DATA SHEET
METAL OXIDE VARISTORS
POWER SUPPLY
10D series
Product specification– May 08, 2021 V.2
RoHS compliant & Halogen free
Circuit Protection
Product Specification
2
16
10D
Metal Oxide Varistors (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 1100V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +105℃
Storage Temperature:-40℃ ~ +125℃
Safety certification:UL、CSA、VDE
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
4
7
1
K
D
1
J
O
TR
Packing
No suffix: Bulk
TB: Tape & Box & P0=12.7mm
TR: Tape & Reel & P0=12.7mm
EB: Tape & Box & P0=15.0mm
ER: Tape & Reel & P0=15.0mm
Tolerance
K: ±10%
Type
D: Disk
Varistor Voltage
180: 18V
101: 100V
102: 1000V
Surge Series
No suffix: Standard type
J: High Surge type
Lead Shape
No suffix: Straight leads
O: Outside crimped leads
F: Y Kinked leads
Element Diameter
10
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
3
16
10D
Dimensions
D
D
T
D
H1
H1
H
T
K≤3.0
L1
L1
F
L
d1
d
K≤3.0
d
e
d
F
O Type
F Type
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
10.5~16.0
180K
2.0~4.6
1.5
301K
2.7~5.5
2.5
H1
13.0~17.5
220K
2.1~4.7
1.6
331K
2.7~5.8
2.5
L(min.)
20.0
270K
2.1~4.8
1.8
361K
2.9~6.0
2.7
L1(min.)
15.0
330K
2.2~5.0
1.7
391K
3.0~6.2
2.8
D
10.0~12.5
390K
2.1~5.3
1.8
431K
3.2~6.5
3.0
F(±0.8)
7.5
470K
2.2~5.4
1.9
471K
3.3~6.7
3.2
T
Table 2
560K
2.3~5.5
2.1
511K
3.4~6.8
3.4
e(±0.8)
Table 2
680K
2.4~5.6
2.4
561K
3.6~7.0
3.6
d(±0.05)
0.8
820K
2.1~4.7
1.8
621K
3.8~7.3
3.9
d1(±0.4)
1.4
101K
2.4~4.9
2.0
681K
4.0~7.6
4.2
121K
2.4~5.1
2.2
751K
4.3~8.0
4.3
151K
2.2~5.4
1.8
781K
4.4~8.1
4.4
181K
2.3~4.8
1.9
821K
4.6~8.3
4.6
201K
2.4~5.0
2.0
911K
4.8~8.8
5.0
221K
2.5~5.1
2.1
102K
5.4~9.3
5.0
241K
2.6~5.2
2.2
112K
5.8~9.9
5.4
271K
2.6~5.4
2.4
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
4
16
10D
Electrical Characteristics
Part
Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD10
180KD10J
11
14
18(15~21.6)
5
36
500
1000
2.1
3.0
0.05
5600
220KD10
220KD10J
14
18
22(19.5~26)
5
43
500
1000
2.5
5.0
0.05
4500
270KD10
270KD10J
17
22
27(25~31)
5
53
500
1000
3.0
6.0
0.05
3700
330KD10
330KD10J
33(29.5~36.5)
5
65
500
1000
4.0
7.0
0.05
3000
390KD10
390KD10J
25
31
39(35~43)
5
77
500
1000
4.6
9.0
0.05
2400
470KD10
470KD10J
30
38
47(42~52)
5
93
500
1000
5.5
11.0
0.05
2100
560KD10
560KD10J
35
45
56(50~62)
5
110
500
1000
7.0
13.0
0.05
1800
680KD10
680KD10J
40
56
68(61~75)
5
135
500
1000
8.2
15.0
0.05
1500
820KD10
820KD10J
50
65
82(74~90)
25
135
2500
3500
12.0
17.0
0.4
1200
101KD10
101KD10J
60
85
100(90~110)
25
165
2500
3500
15.0
18.0
0.4
1000
121KD10
121KD10J
75
100
120(108~132)
25
200
2500
3500
18.0
21.0
0.4
830
151KD10
151KD10J
95
125
150(135~165)
25
250
2500
3500
22.0
25.0
0.4
670
181KD10
181KD10J
115
150
180(162~198)
25
300
2500
3500
27.0
30.0
0.4
560
201KD10
201KD10J
130
170
200(180~220)
25
340
2500
3500
30.0
35.0
0.4
500
221KD10
221KD10J
140
180
220(198~242)
25
360
2500
3500
32.0
39.0
0.4
450
241KD10
241KD10J
150
200
240(216~264)
25
395
2500
3500
35.0
42.0
0.4
420
271KD10
271KD10J
175
225
270(243~297)
25
455
2500
3500
37.0
49.0
0.4
370
301KD10
301KD10J
190
250
300(270~330)
25
500
2500
3500
40.0
54.0
0.4
330
331KD10
331KD10J
210
275
330(297~363)
25
550
2500
3500
43.0
58.0
0.4
300
361KD10
361KD10J
230
300
360(324~396)
25
595
2500
3500
47.0
65.0
0.4
280
391KD10
391KD10J
250
320
390(351~429)
25
650
2500
3500
60.0
70.0
0.4
260
431KD10
431KD10J
275
350
430(387~473)
25
710
2500
3500
65.0
80.0
0.4
230
471KD10
471KD10J
300
385
470(423~517)
25
775
2500
3500
67.0
85.0
0.4
210
511KD10
511KD10J
320
415
510(459~561)
25
845
2500
3500
69.0
90.0
0.4
200
561KD10
561KD10J
350
460
560(504~616)
25
925
2500
3500
70.0
92.0
0.4
180
621KD10
621KD10J
385
505
620(558~682)
25
1025
2500
3500
72.0
95.0
0.4
160
681KD10
681KD10J
420
560
680(612~748)
25
1120
2500
3500
75.0
98.0
0.4
150
751KD10
751KD10J
460
615
750(675~825)
25
1240
2500
3500
77.0
100.0
0.4
130
781KD10
781KD10J
485
640
780(702~858)
25
1290
2500
3500
80.0
105.0
0.4
125
821KD10
821KD10J
510
670
820(738~902)
25
1355
2500
3500
85.0
110.0
0.4
120
911KD10
911KD10J
550
745
910(819~1001)
25
1500
2500
3500
93.0
130.0
0.4
110
102KD10
102KD10J
625
825
1000(900~1100)
25
1650
2500
3500
102.0
140.0
0.4
100
112KD10
112KD10J
680
895
1100(990~1210)
25
1815
2500
3500
115.0
155.0
0.4
90
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K)
IR≤25μA (820K~112K)
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
5
16
10D
Maximum Surge Current Derating Curve
820KD10 to 112KD10
180KD10 to 680KD10
10000
10000
1000
10
1
100
Max. Surge Current (A)
1000
1
2
2
102
103
104
105
106
10
10
1
100
102
1034
10
105
106
10
1
0.1
10
100
1000
0.1
10
10000
100
1000
Td (μs)
Td (μs)
180KD10J to 680KD10J
820KD10J to 112KD10J
10000
10000
10000
1
2
1000
1
2
100
10
1000
10
102
103
1045
10
106
102
103
1045
106
10
10
1
1
0.1
10
100
10
100
1000
Td (μs)
10000
0.1
10
100
1000
10000
Td (μs)
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
10D
6
16
Maximum Leakage Current and Maximum Clamping Voltage Curve
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
10D
7
16
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
10D
8
16
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
10D
9
16
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
10
16
10D
Reliability
Items
Standard
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
IEC60068-2-21
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
No visible damage
1.0
2.0
4.0
|ΔV1mA/V1mA |≤5%
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
Bending Strength
of Terminals
Vibration
Solderability
Resistance to
Soldering Heat
High Temperature
Storage
Low Temperature
Storage
Damp Heat,
Steady State
High Temperature
Load
0.5<d≤0.8
0.8<d≤1.25
1.25<d
IEC60068-2-21
Force (kg)
0.5
1.0
2.0
IEC60068-2-6
Frequency range: 10~55 Hz
2
Amplitude: 0.75mm or 98m/s
Direction: 3 mutually perpendicular directions, 2hrs each.
IEC60068-2-20
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
Ambient Temp: 125±2℃
Duration: 1000±24hrs
At least 95% of terminal
electrode is covered by
new solder
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Ambient Temp: -40±2℃
No visible damage
|ΔV1mA/V1mA |≤5%
IEC60068-2-78
The test is divided into two groups .
a. 40±2℃ , 90~95% RH for 1344±24hrs
b. 40±2℃ , 90~95% RH,at 10%VDC ,1344±24 hrs
No visible damage
|ΔV1mA/V1mA|≤10%
Insulation
Resistance≧100MΩ
MIL-STD-202
Ambient Temp: 105±2℃
Method 108
Load: Max. Allowable Voltage In AC.
IEC60068-2-20
IEC60068-2-2
IEC60068-2-1
|ΔV1mA/V1mA|≤10%
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
IEC60068-2-14
10/1000µS
Surge Life
Temperature (℃)
Period (minutes)
1
-40±3
30±3
No visible damage
2
Room temperature
5±3
|ΔV1mA/V1mA |≤5%
3
125±3
30±3
4
Room temperature
5±3
8/20µS waveform,10 surge currents, unipolar, interval
8/20uS
Surge Life
Step
IEC61051-1
30secs,amplitude corresponding to max. surge current
No visible damage
△Vb(1mA)≦±10%
derating curves for 20µS.
10/1000µS waveform,10 surge currents, unipolar, interval
IEC61051-1
2mins,amplitude corresponding to max. surge current derating
No visible damage
|ΔV1mA/V1mA |≤10%
curves for 1000µS.
Voltage Proof
IEC61051-1
Metal balls method, 2500Vac 1 min.
No visible damage
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
11
16
10D
Soldering Recommendation
Lead-free Wave Soldering Recommendation
300
Maximum Wave 265℃
Preheating
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Marking Code
① Brightking Logo
② Varistor Voltage
①
③ UL Accreditation Logo
XXXKDXXX
②
③
④
XXX Y
VDE
⑤
⑥
⑦
④ VDE Accreditation Logo
⑤“J”is High Surge Code, no“J”is Standard Surge
⑥ Disk Size
⑦ Internal control code
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
12
16
10D
Taping Dimensions
P2
P
h
B
W0
W
H0
W2
D0
I
P1
F
P0
W1
t
P2
h
B
P
W0
W
H0
W2
D0
I
P1
F
P0
W1
t
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
36max
Symbol
Dimension (mm)
P
15.0±1.0
P0
15.0±1.0
P1
3.85±0.7
P2
7.5±1.3
F
7.5±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
36max
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
13
16
10D
Taping Dimensions
P2
h
P
B
W0
W
H0
W2
D0
I
F
P1
P0
W1
t
P2
h
B
P
W0
W
H0
W2
D0
I
F
P1
P0
W1
t
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
36max
Symbol
Dimension (mm)
P
15.0±1.0
P0
15.0±1.0
P1
3.85±0.7
P2
7.5±1.3
F
7.5±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
36max
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
14
16
10D
Taping Dimensions
P
h
B
P2
W0
W
H2
W2
D0
I
F
P1
P0
W1
t
P2
h
B
P
W0
W
H2
W2
D0
I
P1
F
P0
W1
t
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H2
20.0±2.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
36max
Symbol
Dimension (mm)
P
15.0±1.0
P0
15.0±1.0
P1
3.85±0.7
P2
7.5±1.3
F
7.5±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H2
20.0±2.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
36max
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
15
16
10D
Quantity
Packaging Dimensions (Unit: mm)
Quantity
In bulk for Terminals Untrimmed Products
500pcs/bag
4bags/box
(180K~621K)
5M
ax
400pcs/bag
4bags/box
(681K~112K)
300pcs/bag
4bags/box
(122K~182K)
16
130 Max.
250 Max.
In bulk for Terminals Trimmed Products
500pcs/bag
4bags/box
(180K~621K)
5M
ax
400pcs/bag
4bags/box
(681K~112K)
16
66 Max.
252 Max.
300pcs/bag
4bags/box
(122K~182K)
Quantity
750pcs/box
(180K~241K)
0M
ax
600pcs/box
(271K~391K)
500pcs/box
(431K~621K)
25
60 Max.
340 Max.
300pcs/box
(681K~112K)
5M
ax
1000pcs/reel
(180K~391K)
36
60 Max.
750pcs/reel
(431K~621K)
365 Max.
55 Max.
30±1
Φ365 Max.
500pcs/reel
(681K~112K)
www.yageo.com
May. 08, 2021 V.0
Circuit Protection
16
16
10D
Quantity
Quantity
1000pcs/box
(180K~391K)
0M
ax
750pcs/box
(431K~621K)
25
60 Max.
600pcs/box
(681K~751K)
340 Max.
500pcs/box
(781K~112K)
5M
ax
1000pcs/reel
(180K~391K)
36
60 Max.
750pcs/reel
(431K~751K)
365 Max.
55 Max.
30±1
Φ365 Max.
500pcs/reel
(781K~112K)
Storage Condition of Products
(I) Storage Conditions :
1.Storage Temperature : -10℃ ~ +40℃
2.Relative Humidity : ≦80%RH
3.Keep away from corrosive atmosphere and sunlight.
(II) Period of Storage : 1 year
www.yageo.com
May. 08, 2021 V.0
Circuit Protection Components
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum exten t permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates
do not recommend the use of commercial or automotive grade products for high reliability
applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
