为:(3*10+9)*102=3900 A=3, B=9, and n= 2, the capacity is:(3*10+9)*102=3900 (4)容差Capacitance Tolerance Code 容差Cap Tol . (%) 代码Code ±5 ±10 ±20 -10~+20 -25~+20 +20~0 ±15 J K M V U R L (5)直径Case (ØD) 直径 ØD 代码 Code 22 25 30 35 40 45 50 51 64 77 90 100 P Q R S B V J C D E F G (6)高度Height(L:mm) 高度 Height 代码 Code 20 25 30 35 40 45 50 55 60 70 75 80 90 100 110 ... 020 025 030 035 040 045 050 055 060 070 075 080 090 100 110 ... 说明Description:列举的高度并未包含全部 The height above is not all, we can customize the height (7) 端子类型 折弯后 U型垂直焊片 U型平行焊片圆头带孔焊片 长4mm 端子类型 二针牛角 三针牛角 四针牛角 五针牛角 代码Code K L M N U T H X 端子高度 4.0±1mm 4.5±1mm 5±1mm 5.5±1mm 5.8±1mm 6.0±1mm 6.3±1mm 7.6±1mm 代码Code 40 45 50 55 58 60 63 76 (8) 端子长度 (9)套管颜色Sleeve Color 套管颜 色 代码 Code 黑底银字 绿底银字 黑底白字 黑底金字 桔红黑字 咖啡白字 蓝底白字 绿底白字 S P B D O C V G Aluminum Electrolytic Capacito 5 / 10 12. 电气特性 Electrical characteristic NO 1 试验条件及判定 Conditions and Criterion 项目ITEM 工作温度范围 Working temperat ure -40℃ ~ + 85℃ 试验条件 Conditions: 测量温度 Temperature: 25±2℃ 测量频率 Frequency: 120Hz 测量电压 Voltage: 0.3Vrms 判定标准 Criterion: 容量偏差 Tolerance:See Table 1 . 2 电容容量 Capacitance 3 损耗角正切 Dissipation factor (tanδ) 试验条件 Conditions: 测量温度 Temperature: 25±2℃ 测量频率 Frequency: 120Hz 测量电压 Voltage: 0.3Vrms 判定标准 Criterion: See Table 1 漏电流 Leakage Current 试验条件 Conditions: 将额定电压加在电容和 1000Ω±10% 的保护电阻上充电 5分钟后测试。 The rated voltage shall be applied across the capacitors and its protective resistor which shall be 1000Ω±10%.The leakage current shall then be measured after an electrification period of 5 min. 判定标准 Criterion: LC≤0.01 CV, 或1500μA取小者 I: 漏电流 Leakage Current(μA), C: 容量 Capacitance ( μF),V:额定电压 Rated Voltage(V); 4 5 引线强度 Terminal strength 试验条件 Conditions: 引线抗拉强度 Tensile strength of termination: 沿电容器端子引线方向施加下表重力 N, 10±1S 。 A static load of N shall be applied to the terminal in the down-lead direction for 10±1S. 端子线径 重力 Gravity 重锤重量 Weight Diameter mm ( ±10% ) ( ±10% ) SNAP-IN焊针(1.5*0.8) 18N 1.84Kg SNAP-IN型焊片(5*0.6) 18N 1.84Kg 引线抗弯折强度 Bending strength of termination: 在电容器引线施加固定下表重力 N,然后将电容本体弯折 90 度后回到原位,再向 相反方向弯折90 度后回到原位。如此操作约 2~3 秒为一个循环,操作至规定次数 。注意弯曲时不可扭转端子。 A static load of N applied to the lead wire, then bent the body through 90 ° , return to the original position. Next step bent it in opposite direction through 90° with the same speed, again return to the original position. Carry out this operation in about 2~3 sec for one cycle.Do it for specified cycles .But bending the termination is forbidden. 端子线径 重力 Gravity 重锤重量 Weight Diameter mm ( ±10% ) ( ±10% ) SNAP-IN焊针(1.5*0.8) 18N 1.84Kg SNAP-IN型焊片(5*0.6) 18N 1.84Kg 端子最大耐受电流(A) SNAP-IN焊针(1.5*0.8) 12 SNAP-IN型焊片(5.5*0.6) 25 SNAP-IN 型端子不做抗弯试验,LUG 端子做折弯试验,折弯度角 45℃。 判定标准 Criterion: 端子不得有松动、断裂及接触不良之情形。 The terminal should not be loose, breakage and bad connected. Aluminum Electrolytic Capacitor NO 试验条件及判定 Conditions and Criterion 项目ITEM 试验条件 Conditions: 步骤Step 温度 Temperature 6 7 8 9 溫度特性 Temperature characteristics 高温负荷 High temperature load 高温储存 High Temperature Exposure(Storag e) 浪涌试验 Surge Test 6 / 10 测量项目 Item 阻抗 Impedance 1 25±2℃ 2 下限类别温度 Lower Category temperature ±3°C 阻抗 Impedance 3 上限类别温度 Upper Category temperature ±2°C 漏电 LC 要求达到热平衡后测量,并且阻抗在同一频率下测试 Testing when thermal equilibrium and Impedance must be on the same frequency. 判定标准 Criterion: 1.阻抗比不能超出:Z(-25°C)/Z(+25°)≤8、Z(-40°C)/Z(+25°)≤16. 2.LC≤800%初始规格值 Leakage current Shall not more than800% of initial specified value. 试验条件 Conditions: 试验温度Temperature: 85℃ 施加电压 Applied voltage:Rated DC working voltage 试验时间 Test time : 2000H 测试条件 Test condition :在标准大气压下保存 16 小时后进行测试 Test after keep on standard atmospheric conditions for 16 hours. 判定标准 Criterion: 1.容量的变化:C/C ≤± △20%原规格值;Capacitance Change Rate: C/C ≤± △20% of initial value 2.损耗角正切:DF ≤200%原规格值;Dissipation Factor: DF ≤200% of specified value 3.漏电流:LC ≤原规格值;Leakage Current: LC ≤specified value. 4.外观:无明显损伤 Appearance: No visible damage. 试验条件 Conditions: 试验温度 Temperature: 85℃ 施加电压 Applied voltage: None 试验时间 Test time:1000H 测试条件 Test condition: 在标准大气压下保存 16 小时后进行测试 Test after keep on standard atmospheric conditions for 16 hours. Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes. 判定标准 Criterion: 1.容量的变化: C/C ≤± △ 20%原规格值 Capacitance Change Rate: C/C ≤± △ 20% of initial value 2.损耗角正切:DF ≤200%原规格值;Dissipation Factor: DF ≤200% of specified value 3.漏电流:LC ≤原规格值;Leakage Current: LC ≤specified value. 4.外观:无明显损伤 Appearance: No visible damage. 试验条件 Conditions: 试验温度 Temperature: 15~35℃ 施加电压 Applied voltage: 450v 周期 Period:充电 30 秒,放电 330 秒为一个周期。 Charge for 30 seconds,discharge for 330 seconds as a cycle 循环次数 Cycles:1000 测试条件 Test Condition:在标准大气压下保存 16 小时后进行测试。 Test after keep on standard atmospheric conditions for 16 hours. 判定标准 Criterion: 1.容量的变化: C/C ≤±15 △ %原规格值;Capacitance Change Rate: C/C ≤±15 △ % of initial value. 2.损耗角正切:DF ≤原规格值;Dissipation Factor: DF ≤ Original Spec value 3.漏电流:LC ≤原规格值;Leakage Current: LC ≤specified value. 4.外观:无明显损伤 Appearance: No visible damage. Aluminum Electrolytic Capacitor NO 10 11 12 项目ITEM 振动 Vibration 7 / 10 试验条件及判定 Conditions and Criterion 试验条件 Conditions: 频率范围 Frequency Scope : 10~55HZ 振幅 Amplitude : 0.75mm 加速度 Acceleration : 98 m/s 2 (10g) 振动时间 Vibration Time : X、Y、Z 各方向循环各 2 小时、共计 6 小时 X , Y , Z directions each for 2 Hrs, total 6 Hrs. 测试条件 Test Condition : 从振动仪上取下电容后在 30 分钟内测试 Testing within 30 minutes after take it down from vibration machine 判定标准 Criterion: 1.容量的变化: C/C ≤±5 △ %原规格值 Capacitance Change Rate: C/C ≤±5 △ % of initial value 2.损耗角正切:DF ≤原规格值 Dissipation Factor: DF ≤ Original Spec value 3.漏电流:LC ≤原规格值 Leakage Current: LC ≤original Spec value 4.外观:无明显损伤 Appearance: No visible damage 可焊性 Solderability 试验条件 Conditions: 焊锡种类 Kind of solder: Sn:96.5%,Ag:3%,Cu:0.5%或是同等品。 Sn:96.5%,Ag:3%,Cu:0.5% or equal article 锡炉温度 Solder stove temperature: 245±5℃ 浸锡时间 Immerse time: 2.0±0.5S 浸入或移出速度 Speed of immerse or leave: 25±2.5mm/s 浸入深度 Immerse depth: 浸入深度保持在电容本体与焊锡之间距离在 1.5~2.0mm。 1.5~2.0mm between the capacitor body and the solder. 试验次数 times: 1. 测试条件 Test Condition: 从锡炉中取出后 2 小时测试。 Testing after 2 hours for taking it out from the solder stove. 判定标准 Criterion: 新锡附着度应大于 95%。 Above 95% area of surroundings surface shall be covered by the new soldering. 耐焊接热 Resistance to soldering heat 试验条件 Conditions: 焊锡种类 Kind of solder: Sn:96.5%,Ag:3%,Cu:0.5%或是同等品。 Sn:96.5%,Ag:3%,Cu:0.5% or equal article 锡炉温度 Solder stove temperature: 260±(0~3)℃ 浸锡时间 Immerse time: 10±1S 浸入或移出速度 Speed of immerse or leave: 25±2.5mm/s 浸入深度 Immerse depth: 浸入深度保持在电容本体与焊锡之间距离在 1.5~2.0mm。 1.5~2.0mm between the capacitor body and the solder. 试验次数 times: 1. 测试条件 Test Condition: 从锡炉中取出后 2 小时测试。 Testing after 2 hours for taking it out from the solder stove. 判定标准 Criterion: 1.容量的变化: C/C ≤±5 △ %原规格值 Capacitance Change Rate: C/C ≤±5 △ % of initial value 2.损耗角正切:DF ≤原规格值 Dissipation Factor: DF ≤ Original Spec value 3.漏电流:LC ≤原规格值 Leakage Current: LC ≤original Spec value Aluminum Electrolytic Capacitor NO 8 / 10 试验条件及判定 Conditions and Criterion 项目ITEM 试验条件 Conditions: 试验方法 电压 尺寸 保持电流 Method Voltage Size Current 逆向电压法:电容两端施加直流反向电压 80V Reverse Voltage:80V 防爆试验 Vent 13 (仅适用于有 防爆要求产 品) 过压法:两端施加过电压(工作电压的 1.3 倍) Over Voltage:1.3Rated voltage 逆向电压法:电容两端施加直流反向电压 80V Reverse Voltage:80V φ≤22mm φ>22mm WV<160V 160V≤WV<550V WV≥550V 1A 10A 所有尺寸 1A Every Size 所有尺寸 10A Every Size 判定标准 Criterion: 1.当防爆阀打开时,不能有爆炸、闪火、燃烧等现象。 When the pressure relief vent operated, There shall be no explosion, flash, flame, spark or fire from the capacitor during or after the test. 2.如果防爆阀 30 分钟未打开,判定防爆合格,仅适用于过压法。 If the vent does not operate with the voltage applied for 30 minutes, the test is considered to be passed only for the method of over voltage. 试验条件 Conditions: 温度循环 14 Temperature Cycling 15 稳态湿热 High temp and humidity 阶段 Step 温度 Temp. 时间 Time (Min) 30±3 1 下限类别温度±3℃ 2 25±5℃ 3 下限类别温度±2℃ 3 30±3 4 25±5℃ 3 参照 JIC-5101-1 (2010) No:4.16,从 1 到 4 为一个循环,共需要 10 个循环。 Referring to JIC-5101-1 (2010) No:4.16 (1) to (4) = 1 cycle, total 10 cycles. 判定标准 Criterion: 1.容量的变化: C/C ≤±5 △ %原规格值 Capacitance Change Rate: C/C ≤±5 △ % of initial value 2.损耗角正切:DF ≤原规格值 Dissipation Factor: DF ≤ Original Spec value 3.漏电流:LC ≤原规格值 Leakage Current: LC ≤original Spec value 4. 外观:无明显损伤 Appearance: No visible damage 试验条件 Conditions: 温度 Temperature: 40±2℃ 湿度 Humidity: 90~95%RH 维持时间 Maintained Time: 250H 测试条件 Test Condition: 在标准大气压下保存 16 小时后进行测试 Test after keep on standard atmospheric conditions for 16 hours. 判定标准 Criterion: 1.容量的变化: C/C ≤± △ 20%原规格值 Capacitance Change Rate: C/C ≤± △ 20% of initial value 2.损耗角正切:DF ≤1.2 倍原规格值 Dissipation Factor: DF ≤ 1.2 times of the original Spec. value 3.漏电流:LC ≤原规格值 Leakage Current: LC ≤original Spec value 4. 外观:无明显损伤 Appearance: No visible damage Aluminum Electrolytic Capacitor 9 / 10 13、 包装方式:Packaging Spackaging 13.1、内箱装箱数量与外箱标示数量相同,内箱材料为珍珠棉、外箱200g/m2瓦楞原纸; The quantity of the inner case is the same as the quantity marked on the outer case, the inner packaging materials are made of pearl cotton, external carton uses 200g/m2 corrugated base paper; 13.2、牛角产品包装材料的选用及包装数量的规定:纸箱高度以产品高度而定;130-245mm; Packing regulations for Snap-in terminal products: the height of the cartons depends on the height of the products; 130-245mm; 材料materials Φ22 Φ25 Φ30 Φ35 Φ40 Φ45 珍珠棉/层Pearl cotton/layer 154只 130只 80只 70只 63只 42只 13.3 外箱尺寸:Outer Box: 纸箱长435x宽340x高130mm、185mm、210、245mm,装箱规定:Carton length 435x width 340x height 130mm, 185mm, 210, 245mm, packing provisions: 产品高度mm Product height mm 纸箱高度mm Carton height mm 装箱层数 The layer number of packing 30-40 45-50 51-70 71-85 86-90 210 245 185 210 130 3 3 2 2 1 如:Φ35、30-50mm高度、装箱层数3层,产品装箱数量:70只*3层=210只;For example: φ 35, 30-50mm height, packing layer number of 3 layers, product packing number: 70 *3 layers =210; 13.4.Label: 外箱标签模板: 100mm 60mm Aluminum Electrolytic Capacitor 10 / 10 14、使用注意事项 Matters needing attention 铝电解电容器(以下简称电容器)如没有按照规定的条件使用,会出现爆炸及起火等重大事故. 项目 序号 有关 使用 温度, 纹波 电流 有关 外加 电压 及其 它使 用条 件 安装 前的 预备 知识 焊接 清洗 事项 注 意 事 项 1 使用环境、存放环境请根据物品规格书内规定的电容器的使用范围来使用. 2 使用温度、纹波电流的规定范围,请以最大负荷条件为基准来选定电容器;如果过大的电流通过电容器,会出 现异常发热、短路、起火等重大事故. 3 电容器本身是发热品,请注意它会使机器内的温渡上升;为了使机器以正常的状态运作,请确认电容器周边 环境的温度,避开变压器、电感、散热片发热,加剧产品温升。 4 容许纹波电流根据环境温度(电容器周边环境温度)的上升而变小的;根据被预测为最高的环境温度来选择 容许纹波电流。 5 因频率的变化会引起电器的特性随之而变化,请先确定变化的频率范围后来选择电容器;特别是低频率的, 同等价值系列的阻抗会上升,请注意会产生大量的热量。 1 铝电解电容器是有极性的,在反向电压及交流电压输入的时候,会发生短路、起火等重大事故;如果设备是 负载交流,请选择特别指定专用的交流电容器。 2 在出现反向电压的场合要使用双极性的电容器,即使是双极性电容也不要使用在交流电路中。 3 输入电压不能超过额定电压,即由直流电压叠加纹波电流的电压不能超过额定电压;过大的电压会造成发热 、短路、起火等重大事故。 4 浪涌电压是有限定条件的,不能保证长时间使用;即使是短时间使用,总电压也不能超过额定浪涌电压,请 根据要求来选择电容器。 5 多个电容器并联连接的时候要充分考虑电线的阻抗,确保电线和电容器的阻值一样。 6 多个电容器串联连接的时候要使用同一规格的电容器,施加的电压要低于额定电压,并用一个均压电阻与电 容器并联连接,使电压平均地施加到每个电容器上。 7 请选择与机器寿命相吻合的电容器;铝电解电容器如果超过使用期继续使用的话会出现短路等故障,请定期 检查,并适时更换。 8 请不要快速反复的充放电;像焊接设备、相机、闪光灯等以充放电为目的使用时,请使用专用的电容器,伺 服电机等旋转设备的控制电路都是反复的充放电,请商定之后再选定电容器。 9 即使不是急速放电,只要是有连续较大电压变动时,都可能出现寿命特性恶化,短时间故障等问题,在实际操作 时,要确认好使用条件,并进行相关咨询。 10 产品放置时间超过6个月,请确认产品放置环境,产品漏电值将会回升,产品使用前需确认产品特性后使 用,并进行相关咨询,已上线设备请勿满载或超载短时间内启动使用。 1 先确定电容器的规格后、根据规格所规定的要求来安装。 2 3 请务必按极性连接,如果在反向电压下,就算外观合格也不能使用,否则会出现重大的故障。 电容器在掉落或受撞击后其电气性能会变弱,不能使用;请先认真确认包装是否完好后再使用。 4 安装请注意不要将电容器损伤、变形、因为变形后会出现漏液,短路等重大事故。 5 已经安装、上机、通电运行过的电容器,不能使用在剧烈震动或长时间震动设备,否则会造成焊针断裂、产 品损伤不能正常使用。 6 已经上机或通电运行过的电容器不能再使用,做定期测试电气性能的电容器也不能再使用。 1 通常电容套管只是用于标示内容,不能完全起到绝缘功能,如果需要绝缘功能,请进行咨询。 2 如果在由于PCB板上引发的虚锡,由于振动增大会有接触不良、断裂、剥离的风险。 3 由于焊针间距和印刷配线板穴间隔不匹配,焊针需要加工时,在焊接前请不要给电容器本体添加过大压力, 避免损伤焊针和产品本体,引发产品失效。 4 在给产品焊针或PCB板添加助焊剂时,由于会引起腐蚀等原因;请注意不要把助焊剂添加到接线部以外区域 、并控制适量助焊剂,预防PCB板正负极间导电、发热、短路闪火。 5 焊接应在260℃10 秒内,或者控制在350℃ 3秒内;如果超出以上条件,会导致电容性能变化,漏电流增大 等现象。 6 如果把焊接过的电容器取出时,请不要给焊针、电容本体头添加压力,用电烙铁进行充分锡熔后再取出。 7 PCB板的电容器进行焊接以后,不能对电容器进行扭转等任何物理性压力动作;不要有损伤电容器或者过度 震动、碰撞PCB板;不然,将有可能导致本体变形、盖板气密不良、失效等情况。 8 PCB板上电容器进行了焊接以后,不要对它进行碰撞等任何物理性撞击,在印刷电路板有重叠时请防护隔 离,请不要让印刷电路板或者与其碰撞。 9 洗净液不要残留电容器里表面,助焊剂即使不能洗净,也要保持其自身的干燥,由于清洗液、助焊剂的残 存,有可能使卤素对橡胶浸透,并引起PCB板、套管印刷标示、电源线的腐蚀或造成正负极间导电、发热。
LKS2G102MS070K63B 价格&库存
很抱歉,暂时无法提供与“LKS2G102MS070K63B”相匹配的价格&库存,您可以联系我们找货
LKS2G102MS070K63B
  • 1+33.15599
  • 10+31.92799
  • 100+28.98080
  • 500+27.50720
