SMBJ5349B
SMBJ5349B
    HONGJIACHENG(宏嘉诚)
    DO-214AA(SMB)
SMBJ5349B 数据手册
� �D� 宏迦橙 SMBJ5338B THRU SMBJ5388B SURFACE MOUNT ZENER DIODES www.ichjc.com Features DO-214AA(SMB) •Low Zener Impedance •Power Dissipation of 5000mW •High Stability and High Reliability •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications Zener diode is generally used as reference voltage sources in regulated power supplies or as protective diode in overvoltage protection circuits. Mechanical Data •Case: DO-214AA(SMB) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT VALUE Forward Voltage @ IF=10mA VF V 1.2 Power Dissipation PD mW 5000 Storage Temperature Tstg ℃ -55 ~+150 Typical Thermal Resistance RθJ-A ℃ /W 90 Junction Temperature Tj Electrical Parameter SYMBOL Reverse zener voltage @ IZT ZZT Maximum Zener Impedance @ IZT IZK Reverse Current Maximum Zener Impedance @ IZK VR Reverse voltage IF VF Revision:ZD-May.2023-A0 IF I Reverse current ZZK IR -55 ~+150 PARAMETER VZ IZT ℃ VZ VR Reverse leakage current @ VR IR IZT VF V Forward current Forward voltage @ IF 1 of 5 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SMBJ5338B THRU SMBJ5388B www.ichjc.com Electrical Characteristics (Ta=25℃ Unless otherwise specified) Type Number SMBJ5338B SMBJ5339B SMBJ5340B SMBJ5341B SMBJ5342B SMBJ5343B SMBJ5344B Regulator Voltage Test Curren 5.1 240 VZ(V) IZ(mA) 5.6 220 6.0 6.2 6.8 7.5 8.2 200 200 175 175 150 Maximum Dynamic Impedance Maximum Reverse Current Test Voltage 1.5 1.0 1.0 ZZT(Ω) 1.0 1.0 1.0 1.0 1.5 1.5 SMBJ5345B 8.7 150 2.0 SMBJ5347B 10 125 2.0 SMBJ5346B SMBJ5348B SMBJ5349B SMBJ5350B SMBJ5351B SMBJ5352B SMBJ5353B 9.1 11 12 13 14 15 16 SMBJ5354B 17 SMBJ5356B 19 SMBJ5358B 22 SMBJ5355B SMBJ5357B SMBJ5359B SMBJ5360B SMBJ5361B 18 20 24 25 27 SMBJ5362B 28 SMBJ5364B 33 SMBJ5363B SMBJ5365B 30 36 150 125 100 100 100 75 75 2.5 2.5 2.5 2.5 2.5 50 3.5 50 2.5 3.0 3.5 4.0 5.0 10 5.0 2.0 1.0 0.5 0.5 0.5 0.5 0.5 6.9 7.6 8.4 9.1 9.9 11.5 12.9 13.7 14.4 15.2 16.7 18.2 19 0.5 20.6 0.5 22.8 0.5 0.5 IZSM(A) 865 400 13.4 930 790 765 21.2 25.1 200 520 475 430 395 365 340 315 295 280 264 250 237 216 0.5 32.7 110 0.5 SMBJ5368B 47 25 25 0.5 35.8 100 0.5 42.6 86 30 20 SMBJ5369B 51 25 27 0.5 SMBJ5371B 60 20 40 0.5 SMBJ5370B 56 Revision:ZD-May.2023-A0 20 35 38.8 45.5 2 of 5 6 0.25 0.25 0.3 75 5.3 0.4 75 75 75 110 130 140 5.5 5.1 0.4 0.4 4.7 0.45 4.3 0.55 4.4 4.1 3.9 3.7 3.5 0.55 0.6 0.6 0.6 0.6 160 3.3 0.65 190 2.8 0.7 3.1 0.65 210 2.7 0.8 280 2.3 1 93 230 79 350 Zhuhai Hongjiacheng Technology co., Ltd 6.3 0.25 0.35 170 14 7.0 0.25 5.8 122 30 0.25 0.22 75 150 132 0.2 8 6.7 144 27.4 0.15 0.22 75 75 0.1 9.2 7.5 75 0.19 0.2 125 100 0.25 10 8.6 125 0.39 0.15 125 150 Maximum Voltage Regulation (V) 11.5 9.5 120 158 12.4 200 176 170 12.7 10.7 100 190 14.4 200 198 39 43 200 580 SMBJ5366B SMBJ5367B 300 200 0.5 29.7 400 700 545 12.2 0.5 ZZK @1.0mA 6.6 1.0 0.5 IZM (mA) 630 10.6 1.0 Maximum Maximum Maximum Regulator Dynamic Knee Surge Current Impedance(Ω) Current 5.7 1.0 10 11 3.0 6.2 40 30 3.0 10 10 6.0 8.0 2.0 5.2 50 40 VR(V) 10 5.0 3.0 50 1.0 2.5 65 50 1.0 7.5 2.5 65 1.0 2.0 70 65 IR(µA) SURFACE MOUNT ZENER DIODES 2.5 2.2 0.9 1.2 www.ichjc.com � �D� 宏迦橙 SMBJ5338B THRU SMBJ5388B www.ichjc.com Electrical Characteristics (Ta=25℃ Unless otherwise specified) Type Number SMBJ5372B SMBJ5373B SMBJ5374B SMBJ5375B SMBJ5376B SMBJ5377B 68 20 44 82 15 65 62 75 87 91 120 SMBJ5383B SMBJ5384B SMBJ5385B SMBJ5386B SMBJ5387B SMBJ5388B 0.5 IZ( mA) SMBJ5380B SMBJ5382B 42 VZ(V) 100 SMBJ5381B Maximum Reverse Current Test Curren SMBJ5378B SMBJ5379B Maximum Dynamic Impedance Regulator Voltage 110 130 20 20 15 15 12 160 8.0 170 180 190 200 Revision:ZD-May.2023-A0 8.0 5.0 5.0 5.0 51.7 0.5 62.2 0.5 69.2 0.5 83.6 0.5 98.8 0.5 75 90 190 8.0 0.5 75 10 8.0 VR(V) 0.5 125 10 IR(µA) 45 12 140 150 ZZT( Ω) 170 230 330 350 380 430 450 480 Test Voltage 47.1 56 0.5 0.5 0.5 0.5 0.5 0.5 0.5 3 of 5 IZM (mA) 76 70 Maximum Dynamic Knee Impedance ZZK @1.0mA (Ω) 400 500 Maximum Surge Current IZSM(A) 1.35 1.6 2.0 1.9 66 54.5 760 1.7 76 47.5 58 52.5 720 760 800 43 1000 36.6 1250 91.2 39.5 106 34 114 31.6 129 28 29.4 137 26.4 152 23.6 25 Zhuhai Hongjiacheng Technology co., Ltd 1150 1500 1500 1650 1750 1750 1850 1850 Maximum Voltage Regulation (V) 2.1 620 144 0.5 Maximum Regulator Current 63 122 0.5 SURFACE MOUNT ZENER DIODES 1.8 1.6 1.5 1.4 1.3 1.2 1.2 1.1 1.1 1.0 1.0 0.9 0.9 1.5 1.8 2.0 2.2 2.3 2.5 2.5 2.5 2.5 3.0 3.0 3.0 4.0 5.0 5.0 www.ichjc.com � �D� 宏迦橙 SMBJ5338B THRU SMBJ5388B SURFACE MOUNT ZENER DIODES www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 6 10000 1000 TL 4 ZenerCurrentI Z (mA) PowerDissipationP(W) D 5 100 3 10 2 TA 1 0 VZ-6.0thru10Volts 0 25 50 1 75 100 TEMPERATURE(℃) 125 150 0.1 175 0 Fig. 1 Power Derating Curve 1000 2 3 4 5 6 7 ZenerVoltageV Z (V) 8 9 11 10 Fig.2 Typical Zener Breakdown Characteristics 1000 VZ-11thru75Volts VZ-82thru200Volts ZenerCurrentI Z (mA) 100 ZenerCurrentI Z (mA) 100 10 10 1 0.1 10 1 1 20 30 40 50 ZenerVoltageV Z (V) 60 70 0.1 80 80 Fig.3 Typical Zener Breakdown Characteristics Revision:ZD-May.2023-A0 100 120 140 160 ZenerVoltageV Z (V) 180 200 220 Fig.4 Typical Zener Breakdown Characteristics 4 of 5 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SMBJ5338B THRU SMBJ5388B SURFACE MOUNT ZENER DIODES www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMB R3 0.098 3000 6000 48000 13'' Package Outline Dimensions (SMB/DO-214AA) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:ZD-May.2023-A0 5 of 5 Dimensions Millimeters Min. Max. 4.25 4.85 1.85 3.30 2.15 0.75 0.073 0.087 3.94 0.130 0.155 2.65 1.52 0.203 0.15 0.31 5.59 Min. Max. 2.10 - - Zhuhai Hongjiacheng Technology co., Ltd 0.167 0.191 0.085 0.104 0.030 0.060 - 0.008 0.200 0.220 0.006 Dimensions Millimeters 2.26 Max. 2.21 - 5.08 Min. Inches Min. - 0.089 2.74 - 0.085 0.012 Inches Max. - 0.107 www.ichjc.com
SMBJ5349B 价格&库存
很抱歉,暂时无法提供与“SMBJ5349B”相匹配的价格&库存,您可以联系我们找货
SMBJ5349B
    • 5+0.77706
    • 50+0.63234
    • 150+0.55998
    • 500+0.50577
    • 3000+0.42876
    • 6000+0.40706
    库存:14779
