� �D�
宏迦橙
SMBJ5338B THRU SMBJ5388B
SURFACE MOUNT ZENER DIODES
www.ichjc.com
Features
DO-214AA(SMB)
•Low Zener Impedance
•Power Dissipation of 5000mW
•High Stability and High Reliability
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
Zener diode is generally used as reference voltage sources in regulated power
supplies or as protective diode in overvoltage protection circuits.
Mechanical Data
•Case: DO-214AA(SMB)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
VALUE
Forward Voltage @ IF=10mA
VF
V
1.2
Power Dissipation
PD
mW
5000
Storage Temperature
Tstg
-55 ~+150
Typical Thermal Resistance
RθJ-A
℃ /W
90
Junction Temperature
Tj
Electrical Parameter
SYMBOL
Reverse zener voltage @ IZT
ZZT
Maximum Zener Impedance @ IZT
IZK
Reverse Current
Maximum Zener Impedance @ IZK
VR
Reverse voltage
IF
VF
Revision:ZD-May.2023-A0
IF
I
Reverse current
ZZK
IR
-55 ~+150
PARAMETER
VZ
IZT
VZ VR
Reverse leakage current @ VR
IR
IZT
VF
V
Forward current
Forward voltage @ IF
1 of 5
Zhuhai Hongjiacheng Technology co., Ltd
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
Type
Number
SMBJ5338B
SMBJ5339B
SMBJ5340B
SMBJ5341B
SMBJ5342B
SMBJ5343B
SMBJ5344B
Regulator
Voltage
Test Curren
5.1
240
VZ(V)
IZ(mA)
5.6
220
6.0
6.2
6.8
7.5
8.2
200
200
175
175
150
Maximum
Dynamic
Impedance
Maximum
Reverse
Current
Test
Voltage
1.5
1.0
1.0
ZZT(Ω)
1.0
1.0
1.0
1.0
1.5
1.5
SMBJ5345B
8.7
150
2.0
SMBJ5347B
10
125
2.0
SMBJ5346B
SMBJ5348B
SMBJ5349B
SMBJ5350B
SMBJ5351B
SMBJ5352B
SMBJ5353B
9.1
11
12
13
14
15
16
SMBJ5354B
17
SMBJ5356B
19
SMBJ5358B
22
SMBJ5355B
SMBJ5357B
SMBJ5359B
SMBJ5360B
SMBJ5361B
18
25
27
SMBJ5362B
28
SMBJ5364B
33
SMBJ5363B
SMBJ5365B
30
36
150
125
100
100
100
75
75
2.5
2.5
2.5
2.5
2.5
50
3.5
50
2.5
3.0
3.5
4.0
5.0
10
5.0
2.0
1.0
0.5
0.5
0.5
0.5
0.5
6.9
7.6
8.4
9.1
9.9
11.5
12.9
13.7
14.4
15.2
16.7
18.2
19
0.5
20.6
0.5
22.8
0.5
0.5
IZSM(A)
865
400
13.4
930
790
765
21.2
25.1
200
520
475
430
395
365
340
315
295
280
264
250
237
216
0.5
32.7
110
0.5
SMBJ5368B
47
25
25
0.5
35.8
100
0.5
42.6
86
30
SMBJ5369B
51
25
27
0.5
SMBJ5371B
60
0.5
SMBJ5370B
56
38.8
45.5
2 of 5
6
0.25
0.25
0.3
75
5.3
0.4
75
75
75
110
130
140
5.5
5.1
0.4
0.4
4.7
0.45
4.3
0.55
4.4
4.1
3.9
3.7
3.5
0.55
0.6
0.6
0.6
0.6
160
3.3
0.65
190
2.8
0.7
3.1
0.65
210
2.7
0.8
280
2.3
1
93
230
79
350
6.3
0.25
0.35
170
14
7.0
0.25
5.8
122
30
0.25
0.22
75
150
132
0.2
8
6.7
144
27.4
0.15
0.22
75
75
0.1
9.2
7.5
75
0.19
0.2
125
100
0.25
10
8.6
125
0.39
0.15
125
150
Maximum
Voltage
Regulation
(V)
11.5
9.5
120
158
12.4
200
176
170
12.7
10.7
100
190
14.4
200
198
39
43
200
580
SMBJ5366B
SMBJ5367B
300
200
0.5
29.7
400
700
545
12.2
0.5
ZZK @1.0mA
6.6
1.0
0.5
IZM (mA)
630
10.6
1.0
Maximum
Maximum
Maximum
Regulator Dynamic Knee
Surge
Current
Impedance(Ω) Current
5.7
1.0
10
11
3.0
6.2
40
30
3.0
10
10
6.0
8.0
2.0
5.2
50
40
VR(V)
10
5.0
3.0
50
1.0
2.5
65
50
1.0
7.5
2.5
65
1.0
2.0
70
65
IR(µA)
2.5
2.2
0.9
1.2
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
Type
Number
SMBJ5372B
SMBJ5373B
SMBJ5374B
SMBJ5375B
SMBJ5376B
SMBJ5377B
68
82
15
65
62
75
87
91
120
SMBJ5383B
SMBJ5384B
SMBJ5385B
SMBJ5386B
SMBJ5387B
SMBJ5388B
0.5
IZ( mA)
SMBJ5380B
SMBJ5382B
42
VZ(V)
100
SMBJ5381B
Maximum
Reverse
Current
Test Curren
SMBJ5378B
SMBJ5379B
Maximum
Dynamic
Impedance
Regulator
Voltage
110
130
15
12
160
8.0
170
180
190
200
8.0
5.0
5.0
5.0
51.7
0.5
62.2
0.5
69.2
0.5
83.6
0.5
98.8
0.5
75
90
190
8.0
0.5
75
10
8.0
VR(V)
0.5
125
10
IR(µA)
45
12
140
150
ZZT( Ω)
170
230
330
350
380
430
450
480
Test
Voltage
47.1
56
0.5
0.5
0.5
0.5
0.5
0.5
0.5
3 of 5
IZM (mA)
76
70
Maximum
Dynamic
Knee
Impedance
ZZK @1.0mA
(Ω)
400
500
Maximum
Surge
Current
IZSM(A)
1.35
1.6
2.0
1.9
66
54.5
760
1.7
76
47.5
58
52.5
720
760
800
43
1000
36.6
1250
91.2
39.5
106
34
114
31.6
129
28
29.4
137
26.4
152
23.6
25
1150
1500
1500
1650
1750
1750
1850
1850
Maximum
Voltage
Regulation
(V)
2.1
620
144
0.5
Maximum
Regulator
Current
63
122
0.5
1.8
1.6
1.5
1.4
1.3
1.2
1.2
1.1
1.1
1.0
1.0
0.9
0.9
1.5
1.8
2.0
2.2
2.3
2.5
2.5
2.5
2.5
3.0
3.0
3.0
4.0
5.0
5.0
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
6
10000
1000
TL
4
ZenerCurrentI Z (mA)
PowerDissipationP(W)
D
5
100
3
10
2
TA
1
VZ-6.0thru10Volts
50
1
75
100
TEMPERATURE(℃)
125
150
0.1
175
Fig. 1 Power Derating Curve
1000
2
3
4
5
6
7
ZenerVoltageV Z (V)
8
9
11
10
Fig.2 Typical Zener Breakdown Characteristics
1000
VZ-11thru75Volts
VZ-82thru200Volts
100
100
10
10
1
0.1
10
1
1
40
50
ZenerVoltageV Z (V)
60
70
0.1
80
80
Fig.3 Typical Zener Breakdown Characteristics
100
120
140
160
ZenerVoltageV Z (V)
180
200
220
Fig.4 Typical Zener Breakdown Characteristics
4 of 5
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMB
R3
0.098
3000
6000
48000
13''
Package Outline Dimensions (SMB/DO-214AA)
Symbol
A C
A
B
B
C
H
D
E
D
E
F
F
G
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
5 of 5
Dimensions
Millimeters
Min.
Max.
4.25
4.85
1.85
3.30
2.15
0.75
0.073
0.087
3.94
0.130
0.155
2.65
1.52
0.203
0.15
0.31
5.59
Min.
Max.
2.10
0.167
0.191
0.085
0.104
0.030
0.060
0.008
0.200
0.220
0.006
Dimensions
Millimeters
2.26
Max.
2.21
5.08
Min.
Inches
Min.
0.089
2.74
0.085
0.012
Inches
Max.
0.107
www.ichjc.com
很抱歉,暂时无法提供与“SMBJ5339B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.87308
- 50+0.71950
- 150+0.64271
- 500+0.58504
- 3000+0.45641
- 6000+0.43330
