D SERIES
SMDJ
SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS
VOLTAGE RANGE
5.0 to 440 Volts
FEATURES
* For surface mount application
* Built-in strain relief
* Excellent clamping capability
3000 Watts Peak Power
DO-214AB
* Low profile package
* Fast response time: Typically less than
1.0ps from 0 volt to BV min.
* Typical IR less than 1 A above 10V
* High temperature soldering guaranteed:
260 C / 10 seconds at terminals
.245(6.22)
.220(5.59)
.124(3.15)
.108(2.75)
.280(7.11)
.260(6.60)
MECHANICAL DATA
.012(0.31)
.006(0.15)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Lead: Solderable per MIL-STD-202,
method 208 guranteed
* Polarity: Color band denotes cathode end except Bidirectional
* Mounting position: Any
* Weight: 0.21 grams
.103(2.62)
.079(2.00)
.050(1.27)
.030(0.76)
.008
MAX.
(.203)
.320(8.13)
.305(7.75)
Dimensions in inches and (millimeters)
● "GK " represents the brand name
● "X X X " represents the periodic code
● "YY" represents the product type marking
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
RATINGS
Peak Power Dissipation at TA=25 C, TP=1ms(NOTE 1)
Peak Forward Surge Current at 8.3ms Single Half Sine-Wave
superimposed on rated load (JEDEC method) (NOTE 3)
Maximum Instantenous Forward Voltage at 35.0A for
Unidirectional only
Operating and Storage Temperature Range
SYMBOL
VALUE
UNITS
PPK
Minimum 3000
Watts
IFSM
300
Amps
VF
3.5
Volts
TJ, TSTG
-55 to +150
C
NOTES:
1. Non-repetitive current pulse per Fig. 3 and derated above TA=25 C per Fig. 2.
2
2. Mounted on Copper Pad area of 8.0mm (.013mm Thick) to each terminal.
3. 8.3ms single half sine-wave, duty cycle = 4 pulses per minute maximum.
REV 1.0 2017 JAN
PAGE:1/4
RATING AND CHARACTERISTIC CURVES (SMDJ SERIES)
FIG.1-PEAK PULSE POWER DERATING CURVE
PPPM, PEAK PULSE POWER, KW
100
Non-Repetitive
Pulse Waveform
Shown in Fig. 3
TA=25 C
10
1.0
2
5.0mm COPPER PAD AREAS
0.1
0.1ms
u
PEAK PULSE POWER(PPP) OR CURRENT(IPP)
DERATING IN PERCENTAGE%
FIG.2-PULSE DERATING CURVE
100
75
50
25
1.0ms
u
10ms
u
100ms
u
1.0ms
10ms
25
50
100
125
150
175
FIG.4-TYPICAL JUNCTION CAPACITANCE
FIG.3-PULSE WAVE FORM
150
10,000
TA=25 C
Pulse Width (td) is defined
as the point where the Peak
Current Deacys to 50% of Ipp
Tf=10 s
Peak Value
IPPM
TJ=25 C
f=1.0MHz
Vsig=50mVp-p
5,000
Measued at
Zero Bias
100
2,000
Half Value-IPPM
2
50
1,000
10/1000 sec Waveform
as Defined by R.E.A.
td
e-kt
2.0
3.0
4.0
t, TIME, ms
CJ, CAPACITANCE, pF
IPPM, PEAK PULSE CURRENT, %
75
TA, AMBIENT TEMPERATURE ( C)
td, PULSE WIDTH, sec.
500
Measured at
Stand-Off
Voltage(VMW)
200
100
50
FIG.5-MAXIMUM NON-REPETITIVE PEAK
FORWARD SURGE CURRENT
300
TJ=TJmax
8.3ms Single Half Sine-wave
JEDEC Method
IFSM, PEAK FORWARD SURGE
CURRENT, AMPERES
200
10
1.0
150
2.0
5.0
10
100
200
V(BR), BREAKDOWN VOLTAGE, VOLTS
80
1
5
10
100
NUMBER OF CYCLES AT 60Hz
REV 1.0 2017 JAN
PAGE:2/4
3000 Watt Surface Mount TVS
Reverse
Stand-off
Voltage
PART NUMBER
ADD C FOR BIDIRECTIONAL
See Note 1
Breakdown
Voltage
V BR @ I T
Max.Clamp
Voltage
Max. Peak
Pulse Current
Max. Reverse
Leakage
Package
IT
V C @ I PP
I PP
IR@VR
Device Marking Ccode
uA
UNI
RDE
DDE
RDG
DDG
Test
Current
V RMW
Min
Max
V
V
V
mA
V
A
10
9.2
326.1
800
SMC
BI
SMDJ5.0(C)A
5.0
6.4
7
SMDJ6.0 (C)A
6.0
6.67
7.37
10
10.3
291.3
800
SMDJ6.5 (C)A
6.5
7.22
7.98
10
11.2
267.9
500
RDK
DDK
SMDJ7.0 (C)A
7.0
7.78
8.6
10
12
250
200
PDM
DDM
SMDJ7.5 (C)A
7.5
8.33
9.21
1
12.9
232.6
100
PDP
DDP
SMDJ8.0 (C)A
8.0
8.89
9.83
1
13.6
220.6
50
PDR
DDR
SMDJ8.5 (C)A
8.5
9.44
10.4
1
14.4
208.3
PDT
DDT
SMDJ9.0 (C)A
9.0
10
11.1
1
15.4
194.8
10
PDV
DDV
SMDJ10 (C)A
10.0
11.1
12.3
1
17
176.5
5
PDX
DDX
SMDJ11 (C)A
11.0
12.2
13.5
1
18.2
164.8
2
PDZ
DDZ
SMDJ12 (C)A
12.0
13.3
14.7
1
19.9
150.8
2
PEE
DEE
SMDJ13 (C)A
13.0
14.4
15.9
1
21.5
139.5
2
PEG
DEG
SMDJ14 (C)A
14.0
15.6
17.2
1
23.2
129.3
2
PEK
DEK
SMDJ15 (C)A
15.0
16.7
18.5
1
24.4
123
2
PEM
DEM
SMDJ16 (C)A
19.7
1
26
115.4
2
PEP
DEP
16.0
17.8
SMDJ17 (C)A
17.0
18.9
20.9
1
27.6
108.7
2
PER
DER
SMDJ18 (C)A
18.0
1
29.2
102.7
2
PET
DET
SMDJ20 (C)A
20.0
22.2
24.5
1
32.4
92.6
2
PEV
DEV
SMDJ22 (C)A
22.0
24.4
26.9
1
35.5
84.5
2
PEX
DEX
SMDJ24 (C)A
24.0
26.7
29.5
1
38.9
77.1
2
PEZ
DEZ
SMDJ26 (C)A
26.0
28.9
31.9
1
42.1
71.3
2
PFE
DFE
SMDJ28 (C)A
28.0
31.1
34.4
1
45.4
66.1
2
PFG
DFG
SMDJ30 (C)A
30.0
33.3
36.8
1
48.4
62
2
PFK
DFK
SMDJ33 (C)A
33.0
36.7
40.6
1
53.3
56.3
2
PFM
DFM
SMDJ36 (C)A
36.0
40
44.2
1
58.1
51.6
2
PFP
DFP
SMDJ40 (C)A
40.0
44.4
49.1
1
64.5
46.5
2
PFR
DFR
SMDJ43 (C)A
43.0
47.8
52.8
1
69.4
43.2
2
PFT
DFT
SMDJ45 (C)A
45.0
50
55.3
1
72.7
41.3
2
PFV
DFV
SMDJ48 (C)A
48.0
53.3
58.9
1
77.4
38.8
2
PFX
DFX
SMDJ51 (C)A
51.0
56.7
62.7
1
82.4
36.4
2
PFZ
DFZ
SMDJ54 (C)A
54.0
60
66.3
1
87.1
34.4
2
RGE
DGE
SMDJ58 (C)A
58.0
64.4
71.2
1
93.6
32.1
2
PGG
DGG
SMDJ60 (C)A
60.0
66.7
73.7
1
96.8
31
2
PGK
DGK
SMDJ64 (C)A
64.0
71.1
78.6
1
103
29.1
2
PGM
DGM
SMDJ70 (C)A
70.0
77.8
86
1
113
26.5
2
PGP
DGP
SMDJ75 (C)A
75.0
83.3
92.1
1
121
24.8
2
PGR
DGR
SMDJ78 (C)A
126
23.8
2
PGT
DGT
78.0
86.7
95.8
1
SMDJ85 (C)A
85.0
94.4
104
1
137
21.9
2
PGV
DGV
SMDJ90 (C)A
90.0
100
111
1
146
20.5
2
PGX
DGX
SMDJ100 (C)A
100.0
111
123
1
162
18.5
2
PGZ
DGZ
SMDJ110 (C)A
110.0
122
135
1
177
16.9
2
PHE
DHE
SMDJ120 (C)A
120.0
133
147
1
193
15.5
2
PHG
DHG
SMDJ130 (C)A
130.0
144
159
1
209
14.4
2
PHK
DHK
SMDJ150 (C)A
150.0
167
185
1
243
12.3
2
PHM
DHM
SMDJ160 (C)A
160.0
178
197
1
259
11.6
2
PHP
DHP
SMDJ170 (C)A
170.0
189
209
1
275
10.9
2
PHR
DHR
(C)A
REV 1.0 2017 JAN
PAGE:3/4
Reverse
Stand-off
Voltage
PART NUMBER
Breakdown
Voltage
V BR @ I T
Max.Clamp
Voltage
Max. Peak
Pulse Current
Max. Reverse
Leakage
Package
IT
V C @ I PP
I PP
IR@VR
Test
Current
SMC
V RMW
Min
Max
V
V
V
mA
V
A
uA
UNI
BI
SMD J 180 (C)A
180.0
200.00
220.00
1
291.6
10.29
2
PHT
DHT
See Note 1
SMDJ 190 (C)A
190.0
211.00
232.00
1
307.8
9.75
2
PHV
DHV
SMDJ 200 (C)A
200.0
324.0
9.26
2
PHW
DHW
220.0
247.00
272.00
1
SMDJ 220 (C)A
224.00
246.00
1
356.0
8.43
2
PHX
DHX
SMDJ 250 (C)A
250.0
279.00
309.00
1
405.0
PHZ
DHZ
300.0
335.00
371.00
1
486.0
7.41
6.17
2
SMDJ 300 (C)A
2
PJE
DJE
2
PJG
DJG
SMDJ 350 (C)A
350.0
391.00
432.00
1
SMDJ 400 (C)A
400.0
447.00
494.00
1
567.0
648.0
5.29
4.63
2
PJK
DJK
SMDJ 440 (C)A
440.0
492.00
543.00
1
713.0
4.21
2
PJM
DJM
(C)A
REV 1.0 2017 JAN
PAGE:4/4
很抱歉,暂时无法提供与“SMDJ36CA”相匹配的价格&库存,您可以联系我们找货
