1SMB5349B
1SMB5349B
    YFW(佑风微)
    DO-214AA(SMB)
1SMB5349B 数据手册
1SMB5333B THRU 1SMB 5388B SMB Silicon Planar Zener Diodes Pinning 1.Cathode FEATURES  Total power dissipation: Max. 5 W.  Wide zener reverse voltage range 3.3V to 200V.  plastic package suitable for surface mounted design. 2.Anode 1 2 DO-214AA/SMB  Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case: DO-214AA/SMB  Terminals: Solderable per MIL-STD-750, Method 2026  Approx. Weight: 0.095g / 0.003oz Absolute Maximum Ratings And Characteristics (Ta = 25 °C) Rating Symbol Value Unit Power Dissipation at T L = 25 °C PD 5 W Maximum Forward Voltage at I F = 1.0 A VF 1.2 V Thermal Resistance, Junction to Ambient (Note 1) RӨJA 90 °C/W Thermal Resistance, Junction to Lead (Note 1) RӨJL 25 °C/W TJ, TSTG - 65 to + 150 °C Operating and Storage Temperature Range Note : (1) When mounted on FR4 PC board (1 oz Cu) with recommended footprint. Fig. 1 POWER DERATING CURVE Fig.2 Maximum Non-Repetitive Surg Current versus Nominal Zener Voltage Ir, PEAK SURGE CURRENT (AMPS) PD, MAXIMUM DISSIPATION (WATTS) 5.0 4.0 3.0 2.0 1.0 40 PW=1 ms* 20 10 PW=8.3 ms* 4 2 1 PW=100 ms* 0.4 PW=1000 ms* 0.2 *SQURE WAVE 0.1 0 0 25 50 75 100 125 3 150 TL, LEAD TEMPERATURE (°C) www.yfwdiode.com 4 6 8 10 20 30 40 80 100 200 NORMINAL Vz (V) 1/3 G uangDong YFW Electronics Co, Ltd. 1SMB5333B THRU 1SMB 5388B SMB ELECTRICAL CHARACTERISTICS TYPE 1SMB5333B 1SMB5334B 1SMB5335B 1SMB5336B 1SMB5337B 1SMB5338B 1SMB5339B 1SMB5340B 1SMB5341B 1SMB5342B 1SMB5343B 1SMB5344B 1SMB5345B 1SMB5346B 1SMB5347B 1SMB5348B 1SMB5349B 1SMB5350B 1SMB5351B 1SMB5352B 1SMB5353B 1SMB5354B 1SMB5355B 1SMB5356B 1SMB5357B 1SMB5358B 1SMB5359B 1SMB5360B 1SMB5361B 1SMB5362B 1SMB5363B 1SMB5364B 1SMB5365B 1SMB5366B 1SMB5367B 1SMB5368B 1SMB5369B 1SMB5370B 1SMB5371B 1SMB5372B 1SMB5373B 1SMB5374B 1SMB5375B 1SMB5376B 1SMB5377B 1SMB5378B 1SMB5379B 1SMB5380B 1SMB5381B 1SMB5382B 1SMB5383B 1SMB5384B 1SMB5385B 1SMB5386B 1SMB5387B 1SMB5388B Regulator Voltage VZ @ IZT IZT (V) (mA) 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.0 6.2 6.8 7.5 8.2 8.7 9.1 10 11 12 13 14 15 16 17 18 19 20 22 24 25 27 28 30 33 36 39 43 47 51 56 60 62 68 75 82 87 91 100 110 120 130 140 150 160 170 180 190 200 380 350 320 290 260 240 220 200 200 175 175 150 150 150 125 125 100 100 100 75 75 70 65 65 65 50 50 50 50 50 40 40 30 30 30 25 25 20 20 20 20 20 15 15 15 12 12 10 10 8.0 8.0 8.0 8.0 5.0 5.0 5.0 (Rating at 25 °C ambient temperature unless otherwise specified) Maximum Zener Maximum Reverse Maximum Maximum Impedance Leakage Current Zener Current Surge Current ZZT @ IZT ZZK @ IZK IZK IR @ VR IZM IZSM (Ω) (Ω) (mA) (μA) (V) (mA) (A) 3.0 2.5 2.0 2.0 2.0 1.5 1.0 1.0 1.0 1.0 1.5 1.5 2.0 2.0 2.0 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 3.0 3.0 3.5 3.5 4.0 5.0 6.0 8.0 10 11 14 20 25 27 35 40 42 44 45 65 75 75 90 125 170 190 230 330 350 380 430 450 480 400 500 500 500 450 400 400 300 200 200 200 200 200 150 125 125 125 100 75 75 75 75 75 75 75 75 100 110 120 130 140 150 160 170 190 210 230 280 350 400 500 620 720 760 760 800 1000 1150 1250 1500 1500 1650 1750 1750 1850 1850 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 300 150 50 10 5.0 1.0 1.0 1.0 1.0 10 10 10 10 7.5 5.0 5.0 2.0 1.0 1.0 1.0 1.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 3.0 5.2 5.7 6.2 6.6 6.9 7.6 8.4 9.1 9.9 10.6 11.5 12.2 12.9 13.7 14.4 15.2 16.7 18.2 19.0 20.6 21.2 22.8 25.1 27.4 29.7 32.7 35.8 38.8 42.6 45.5 47.1 51.7 56.0 62.2 66.0 69.2 76.0 83.6 91.2 98.8 106 114 122 129 137 144 152 1440 1320 1220 1100 1010 930 856 790 765 700 630 580 545 520 475 430 395 365 340 315 295 280 265 250 237 216 198 190 176 170 158 144 132 122 110 100 93.0 86.0 79.0 76.0 70.0 63.0 58.0 54.5 52.5 47.5 43.0 39.5 36.6 34.0 31.6 29.4 28.0 26.4 25.0 23.6 20.0 18.7 17.6 16.4 15.3 14.4 13.4 12.7 12.4 11.5 10.7 10.0 9.5 9.2 8.6 8.0 7.5 7.0 6.7 6.3 6.0 5.8 5.5 5.3 5.1 4.7 4.4 4.3 4.1 3.9 3.7 3.5 3.3 3.1 2.8 2.7 2.5 2.3 2.2 2.1 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.2 1.1 1.1 1.0 1.0 0.9 0.9 Maximum Voltage Regulator ∆VZ 0.85 0.80 0.54 0.49 0.44 0.39 0.25 0.19 0.10 0.15 0.15 0.20 0.20 0.22 0.22 0.25 0.25 0.25 0.25 0.25 0.30 0.35 0.40 0.40 0.40 0.45 0.55 0.55 0.60 0.60 0.60 0.60 0.65 0.65 0.70 0.80 0.90 1.00 1.20 1.35 1.50 1.60 1.80 2.00 2.20 2.30 2.50 2.50 2.50 2.50 3.00 3.00 3.00 4.00 5.00 5.00 Notes : (1) Suffix " B " indicates ± 5% tolerance, suffix " A " indicates ± 10% tolerance. (2) The surge current (IZSM) is specified as the maximum peak of a non- recurrent half-sin wave of 8.3 ms duration. (3) Voltage regulation (VZ) is the difference between the voltage measured at 10% and 50% of I www.yfwdiode.com 2/3 G uangDong YFW Electronics Co, Ltd. 1SMB5333B THRU 1SMB 5388B SMB DO-214AA SMB Package Outline Plastic surface mounted package; 2 leads L A A1 C A b D E E1 UNIT mm mil VM A A1 L C b 5.59 0.20 1.5 0.305 2.2 E1 A E D max 2.44 4.70 3.94 min 2.13 4.06 3.3 5.08 0.05 0.8 0.152 1.9 max 96 185 155 220 7.9 59 12 87 min 84 160 130 200 2.0 32 6 75 The recommended mounting pad size 2.2 (86) 2.4 (94) 2.8 (110) 2.4 (94) mm Unit : (mil) Summary of Packing Options Package DO-214AA SMB www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 3/3 G uangDong YFW Electronics Co, Ltd.
1SMB5349B 价格&库存
很抱歉,暂时无法提供与“1SMB5349B”相匹配的价格&库存,您可以联系我们找货
1SMB5349B
    • 5+0.66824
    • 50+0.53527
    • 150+0.46879
    • 500+0.41891
    • 3000+0.37901
    • 6000+0.35901
    库存:2752
